Update on loss of Turbo Boost and check Transmission light - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Update on loss of Turbo Boost and check Transmission light (/showthread.php?tid=3971) |
Update on loss of Turbo Boost and check Transmission light - Julia Bonser - 12-07-2006 15:44 We arrived in front of Stewart and Stevenson at 10 p.m. last night. They said they would take a preliminary look today. From our description of the problem and what work had been done they thought that the issue was on the engine side of the equation. What they found was the air filter was full. Now they are trying to locate a filter to fit. They have phoned Bluebird but did not get an answer today. He hoped for a call back tomorrow. After they put in the air filter they will test the system to see if the problem is resolved. Now it really is aggravating to have to pay 3 shops to troubleshoot a problem when the first shop should have found the problem. United Engines in Oklahoma City told us that we had about 50% left on our air filter. They were wrong and consequently we had a transmission shop try to find the problem. I guess it is a good thing to have all our ground connections made secure but it was not the cause. So does Bluebird work on Friday. Does anyone know what air filter the 1992 WLWB 40' PT 8V92 uses? If S & S can obtain a filter we could possibly be on our way to our winter abode. Thanks for all the advice and support. The camaraderie of these lists is truly wonderful. Julie Bonser 1992 WLWB PT 40' El Paso, TX Update on loss of Turbo Boost and check Transmission light - Tom Warner - 12-07-2006 15:58 Julie if I were in your place I would immediately contact both shops for a 100% refund once you get the bill. If you have the number off the old filter go to this site and plug it in with no dashes. http://www.wixfilters.com/filterlookup/index.asp then go to http://www.filter1.com and get the phone number and the chances are they will have one in stock. tom warner vernon center,ny 1985 PT 40 At 10:44 PM 12/7/2006, you wrote: >We arrived in front of Stewart and Stevenson at 10 p.m. last night. >They said they would take a preliminary look today. From our >description of the problem and what work had been done they thought >that the issue was on the engine side of the equation. What they >found was the air filter was full. Now they are trying to locate a >filter to fit. They have phoned Bluebird but did not get an answer >today. He hoped for a call back tomorrow. > >After they put in the air filter they will test the system to see if >the problem is resolved. Now it really is aggravating to have to pay >3 shops to troubleshoot a problem when the first shop should have >found the problem. United Engines in Oklahoma City told us that we >had about 50% left on our air filter. They were wrong and >consequently we had a transmission shop try to find the problem. I >guess it is a good thing to have all our ground connections made >secure but it was not the cause. > >So does Bluebird work on Friday. Does anyone know what air filter the >1992 WLWB 40' PT 8V92 uses? >If S & S can obtain a filter we could possibly be on our way to our >winter abode. > > Thanks for all the advice and support. The camaraderie of these >lists is truly wonderful. > >Julie Bonser >1992 WLWB PT 40' >El Paso, TX > > > > > >Yahoo! Groups Links > > > Update on loss of Turbo Boost and check Transmission light - davidkerryedwards - 12-07-2006 15:59 Glad the source of the problem has been found. Had a similar situation myself this summer. A couple of conditions had coordinated to plug the filter. Is there a number on the existing filter? It took a couple of days to get a filter shipped to us thru NAPA. Hope they can find yours faster. Kerry 82 FC 35 Denver --- In WanderlodgeForum@yahoogroups.com, Julia Bonser > > We arrived in front of Stewart and Stevenson at 10 p.m. last night. > They said they would take a preliminary look today. From our > description of the problem and what work had been done they thought > that the issue was on the engine side of the equation. What they > found was the air filter was full. Now they are trying to locate a > filter to fit. They have phoned Bluebird but did not get an answer > today. He hoped for a call back tomorrow. > > After they put in the air filter they will test the system to see if > the problem is resolved. Now it really is aggravating to have to pay > 3 shops to troubleshoot a problem when the first shop should have > found the problem. United Engines in Oklahoma City told us that we > had about 50% left on our air filter. They were wrong and > consequently we had a transmission shop try to find the problem. I > guess it is a good thing to have all our ground connections made > secure but it was not the cause. > > So does Bluebird work on Friday. Does anyone know what air filter the > 1992 WLWB 40' PT 8V92 uses? > If S & S can obtain a filter we could possibly be on our way to our > winter abode. > > Thanks for all the advice and support. The camaraderie of these > lists is truly wonderful. > > Julie Bonser > 1992 WLWB PT 40' > El Paso, TX > Update on loss of Turbo Boost and check Transmission light - adieu2y - 12-07-2006 16:11 --- In WanderlodgeForum@yahoogroups.com, Julia Bonser We're interested in air filters too. We checked our indicator yesterday and found our BB needed a new one. We leave Co. for Mi. tomorrow. The rv dealer looked all over Denver and east to where ever. He found a Parker Hannifin filter (factory spec)in Ga. What gives? You'd think an air filter for a diesel engine would be readily availble. Jack VanDenBerg 05 Lxi Glenn, Mi wrote: > > We arrived in front of Stewart and Stevenson at 10 p.m. last night. > They said they would take a preliminary look today. From our > description of the problem and what work had been done they thought > that the issue was on the engine side of the equation. What they > found was the air filter was full. Now they are trying to locate a > filter to fit. They have phoned Bluebird but did not get an answer > today. He hoped for a call back tomorrow. > > After they put in the air filter they will test the system to see if > the problem is resolved. Now it really is aggravating to have to pay > 3 shops to troubleshoot a problem when the first shop should have > found the problem. United Engines in Oklahoma City told us that we > had about 50% left on our air filter. They were wrong and > consequently we had a transmission shop try to find the problem. I > guess it is a good thing to have all our ground connections made > secure but it was not the cause. > > So does Bluebird work on Friday. Does anyone know what air filter the > 1992 WLWB 40' PT 8V92 uses? > If S & S can obtain a filter we could possibly be on our way to our > winter abode. > > Thanks for all the advice and support. The camaraderie of these > lists is truly wonderful. > > Julie Bonser > 1992 WLWB PT 40' > El Paso, TX > Update on loss of Turbo Boost and check Transmission light - Rob Robinson - 12-07-2006 16:13 Thank you for keeping us all posted Julia. On 07/12/06, Julia Bonser > > We arrived in front of Stewart and Stevenson at 10 p.m. last night. > They said they would take a preliminary look today. From our > description of the problem and what work had been done they thought > that the issue was on the engine side of the equation. What they > found was the air filter was full. Now they are trying to locate a > filter to fit. They have phoned Bluebird but did not get an answer > today. He hoped for a call back tomorrow. > > After they put in the air filter they will test the system to see if > the problem is resolved. Now it really is aggravating to have to pay > 3 shops to troubleshoot a problem when the first shop should have > found the problem. United Engines in Oklahoma City told us that we > had about 50% left on our air filter. They were wrong and > consequently we had a transmission shop try to find the problem. I > guess it is a good thing to have all our ground connections made > secure but it was not the cause. > > So does Bluebird work on Friday. Does anyone know what air filter the > 1992 WLWB 40' PT 8V92 uses? > If S & S can obtain a filter we could possibly be on our way to our > winter abode. > > Thanks for all the advice and support. The camaraderie of these > lists is truly wonderful. > > Julie Bonser > 1992 WLWB PT 40' > El Paso, TX > > > -- Rob, Sue & Merlin Robinson 94 WLWB [Non-text portions of this message have been removed] Update on loss of Turbo Boost and check Transmission light - Leroy Eckert - 12-07-2006 16:21 I had my coach serviced last Friday. I do not know if your air filter is the same as mine but I will give you the number off of my invoice. NAPA 2610 same day delivery $121.60 In any event NAPA should be able to match yours up. . Leroy Eckert 1990 WB-40 "Smoke N Mirrors" Niceville, FL 8v92 ----- Original Message ----- From: Julia Bonser To: WanderlodgeForum@yahoogroups.com ; Wanderlodge@yahoogroups.com Sent: Thursday, December 07, 2006 9:44 PM Subject: [WanderlodgeForum] Update on loss of Turbo Boost and check Transmission light We arrived in front of Stewart and Stevenson at 10 p.m. last night. They said they would take a preliminary look today. From our description of the problem and what work had been done they thought that the issue was on the engine side of the equation. What they found was the air filter was full. Now they are trying to locate a filter to fit. They have phoned Bluebird but did not get an answer today. He hoped for a call back tomorrow. After they put in the air filter they will test the system to see if the problem is resolved. Now it really is aggravating to have to pay 3 shops to troubleshoot a problem when the first shop should have found the problem. United Engines in Oklahoma City told us that we had about 50% left on our air filter. They were wrong and consequently we had a transmission shop try to find the problem. I guess it is a good thing to have all our ground connections made secure but it was not the cause. So does Bluebird work on Friday. Does anyone know what air filter the 1992 WLWB 40' PT 8V92 uses? If S & S can obtain a filter we could possibly be on our way to our winter abode. Thanks for all the advice and support. The camaraderie of these lists is truly wonderful. Julie Bonser 1992 WLWB PT 40' El Paso, TX [Non-text portions of this message have been removed] Update on loss of Turbo Boost and check Transmission light - David Brady - 12-07-2006 16:21 They're made to BB specs, consequently, it doesn't matter what Wanderlodge you have, getting the right filter is a pain. The best choice is thru BB. David Brady '02 LXi, Smokey Va adieu2y wrote: > --- In WanderlodgeForum@yahoogroups.com, Julia Bonser > We're interested in air filters too. We checked our indicator > yesterday and found our BB needed a new one. We leave Co. for Mi. > tomorrow. The rv dealer looked all over Denver and east to where > ever. He found a Parker Hannifin filter (factory spec)in Ga. > What gives? You'd think an air filter for a diesel engine would be > readily availble. Jack VanDenBerg 05 Lxi Glenn, Mi > wrote: > > > > > > Update on loss of Turbo Boost and check Transmission light - Julia Bonser - 12-07-2006 19:06 If we had a brain in our head after being tired and stressed we would have thought to look in our manuel. There it is on the first page "Service Parts Sheet." Farr #99842-004B Then on the back of the sheet a previous owner wrote down that it was also Donaldson P12 9396 which apparently the NAPA 2610 corresponds. I will give the information to the shop manager first thing tomorrow morning. Julie Bonser 1992 WLWB PT 40' El Paso, TX On Dec 7, 2006, at 9:21 PM, Leroy Eckert wrote: > I had my coach serviced last Friday. I do not know if your air > filter is the same as mine but I will give you the number off of my > invoice. NAPA 2610 same day delivery $121.60 > > In any event NAPA should be able to match yours up. > . > Leroy Eckert > 1990 WB-40 "Smoke N Mirrors" > Niceville, FL > 8v92 > > > > > > > ----- Original Message ----- > From: Julia Bonser > To: WanderlodgeForum@yahoogroups.com ; Wanderlodge@yahoogroups.com > Sent: Thursday, December 07, 2006 9:44 PM > Subject: [WanderlodgeForum] Update on loss of Turbo Boost and > check Transmission light > > > We arrived in front of Stewart and Stevenson at 10 p.m. last night. > They said they would take a preliminary look today. From our > description of the problem and what work had been done they thought > that the issue was on the engine side of the equation. What they > found was the air filter was full. Now they are trying to locate a > filter to fit. They have phoned Bluebird but did not get an answer > today. He hoped for a call back tomorrow. > > After they put in the air filter they will test the system to see if > the problem is resolved. Now it really is aggravating to have to pay > 3 shops to troubleshoot a problem when the first shop should have > found the problem. United Engines in Oklahoma City told us that we > had about 50% left on our air filter. They were wrong and > consequently we had a transmission shop try to find the problem. I > guess it is a good thing to have all our ground connections made > secure but it was not the cause. > > So does Bluebird work on Friday. Does anyone know what air filter > the > 1992 WLWB 40' PT 8V92 uses? > If S & S can obtain a filter we could possibly be on our way to our > winter abode. > > Thanks for all the advice and support. The camaraderie of these > lists is truly wonderful. > > Julie Bonser > 1992 WLWB PT 40' > El Paso, TX > > > > > > [Non-text portions of this message have been removed] > > > > > Yahoo! Groups Links > > > Update on loss of Turbo Boost and check Transmission light - David Brady - 12-08-2006 00:27 Thanks Tom, I was incorrect. Please disregard my previous post on air filters made to BB specs. This is true of the LXi, but not for all BB's. David Brady '02 LXi, Smokey Va Tom Warner wrote: > David I dont agree. I get all of my filters from http://www.filter1.com. > They have a 1-800 number and free shipping over $50. I have never yet > failed to get a filter from them even for my 21 year old german diesel > tractor and all of the filters for my 6V92. > > . > > tom > > At 11:21 PM 12/7/2006, you wrote: >> made to BB specs, consequently, it doesn't matter >> what Wanderlodge you have, getting the right filter is a pain. >> The best choice is thru BB. >> >> David Brady >> '02 LXi, Smokey >> Va > > > > Update on loss of Turbo Boost and check Transmission light - ronmarabito2002 - 12-08-2006 03:48 Tom: You are jumping the gun here with a call for 100% refund from shops. Perhaps the first one, which falsely gave the Bonsers a clear slate on the filter. Industrial Automatic was diagnosing a transmission code showing low voltage to a throttle sensor. There was no engine fault code. They did recommend taking it to an engine outfit and that ended up being Stewart & Stevenson who diagnosed the problem. It is unfortunate that all shops are not capable in dealing with all the problems encountered with these rigs. Most of these problems end up being a result of poor preventative maintenance, which is often caused by poor record keeping and things are left undone until they fail. R.E. (Ron) Marabito, Dallas, tX 92WB40 --- In WanderlodgeForum@yahoogroups.com, Tom Warner > > Julie if I were in your place I would immediately contact both shops > for a 100% refund once you get the bill. If you have the number off > the old filter go to this site and plug it in with no > dashes. http://www.wixfilters.com/filterlookup/index.asp then go > to http://www.filter1.com and get the phone number and the chances are they > will have one in stock. > > tom warner > vernon center,ny > 1985 PT 40 > > > At 10:44 PM 12/7/2006, you wrote: > >We arrived in front of Stewart and Stevenson at 10 p.m. last night. > >They said they would take a preliminary look today. From our > >description of the problem and what work had been done they thought > >that the issue was on the engine side of the equation. What they > >found was the air filter was full. Now they are trying to locate a > >filter to fit. They have phoned Bluebird but did not get an answer > >today. He hoped for a call back tomorrow. > > > >After they put in the air filter they will test the system to see if > >the problem is resolved. Now it really is aggravating to have to pay > >3 shops to troubleshoot a problem when the first shop should have > >found the problem. United Engines in Oklahoma City told us that we > >had about 50% left on our air filter. They were wrong and > >consequently we had a transmission shop try to find the problem. I > >guess it is a good thing to have all our ground connections made > >secure but it was not the cause. > > > >So does Bluebird work on Friday. Does anyone know what air filter the > >1992 WLWB 40' PT 8V92 uses? > >If S & S can obtain a filter we could possibly be on our way to our > >winter abode. > > > > Thanks for all the advice and support. The camaraderie of these > >lists is truly wonderful. > > > >Julie Bonser > >1992 WLWB PT 40' > >El Paso, TX > > > > > > > > > > > >Yahoo! Groups Links > > > > > > > |
