Cruise Control??? - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Cruise Control??? (/showthread.php?tid=3875) |
Cruise Control??? - doug_ngl - 11-23-2006 10:54 Hey Gang, Happy T-Day! Nothing like a day of BB chores. I think I have a handle on my water problems, looks like a bad regulator/check valve and a seeping Sporlan letting the water run in a loop instead of building pressure when using the pump. Gonna look for parts tomorrow. The cruise does not work on our rig, so we used the hand throttle on the way home, kinda scary in traffic . While adjusting the throttlelinkage, I saw a heavy gauage beaded chain laying in the valley under the air plentum. I pulled gently on the chain (it was not attatched to anything) and it came loose, bringing a short, light, broken cable with it. Is this the throttle/cruise connection? If so, where does it hook up, is there some bellcrank assy that I am missing? Any light that could be shed on the cruise control assy would be greatly appreciated. Thanks as always. Doug Cruise Control??? - davidkerryedwards - 11-23-2006 13:43 Yes, I believe that is the throttle cruise connection. On mine it goes from the actuator to the throttle linkage. Do you have an actuator in place? My vacuum generator failed and I decided it to replace the vacuum system with an electric version since the vacuum system did not work that well anyway. Kerry 82 Fc 35 Denver --- In WanderlodgeForum@yahoogroups.com, "doug_ngl" > > Hey Gang, Happy T-Day! Nothing like a day of BB chores. I think I have > a handle on my water problems, looks like a bad regulator/check valve > and a seeping Sporlan letting the water run in a loop instead of > building pressure when using the pump. Gonna look for parts tomorrow. > The cruise does not work on our rig, so we used the hand throttle on > the way home, kinda scary in traffic . While adjusting the throttle> linkage, I saw a heavy gauage beaded chain laying in the valley under > the air plentum. I pulled gently on the chain (it was not attatched to > anything) and it came loose, bringing a short, light, broken cable > with > it. Is this the throttle/cruise connection? If so, where does it hook > up, is there some bellcrank assy that I am missing? Any light that > could be shed on the cruise control assy would be greatly appreciated. > Thanks as always. Doug > Cruise Control??? - Jeff Miller - 11-23-2006 15:21 If it's an '80-'83 FC it should have a vacuum-actuator for the cruise control mounted to the rearmost bolts for the intake manifold, driver's side. - Jeff Miller --- In WanderlodgeForum@yahoogroups.com, "davidkerryedwards" > > Yes, I believe that is the throttle cruise connection. On mine it goes from the actuator to > the throttle linkage. Do you have an actuator in place? My vacuum generator failed and I > decided it to replace the vacuum system with an electric version since the vacuum system > did not work that well anyway. > > Kerry > 82 Fc 35 > Denver > > --- In WanderlodgeForum@yahoogroups.com, "doug_ngl" wrote: > > > > Hey Gang, Happy T-Day! Nothing like a day of BB chores. I think I have > > a handle on my water problems, looks like a bad regulator/check valve > > and a seeping Sporlan letting the water run in a loop instead of > > building pressure when using the pump. Gonna look for parts tomorrow. > > The cruise does not work on our rig, so we used the hand throttle on > > the way home, kinda scary in traffic . While adjusting thethrottle > > linkage, I saw a heavy gauage beaded chain laying in the valley under > > the air plentum. I pulled gently on the chain (it was not attatched to > > anything) and it came loose, bringing a short, light, broken cable > > with > > it. Is this the throttle/cruise connection? If so, where does it hook > > up, is there some bellcrank assy that I am missing? Any light that > > could be shed on the cruise control assy would be greatly appreciated. > > Thanks as always. Doug > > > Cruise Control??? - Doug Engel - 11-23-2006 15:41 Kerry, Thanks, The actuator is still in place, but no connection to the throttle linkage, I'll do some recon tomorrow to look for connection opportunities. Doug davidkerryedwards is the throttle cruise connection. On mine it goes from the actuator to the throttle linkage. Do you have an actuator in place? My vacuum generator failed and I decided it to replace the vacuum system with an electric version since the vacuum system did not work that well anyway. Kerry 82 Fc 35 Denver --- In WanderlodgeForum@yahoogroups.com, "doug_ngl" > > Hey Gang, Happy T-Day! Nothing like a day of BB chores. I think I have > a handle on my water problems, looks like a bad regulator/check valve > and a seeping Sporlan letting the water run in a loop instead of > building pressure when using the pump. Gonna look for parts tomorrow. > The cruise does not work on our rig, so we used the hand throttle on > the way home, kinda scary in traffic . While adjusting the throttle> linkage, I saw a heavy gauage beaded chain laying in the valley under > the air plentum. I pulled gently on the chain (it was not attatched to > anything) and it came loose, bringing a short, light, broken cable > with > it. Is this the throttle/cruise connection? If so, where does it hook > up, is there some bellcrank assy that I am missing? Any light that > could be shed on the cruise control assy would be greatly appreciated. > Thanks as always. Doug > Doug Engel, Gunnison, CO. 1981 FC35SB "Pokey" --------------------------------- Everyone is raving about the all-new Yahoo! Mail beta. [Non-text portions of this message have been removed] Cruise Control??? - M Thomas Eastham - 11-24-2006 05:29 I''m in the same situation with my 83 FC35. Please keep us posted on what you figure out. Thanks, Thomas [Non-text portions of this message have been removed] Cruise Control??? - davidkerryedwards - 11-24-2006 05:43 Mine attaches to the throttle linkage up above the rubber booted component of the throttle linkage with the cable end at the actuator and the ball chain at the linkage. Kerry 82 FC 35 Denver- -- In WanderlodgeForum@yahoogroups.com, Doug Engel > > Kerry, Thanks, The actuator is still in place, but no connection to the throttle linkage, I'll do some recon tomorrow to look for connection opportunities. Doug > > davidkerryedwards that is the throttle cruise connection. On mine it goes from the actuator to > the throttle linkage. Do you have an actuator in place? My vacuum generator failed and I > decided it to replace the vacuum system with an electric version since the vacuum system > did not work that well anyway. > > Kerry > 82 Fc 35 > Denver > > --- In WanderlodgeForum@yahoogroups.com, "doug_ngl" > > > > Hey Gang, Happy T-Day! Nothing like a day of BB chores. I think I have > > a handle on my water problems, looks like a bad regulator/check valve > > and a seeping Sporlan letting the water run in a loop instead of > > building pressure when using the pump. Gonna look for parts tomorrow. > > The cruise does not work on our rig, so we used the hand throttle on > > the way home, kinda scary in traffic . While adjusting the throttle> > linkage, I saw a heavy gauage beaded chain laying in the valley under > > the air plentum. I pulled gently on the chain (it was not attatched to > > anything) and it came loose, bringing a short, light, broken cable > > with > > it. Is this the throttle/cruise connection? If so, where does it hook > > up, is there some bellcrank assy that I am missing? Any light that > > could be shed on the cruise control assy would be greatly appreciated. > > Thanks as always. Doug > > > > > > > > > Doug Engel, Gunnison, CO. 1981 FC35SB "Pokey" > > --------------------------------- > Everyone is raving about the all-new Yahoo! Mail beta. > > [Non-text portions of this message have been removed] > Cruise Control??? - Doug Engel - 11-24-2006 07:22 Thanks Kerry. I looked into it more today and found the ball chain component that I had found connects to a vaccum dashpot via a small (read:tiny) cable. The cable is broken. Any ideas on parts sources for this before I start fabricating? What happened to the Broncos yesterday??? Doug davidkerryedwards throttle linkage up above the rubber booted component of the throttle linkage with the cable end at the actuator and the ball chain at the linkage. Kerry 82 FC 35 Denver- -- In WanderlodgeForum@yahoogroups.com, Doug Engel > > Kerry, Thanks, The actuator is still in place, but no connection to the throttle linkage, I'll do some recon tomorrow to look for connection opportunities. Doug > > davidkerryedwards that is the throttle cruise connection. On mine it goes from the actuator to > the throttle linkage. Do you have an actuator in place? My vacuum generator failed and I > decided it to replace the vacuum system with an electric version since the vacuum system > did not work that well anyway. > > Kerry > 82 Fc 35 > Denver > > --- In WanderlodgeForum@yahoogroups.com, "doug_ngl" > > > > Hey Gang, Happy T-Day! Nothing like a day of BB chores. I think I have > > a handle on my water problems, looks like a bad regulator/check valve > > and a seeping Sporlan letting the water run in a loop instead of > > building pressure when using the pump. Gonna look for parts tomorrow. > > The cruise does not work on our rig, so we used the hand throttle on > > the way home, kinda scary in traffic . While adjusting the throttle> > linkage, I saw a heavy gauage beaded chain laying in the valley under > > the air plentum. I pulled gently on the chain (it was not attatched to > > anything) and it came loose, bringing a short, light, broken cable > > with > > it. Is this the throttle/cruise connection? If so, where does it hook > > up, is there some bellcrank assy that I am missing? Any light that > > could be shed on the cruise control assy would be greatly appreciated. > > Thanks as always. Doug > > > > > > > > > Doug Engel, Gunnison, CO. 1981 FC35SB "Pokey" > > --------------------------------- > Everyone is raving about the all-new Yahoo! Mail beta. > > [Non-text portions of this message have been removed] > Doug Engel, Gunnison, CO. 1981 FC35SB "Pokey" --------------------------------- Check out the all-new Yahoo! Mail beta - Fire up a more powerful email and get things done faster. [Non-text portions of this message have been removed] Cruise Control??? - Doug Engel - 11-24-2006 10:07 Thomas, Currently, I have some similar cable and am going to try fabricating a new one. I'll post the results. Doug M Thomas Eastham with my 83 FC35. Please keep us posted on what you figure out. Thanks, Thomas [Non-text portions of this message have been removed] Doug Engel, Gunnison, CO. 1981 FC35SB "Pokey" --------------------------------- Everyone is raving about the all-new Yahoo! Mail beta. [Non-text portions of this message have been removed] |
