glow plugs + temperature gun ? - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: glow plugs + temperature gun ? (/showthread.php?tid=3965) |
glow plugs + temperature gun ? - erniecarpet@... - 12-07-2006 05:00 Hi Bob- I bet Carol would be more then willing to shoot those plugs out in the cold.!!! ~ Ernie-83PT40 inTexas-- no glow plugs needed today [Non-text portions of this message have been removed] glow plugs + temperature gun ? - erniecarpet@... - 12-07-2006 07:03 When I was trying to start my generator in the frozen Livingston, Mt- the voltage would drop like a rock. Glad Tom suggested tying the batteries together and after quite a few tries- she fired off, killing anything that was flying in the vicinity of all the exhaust smoke. Ernie-83PT40 in texas [Non-text portions of this message have been removed] glow plugs + temperature gun ? - Bob & Carol Howald` - 12-07-2006 08:46 Can you get a basic clue as to weather or not the plugs are working by holding the glow plug switch and having someone shoot them with a temp. gun? Bob 93pt IL. glow plugs + temperature gun ? - davidkerryedwards - 12-07-2006 09:01 I've tried it. It does work but the block absorbs so much heat it is hard to get a clear indication of working/not working. It is a rough estimate but not ultimately reliable. Kerry 82 FC35 Denver --- In WanderlodgeForum@yahoogroups.com, "Bob & Carol Howald`" > > Can you get a basic clue as to weather or not the plugs are working by > holding the glow plug switch and having someone shoot them with a temp. > gun? Bob 93pt IL. > glow plugs + temperature gun ? - Tom Warner - 12-07-2006 10:09 Ernie tell them what worked for you when you had to start yours in the COLD!!! tom warner vernon center,ny 1985 PT 40 .working on the hot water heater which is a BEAR to do At 05:00 PM 12/7/2006, you wrote: >Hi Bob- I bet Carol would be more then willing to shoot those plugs out in >the cold.!!! ~ Ernie-83PT40 inTexas-- no glow plugs needed today > > >[Non-text portions of this message have been removed] > > > > >Yahoo! Groups Links > > > glow plugs + temperature gun ? - Jeff Miller - 12-07-2006 10:40 Easier to watch the generator battery voltmeter, it should drop slightly when the stop button is held down, raise up when released. - Jeff Miller in Holland, MI --- In WanderlodgeForum@yahoogroups.com, "Bob & Carol Howald`" > > Can you get a basic clue as to weather or not the plugs are working by > holding the glow plug switch and having someone shoot them with a temp. > gun? Bob 93pt IL. > glow plugs + temperature gun ? - one_dusty_hoot - 12-07-2006 11:03 Haven't tried to see if the temp gun would work and I believe the answer previously given would be the results, so much mass surrounding the glow plug. What could be done however is to series the total glow plug load with an ampmeter, full-scale maybe 50 Amps, located near the genset. Then, with good glow plugs, see what the current reading is on pre-heat, make a mark on the guage of that reading. This is normal, lower, glow plugs are not effective, higher, one has shorted. Hmmm, I might do this. Guess you fella's know that hitting the glow plugs then instead of hitting the starter, wait 15 seconds, then pre-heat again, then the start, the diesel will kick over quicker. Sometimes on other diesels I have done this 3 times before hitting start. bob janes, '87fc35, greenville, sc --- In WanderlodgeForum@yahoogroups.com, "Bob & Carol Howald`" > > Can you get a basic clue as to weather or not the plugs are working by > holding the glow plug switch and having someone shoot them with a temp. > gun? Bob 93pt IL. > |
