3208 NA rpm - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: 3208 NA rpm (/showthread.php?tid=3989) |
3208 NA rpm - Gardner Yeaw - 12-11-2006 13:58 What is the top rpm of a 3208 NA in a Bluebird. My '78 peaks about 25 or 2600. I can put the trany in 3rd and take it to the top speed and it stops at 2500 and doesn't shift, so the trans doesn't register an over speed. Is this normal, or is the high idle or throttle linkage in need of adjustment? I thought the top RPM was closer to 3000. Gardner 78FC33 3208 NA rpm - Mike Hohnstein - 12-11-2006 14:49 3050 is enough for a NA. Low side of the scale is 1900, it will live longer if you cruise at 2400/2600. Some will say it's OK to run on the governor, but it ain't so. Valves tend to fall into the cylinders. You need to verify the throttle is all the way open, don't sound like it is. MH ----- Original Message ----- From: Gardner Yeaw To: WanderlodgeForum@yahoogroups.com Sent: Monday, December 11, 2006 7:58 PM Subject: [WanderlodgeForum] 3208 NA rpm What is the top rpm of a 3208 NA in a Bluebird. My '78 peaks about 25 or 2600. I can put the trany in 3rd and take it to the top speed and it stops at 2500 and doesn't shift, so the trans doesn't register an over speed. Is this normal, or is the high idle or throttle linkage in need of adjustment? I thought the top RPM was closer to 3000. Gardner 78FC33 [Non-text portions of this message have been removed] 3208 NA rpm - davidkerryedwards - 12-11-2006 15:12 3208NA is typically governed at 2800rpm. You should have a couple of hundred more rpm's somwhere. Kerry 82 Fc 35 Denver --- In WanderlodgeForum@yahoogroups.com, "Gardner Yeaw" > > What is the top rpm of a 3208 NA in a Bluebird. > My '78 peaks about 25 or 2600. I can put the trany in 3rd and take it > to the top speed and it stops at 2500 and doesn't shift, so the trans > doesn't register an over speed. Is this normal, or is the high idle or > throttle linkage in need of adjustment? I thought the top RPM was > closer to 3000. > > Gardner > 78FC33 > |
