ULSD - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: ULSD (/showthread.php?tid=3975) |
ULSD - williamcharrison - 12-08-2006 06:25 For what it is worth, I visited the gov. sponsored web site http://www.clean-diesel to see what they had to say about additives required to maintain lubricity and saw the following: Q. Will I need to put an additive in my fuel tank to replace the lubricity that was provided by the higher sulfur content? A. Like Low Sulfur Diesel fuel, ULSD fuel requires good lubricity and corrosion inhibitors to prevent unacceptable engine wear. As necessary, additives to increase lubricity and to inhibit corrosion will be added to ULSD fuel prior to its retail sale. With these additives, ULSD fuel is expected to perform as well as Low Sulfur Diesel fuel. Q. Will ULSD fuel affect the performance of my vehicle? A. Engine and vehicle manufacturers expect ULSD fuel to be fully compatible with the existing fleet, including 2006 and earlier model year vehicles. In some instances, the introduction of ULSD fuel to older vehicles may affect fuel system components or loosen deposits in fuel tanks. As part of a good maintenance program, owners and operators of existing cars, trucks and buses are encouraged to monitor their diesel-powered vehicles closely for potential fuel system leaks or premature fuel filter plugging during the change- over to ULSD fuel. I hope this does not just add to the controversy. Chuck Harrison 90SP36 Akron, Ohio ULSD - Jeff Miller - 12-08-2006 10:33 This is the most clear and neutral information that I've found so far (cut and past if you need to): <http://www.nrc.gov/reading-rm/doc-collections/gen-comm/info- notices/2006/in200622.pdf> - Jeff Miller in Holland, MI --- In WanderlodgeForum@yahoogroups.com, "williamcharrison" > > For what it is worth, I visited the gov. sponsored web site > http://www.clean-diesel to see what they had to say about additives > required to maintain lubricity and saw the following: > > Q. Will I need to put an additive in my fuel tank to replace the > lubricity that was provided by the higher sulfur content? > > A. Like Low Sulfur Diesel fuel, ULSD fuel requires good lubricity > and corrosion inhibitors to prevent unacceptable engine wear. As > necessary, additives to increase lubricity and to inhibit corrosion > will be added to ULSD fuel prior to its retail sale. With these > additives, ULSD fuel is expected to perform as well as Low Sulfur > Diesel fuel. > > Q. Will ULSD fuel affect the performance of my vehicle? > > A. Engine and vehicle manufacturers expect ULSD fuel to be fully > compatible with the existing fleet, including 2006 and earlier model > year vehicles. In some instances, the introduction of ULSD fuel to > older vehicles may affect fuel system components or loosen deposits > in fuel tanks. As part of a good maintenance program, owners and > operators of existing cars, trucks and buses are encouraged to > monitor their diesel-powered vehicles closely for potential fuel > system leaks or premature fuel filter plugging during the change- > over to ULSD fuel. > > I hope this does not just add to the controversy. > > Chuck Harrison > 90SP36 > Akron, Ohio > ULSD - Gregory OConnor - 12-08-2006 11:07 Chuck, The hype was started by those companies selling the additives. I buy 700 to 1,200 gallons of diesel a month and dont plan on doing anything other than dumping ATF in the mix as I always did. My 3208 trucks (now replaced) all had over 300,000 miles and Injection pumps were rebuilt several times even with the old fuel. Folks are gonna blame necessary repairs of fuel systems to the new formula. In place of buying $240.00 worth of additive a month I am going to sit it out and just save for an upgrade seal replacement rebuild of the pump. If the pump fails in 8 months and cost less than $2,000, I'm good. If not, I'll let you know. Rebuild Injection pump, run rack, adjust valves on a 3208 cost me $1300 in 1999. Gregory O'Connor 94ptRomolandca --- In WanderlodgeForum@yahoogroups.com, "williamcharrison" > > For what it is worth, I visited the gov. sponsored web site > http://www.clean-diesel to see what they had to say about additives > required to maintain lubricity and saw the following: > > Q. Will I need to put an additive in my fuel tank to replace the > lubricity that was provided by the higher sulfur content? > > A. Like Low Sulfur Diesel fuel, ULSD fuel requires good lubricity > and corrosion inhibitors to prevent unacceptable engine wear. As > necessary, additives to increase lubricity and to inhibit corrosion > will be added to ULSD fuel prior to its retail sale. With these > additives, ULSD fuel is expected to perform as well as Low Sulfur > Diesel fuel. > > Q. Will ULSD fuel affect the performance of my vehicle? > > A. Engine and vehicle manufacturers expect ULSD fuel to be fully > compatible with the existing fleet, including 2006 and earlier model > year vehicles. In some instances, the introduction of ULSD fuel to > older vehicles may affect fuel system components or loosen deposits > in fuel tanks. As part of a good maintenance program, owners and > operators of existing cars, trucks and buses are encouraged to > monitor their diesel-powered vehicles closely for potential fuel > system leaks or premature fuel filter plugging during the change- > over to ULSD fuel. > > I hope this does not just add to the controversy. > > Chuck Harrison > 90SP36 > Akron, Ohio > ULSD - Mike Hohnstein - 12-08-2006 14:05 A lot of consumer types think a diesel will "live forever", and on and on it goes. There is a real good reason I am the proud owner of a pretty nice Airstream 345 P 30 454 GAS engine motorhome. It has a whole lot to do with the fuel situation these days, don't think it is going to be cool for a while. Not ready to lose my diesel yet but it might get to a point of diminishing returns if the "greens" and the yahoos from Sacramento keep it up. MH ----- Original Message ----- From: Gregory OConnor To: WanderlodgeForum@yahoogroups.com Sent: Friday, December 08, 2006 5:07 PM Subject: [WanderlodgeForum] Re: ULSD Chuck, The hype was started by those companies selling the additives. I buy 700 to 1,200 gallons of diesel a month and dont plan on doing anything other than dumping ATF in the mix as I always did. My 3208 trucks (now replaced) all had over 300,000 miles and Injection pumps were rebuilt several times even with the old fuel. Folks are gonna blame necessary repairs of fuel systems to the new formula. In place of buying $240.00 worth of additive a month I am going to sit it out and just save for an upgrade seal replacement rebuild of the pump. If the pump fails in 8 months and cost less than $2,000, I'm good. If not, I'll let you know. Rebuild Injection pump, run rack, adjust valves on a 3208 cost me $1300 in 1999. Gregory O'Connor 94ptRomolandca --- In WanderlodgeForum@yahoogroups.com, "williamcharrison" > > For what it is worth, I visited the gov. sponsored web site > http://www.clean-diesel to see what they had to say about additives > required to maintain lubricity and saw the following: > > Q. Will I need to put an additive in my fuel tank to replace the > lubricity that was provided by the higher sulfur content? > > A. Like Low Sulfur Diesel fuel, ULSD fuel requires good lubricity > and corrosion inhibitors to prevent unacceptable engine wear. As > necessary, additives to increase lubricity and to inhibit corrosion > will be added to ULSD fuel prior to its retail sale. With these > additives, ULSD fuel is expected to perform as well as Low Sulfur > Diesel fuel. > > Q. Will ULSD fuel affect the performance of my vehicle? > > A. Engine and vehicle manufacturers expect ULSD fuel to be fully > compatible with the existing fleet, including 2006 and earlier model > year vehicles. In some instances, the introduction of ULSD fuel to > older vehicles may affect fuel system components or loosen deposits > in fuel tanks. As part of a good maintenance program, owners and > operators of existing cars, trucks and buses are encouraged to > monitor their diesel-powered vehicles closely for potential fuel > system leaks or premature fuel filter plugging during the change- > over to ULSD fuel. > > I hope this does not just add to the controversy. > > Chuck Harrison > 90SP36 > Akron, Ohio > [Non-text portions of this message have been removed] |
