Carpet around the Steering column - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Carpet around the Steering column (/showthread.php?tid=4012) |
Carpet around the Steering column - Chuck Wheeler - 12-16-2006 02:26 The top seal is bad on the power steering unit on our 82 FC. I have removed the shroud around the steering and started to pull back the carpet and mat. The carpet appears to go under the pedestal for the phone. Does the pedestal remove or should I just cut the carpet? I'm not actually going to do the replacement of the unit, but I didn't see any reason to pay shop time for them to get at it. - Chuck Wheeler - 82 FC 31 SB Fort Worth, TX [Non-text portions of this message have been removed] Carpet around the Steering column - davidkerryedwards - 12-16-2006 03:22 I just did this on my 82 since I'm working on the power steering. Are you sure it is not the return hose? Mine was leaking right there where it attaches to the box. I don't know what you mean by the pedestal for the phone, since I don't have one, but I just removed the cover around the steering shaft, unbolted the accelerator and peeled back the carpet and underlayment, then removed the cover at the steering box. Have them check the return hose while they are in there. Mine was in extremely bad condition. Kerry 82 FC 35 Denver --- In WanderlodgeForum@yahoogroups.com, "Chuck Wheeler" > > The top seal is bad on the power steering unit on our 82 FC. I have removed > the shroud around the steering and started to pull back the carpet and mat. > The carpet appears to go under the pedestal for the phone. Does the > pedestal remove or should I just cut the carpet? I'm not actually going to > do the replacement of the unit, but I didn't see any reason to pay shop time > for them to get at it. > > - Chuck Wheeler - > 82 FC 31 SB > Fort Worth, TX > > > [Non-text portions of this message have been removed] > Carpet around the Steering column - Chuck Wheeler - 12-17-2006 15:26 David, I wish it was just a hose! When I found the oil coming from the steering shaft I disconnected the shaft from the steering wheel to see if it was a seal that can be changed from the outside. (We used to do that on Freightliners) The steering input shaft moves side to side and in and out and that is what took the seal out. Something is really bad on the inside! - Chuck Wheeler - 82 FC 31 SB Fort Worth, TX _____ From: WanderlodgeForum@yahoogroups.com [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of davidkerryedwards Sent: Saturday, December 16, 2006 9:22 AM To: WanderlodgeForum@yahoogroups.com Subject: [WanderlodgeForum] Re: Carpet around the Steering column I just did this on my 82 since I'm working on the power steering. Are you sure it is not the return hose? Mine was leaking right there where it attaches to the box. I don't know what you mean by the pedestal for the phone, since I don't have one, but I just removed the cover around the steering shaft, unbolted the accelerator and peeled back the carpet and underlayment, then removed the cover at the steering box. Have them check the return hose while they are in there. Mine was in extremely bad condition. Kerry 82 FC 35 Denver --- In WanderlodgeForum@ yahoogroups.com, "Chuck Wheeler" > > The top seal is bad on the power steering unit on our 82 FC. I have removed > the shroud around the steering and started to pull back the carpet and mat. > The carpet appears to go under the pedestal for the phone. Does the > pedestal remove or should I just cut the carpet? I'm not actually going to > do the replacement of the unit, but I didn't see any reason to pay shop time > for them to get at it. > > - Chuck Wheeler - > 82 FC 31 SB > Fort Worth, TX > > > [Non-text portions of this message have been removed] > [Non-text portions of this message have been removed] |
