location of oil sending unit - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: location of oil sending unit (/showthread.php?tid=3889) |
location of oil sending unit - nslinkman - 11-27-2006 08:50 Can anyone tell me where the oil sending unit on a 8V92 in a 1994 coach. Thanks Nelson Slinkman Westminster, Md location of oil sending unit - Leroy Eckert - 11-27-2006 10:15 Nelson: I can tell you where mine is and that will get you started. Approx 2 feet in front of the rear bumper on the right hand side is a sender about 2" in diameter, gold annodized with a single wire. It screws into a small brass fitting mounted to the frame. Easy change. Hope this helps. Leroy Eckert 1990 WB-40 "Smoke N Mirrors" Niceville, FL ----- Original Message ----- From: nslinkman To: WanderlodgeForum@yahoogroups.com Sent: Monday, November 27, 2006 2:50 PM Subject: [WanderlodgeForum] location of oil sending unit Can anyone tell me where the oil sending unit on a 8V92 in a 1994 coach. Thanks Nelson Slinkman Westminster, Md [Non-text portions of this message have been removed] |
