FloorJack - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: FloorJack (/showthread.php?tid=3924) |
FloorJack - Gregory OConnor - 12-03-2006 03:38 I have a rolling 2 1/2 ton floor jack phobia. several years ago I bought a cheepo jack and used it to lift 1/2 of a 3 1/2 ton skidsteer. pumping the jack hydrolic fluid to fill the cylinder it felt spongey and the load would lift only little. As I attempted to pull the jack back out from under the tractor, I got hit in the face by the 3 pound round metal load cup that is Loosly fitted on the long arm end of the jack. I was lucky to only have a broken cheekbone, 16 stiches and a black eye. It turns out the spongeyness was air in the cylinder and I was compressing the air to over 3,000 psi. Remember to purge the air if you feel the same lifting problem. GregoryO'Connor |
