CRUISE CONTROL-VACUUM CONTROL - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: CRUISE CONTROL-VACUUM CONTROL (/showthread.php?tid=3911) |
CRUISE CONTROL-VACUUM CONTROL - putneyflash - 11-29-2006 23:26 HEY GANG: THERE HAS BEEN A LOT OF DISCUSSION CONCERNING THE VACUUM CONTROL ON OLD BIRDS THAT WAS LOCATED BEHIND THE FRONT BUMPER. WHEN I CALL BLUE BIRD THEY TOLD ME THEY NO LONGER HAD THE PART. THEY SAID JOHN BLECKLEY MOTORS (MACON GA)HAD A REPLACEMENT.THIS DEALER SELLS AND WORKS ON A LOT OF BB, I CALL THE PARTS DEPARTMENT AND SPOKE TO RUSSELL ( 1-877-456-3700) RUSSELL SAYS THEY HAVE ONE THAT WILL REPLACE THE ORGINIAL ONE. THAT YOU MOUNT IT SOMEWHERE ON THE CHASSIS AND RUN AN AIR LINE TO THE ORGINIAL FITTING ON THE BIRD AND CONNECT ONE OF THE ORGINAL AIR LINES TO THE CRUISE TO IT. IT HAS A 12 SOLENIOD SO IF ITS WIRED CORRECTLY IT WILL SHUT OFF WHEN THE KEY SWITCH IS TURNED OFF.( I DON'T THINK THE FITTING WILL LEAK AIR BELOW 75 PSI ANYWAY) IT COST ABOUT $134.00.PLEASE UNDERSTAND I HAVE NOT USE ONE OR INSTALLED I AM GOING BY WHAT RUSSELL HAS RELAYED TO ME HOPE THIS IS GOOD INFO, IF ANYONE BUYS ONE AND INSTALLS LET ME KNOW. RE BRAKE FC-35 SB "SAGECOACH" CRUISE CONTROL-VACUUM CONTROL - davidkerryedwards - 11-30-2006 08:51 Thanks for that info. I'm surprised Bluebird did not tell me that when I called and asked them about the vacuum generator about 8 weeks ago. However, at that price, it's probably just as good to install the Rostra electric cruise control since my vacuum cruise control wasn't that great to begin with. Kerry 82 FC 35 Denver --- In WanderlodgeForum@yahoogroups.com, "putneyflash" > > HEY GANG: THERE HAS BEEN A LOT OF DISCUSSION CONCERNING THE VACUUM > CONTROL ON OLD BIRDS THAT WAS LOCATED BEHIND THE FRONT BUMPER. WHEN I > CALL BLUE BIRD THEY TOLD ME THEY NO LONGER HAD THE PART. THEY SAID > JOHN BLECKLEY MOTORS (MACON GA)HAD A REPLACEMENT.THIS DEALER SELLS AND > WORKS ON A LOT OF BB, I CALL THE PARTS DEPARTMENT AND SPOKE TO RUSSELL > ( 1-877-456-3700) RUSSELL SAYS THEY HAVE ONE THAT WILL REPLACE THE > ORGINIAL ONE. THAT YOU MOUNT IT SOMEWHERE ON THE CHASSIS AND RUN AN > AIR LINE TO THE ORGINIAL FITTING ON THE BIRD AND CONNECT ONE OF THE > ORGINAL AIR LINES TO THE CRUISE TO IT. IT HAS A 12 SOLENIOD SO IF ITS > WIRED CORRECTLY IT WILL SHUT OFF WHEN THE KEY SWITCH IS TURNED OFF. ( I > DON'T THINK THE FITTING WILL LEAK AIR BELOW 75 PSI ANYWAY) > IT COST ABOUT $134.00.PLEASE UNDERSTAND I HAVE NOT USE ONE OR > INSTALLED I AM GOING BY WHAT RUSSELL HAS RELAYED TO ME > HOPE THIS IS GOOD INFO, IF ANYONE BUYS ONE AND INSTALLS LET ME KNOW. > > RE BRAKE FC-35 SB "SAGECOACH" > CRUISE CONTROL-VACUUM CONTROL - putneyflash@...> - 11-30-2006 13:35 I have not heard of the Rostra system, where can i find out about it, any idea od the cost and who installs dealer or owner thanks re brake 198 FC-35 sb > > From: "davidkerryedwards" > Date: 2006/11/30 Thu PM 03:51:58 EST > To: WanderlodgeForum@yahoogroups.com > Subject: [WanderlodgeForum] Re: CRUISE CONTROL-VACUUM CONTROL > > Thanks for that info. I'm surprised Bluebird did not tell me that > when I called and asked them about the vacuum generator about 8 > weeks ago. However, at that price, it's probably just as good to > install the Rostra electric cruise control since my vacuum cruise > control wasn't that great to begin with. > > Kerry > 82 FC 35 > Denver > > > --- In WanderlodgeForum@yahoogroups.com, "putneyflash" > > > > > HEY GANG: THERE HAS BEEN A LOT OF DISCUSSION CONCERNING THE VACUUM > > CONTROL ON OLD BIRDS THAT WAS LOCATED BEHIND THE FRONT BUMPER. > WHEN I > > CALL BLUE BIRD THEY TOLD ME THEY NO LONGER HAD THE PART. THEY SAID > > JOHN BLECKLEY MOTORS (MACON GA)HAD A REPLACEMENT.THIS DEALER SELLS > AND > > WORKS ON A LOT OF BB, I CALL THE PARTS DEPARTMENT AND SPOKE TO > RUSSELL > > ( 1-877-456-3700) RUSSELL SAYS THEY HAVE ONE THAT WILL REPLACE > THE > > ORGINIAL ONE. THAT YOU MOUNT IT SOMEWHERE ON THE CHASSIS AND RUN > AN > > AIR LINE TO THE ORGINIAL FITTING ON THE BIRD AND CONNECT ONE OF > THE > > ORGINAL AIR LINES TO THE CRUISE TO IT. IT HAS A 12 SOLENIOD SO IF > ITS > > WIRED CORRECTLY IT WILL SHUT OFF WHEN THE KEY SWITCH IS TURNED OFF. > ( I > > DON'T THINK THE FITTING WILL LEAK AIR BELOW 75 PSI ANYWAY) > > IT COST ABOUT $134.00.PLEASE UNDERSTAND I HAVE NOT USE ONE OR > > INSTALLED I AM GOING BY WHAT RUSSELL HAS RELAYED TO ME > > HOPE THIS IS GOOD INFO, IF ANYONE BUYS ONE AND INSTALLS LET ME > KNOW. > > > > RE BRAKE FC-35 SB "SAGECOACH" > > > > > > CRUISE CONTROL-VACUUM CONTROL - Stephen Birtles - 11-30-2006 13:55 R.E. go to http://www.rostra.com/cruise-control.htm you may also want to look at http://www.cruisecontrolking.com/ Iam a dealer for cruise king its a heavy duty unit Stephen 77fc35 --- In WanderlodgeForum@yahoogroups.com, > > I have not heard of the Rostra system, where can i find out about it, any idea od the cost and who installs dealer or owner > thanks > re brake 198 FC-35 sb > > > > > > From: "davidkerryedwards" > > Date: 2006/11/30 Thu PM 03:51:58 EST > > To: WanderlodgeForum@yahoogroups.com > > Subject: [WanderlodgeForum] Re: CRUISE CONTROL-VACUUM CONTROL > > > > Thanks for that info. I'm surprised Bluebird did not tell me that > > when I called and asked them about the vacuum generator about 8 > > weeks ago. However, at that price, it's probably just as good to > > install the Rostra electric cruise control since my vacuum cruise > > control wasn't that great to begin with. > > > > Kerry > > 82 FC 35 > > Denver > > > > > > --- In WanderlodgeForum@yahoogroups.com, "putneyflash" > > > > > > > > HEY GANG: THERE HAS BEEN A LOT OF DISCUSSION CONCERNING THE VACUUM > > > CONTROL ON OLD BIRDS THAT WAS LOCATED BEHIND THE FRONT BUMPER. > > WHEN I > > > CALL BLUE BIRD THEY TOLD ME THEY NO LONGER HAD THE PART. THEY SAID > > > JOHN BLECKLEY MOTORS (MACON GA)HAD A REPLACEMENT.THIS DEALER SELLS > > AND > > > WORKS ON A LOT OF BB, I CALL THE PARTS DEPARTMENT AND SPOKE TO > > RUSSELL > > > ( 1-877-456-3700) RUSSELL SAYS THEY HAVE ONE THAT WILL REPLACE > > THE > > > ORGINIAL ONE. THAT YOU MOUNT IT SOMEWHERE ON THE CHASSIS AND RUN > > AN > > > AIR LINE TO THE ORGINIAL FITTING ON THE BIRD AND CONNECT ONE OF > > THE > > > ORGINAL AIR LINES TO THE CRUISE TO IT. IT HAS A 12 SOLENIOD SO IF > > ITS > > > WIRED CORRECTLY IT WILL SHUT OFF WHEN THE KEY SWITCH IS TURNED OFF. > > ( I > > > DON'T THINK THE FITTING WILL LEAK AIR BELOW 75 PSI ANYWAY) > > > IT COST ABOUT $134.00.PLEASE UNDERSTAND I HAVE NOT USE ONE OR > > > INSTALLED I AM GOING BY WHAT RUSSELL HAS RELAYED TO ME > > > HOPE THIS IS GOOD INFO, IF ANYONE BUYS ONE AND INSTALLS LET ME > > KNOW. > > > > > > RE BRAKE FC-35 SB "SAGECOACH" > > > > > > > > > > > > CRUISE CONTROL-VACUUM CONTROL - davidkerryedwards - 11-30-2006 14:21 http://www.rostra.com/cc-250-1223.asp I bought one recently and have yet to install it. Less than $200 and uses the existing stalk switch and speed sensor. Someone on the forum has installed one and was happy with it. He offered to give me advice when I install mine but I haven't gotten around to it yet.My existing vacuum system would periodically cut out for no reason and it was hard to get it to set at the speed I wanted, so the Rostra looked like a good substitute. Kerry 82 FC 35 Denver --- In WanderlodgeForum@yahoogroups.com, > > I have not heard of the Rostra system, where can i find out about it, any idea od the cost and who installs dealer or owner > thanks > re brake 198 FC-35 sb > >> > > CRUISE CONTROL-VACUUM CONTROL - putneyflash@...> - 12-01-2006 11:34 Please keep me posted that may be my next step re brake 1983 FC-35 sb, "sagecoach" > > From: "davidkerryedwards" > Date: 2006/11/30 Thu PM 09:21:22 EST > To: WanderlodgeForum@yahoogroups.com > Subject: [WanderlodgeForum] Re: CRUISE CONTROL-VACUUM CONTROL > > http://www.rostra.com/cc-250-1223.asp > I bought one recently and have yet to install it. Less than $200 and uses the existing stalk > switch and speed sensor. Someone on the forum has installed one and was happy with it. > He offered to give me advice when I install mine but I haven't gotten around to it yet.My > existing vacuum system would periodically cut out for no reason and it was hard to get it > to set at the speed I wanted, so the Rostra looked like a good substitute. > > Kerry > 82 FC 35 > Denver > > > --- In WanderlodgeForum@yahoogroups.com, > > > > I have not heard of the Rostra system, where can i find out about it, any idea od the cost > and who installs dealer or owner > > thanks > > re brake 198 FC-35 sb > > > >> > > > > > > > |
