Ok, The Pekins stays... - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Ok, The Pekins stays... (/showthread.php?tid=3964) |
Ok, The Pekins stays... - doug_ngl - 12-07-2006 05:06 So I keep the Perkins, more $$$ for the convection microwave! Does the genset battery charge off of teh converters (when on shore power) and the cat charging system, or is it stand alone and only charges when the Perkins is running? Thanks for all the other input. Doug Engel. Gunnison, CO, 1981 FC35SB "Pokey" Ok, The Pekins stays... - Tom Warner - 12-07-2006 06:02 I believe the 1981 generator is like my 1982 FC35 generator and if so the generator battery gets its charge from a factory modification across the aux Battery solenoid that is located under the side steps attached to the inside frame rail. Across the solenoid is a 30 amp circuit breaker and a 30 amp diode that will then charge the battery whether the Cat engine is running or the generator is running and the chargers are doing it thru this same circuit. However with that said I found in my generator control box that the Kohler charging system was still inside the box and only had to be connected to then charge the generator battery whenever the generator was running. For some reason BB did not connect it. tom warner vernon center, ny 1985 PT 40 t 12:06 PM 12/7/2006, you wrote: >So I keep the Perkins, more $$$ for the convection microwave! Does the >genset battery charge off of teh converters (when on shore power) and >the cat charging system, or is it stand alone and only charges when the >Perkins is running? Thanks for all the other input. Doug Engel. >Gunnison, CO, 1981 FC35SB "Pokey" > Ok, The Pekins stays... - Jeff Miller - 12-07-2006 08:27 I believe that it originally charged through a resistor pack in the control box of the genset. This original setup doesn't work very well, many have been modified as Tom outlined, a better method. A stud-diode and self-resetting circuit-breaker is what BB used (in later models and PTs). - Jeff Miller in Holland, MI --- In WanderlodgeForum@yahoogroups.com, "doug_ngl" wrote: > > So I keep the Perkins, more $$$ for the convection microwave! Does the > genset battery charge off of teh converters (when on shore power) and > the cat charging system, or is it stand alone and only charges when the > Perkins is running? Thanks for all the other input. Doug Engel. > Gunnison, CO, 1981 FC35SB "Pokey" > |
