HWH Control manifold rebuild - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: HWH Control manifold rebuild (/showthread.php?tid=4086) |
HWH Control manifold rebuild - erniecarpet@... - 12-31-2006 03:38 Ralph, I replaced the actuator on my forward jack. While getting the actuator off is realtively easy. remounting is tough as the supplied clamps are very tight to get everything to work correctly. We used large worm drive clamps to position it and then tightened it down with the factory clamps. Once we figured out that procedure, it went as planned. Ernie Ekberg 83PT40 Weatherford, tx [Non-text portions of this message have been removed] HWH Control manifold rebuild - Ralph L. Fullenwider - 12-31-2006 04:50 Good morning everyone: The rebuild of the HWH control manifold went well, no more leaks there. We now have 3 out of 4 leveling jacks. I have a leak between the kick down cylinder and the jack cylinder on one. Have not had this off in the past, so am delving into something new. Looks like the leak is in the upper port where the small kick down cylinder joins the jack. Anyone been there? Does it screw in or is it a press fit with o'rings? Last day of this year, and Bird's from Coast to Coast are starting off 2007 with a bang!!! Safe travels, Ralph and Charolette Fullenwider 84FC35 Ralph's RV Solutions, Duncan, Oklahoma HWH Control manifold rebuild - Curt Sprenger - 12-31-2006 05:37 Ralph, Is the jack the same type as the front swing down jacks on our '87 PT38? I've replaced the swing down Actuator on one. It's two o-rings, one top and one bottom, press fit. Yup, last day of the year. Happy New Year to all. Curt Sprenger 1987 PT38 8V92 "MacAttack Racing" Anaheim Hills, Calif. Ralph L. Fullenwider wrote: >Good morning everyone: > >The rebuild of the HWH control manifold went well, no more leaks there. We >now have 3 out of 4 leveling jacks. I have a leak between the kick down >cylinder and the jack cylinder on one. Have not had this off in the past, >so am delving into something new. Looks like the leak is in the upper port >where the small kick down cylinder joins the jack. Anyone been there? Does >it screw in or is it a press fit with o'rings? > >Last day of this year, and Bird's from Coast to Coast are starting off 2007 >with a bang!!! > >Safe travels, > >Ralph and Charolette Fullenwider >84FC35 >Ralph's RV Solutions, Duncan, Oklahoma > > > > >Yahoo! Groups Links > > > > > > HWH Control manifold rebuild - Ralph L. Fullenwider - 12-31-2006 05:53 Hi Curt: Thank you, yes the same swing down type. Will replace the o'rings and give it a shot. Safe travels, Ralph and Charolette Fullenwider 84FC35 Ralph's RV Solutions, Duncan, Oklahoma At 09:37 AM 12/31/2006 -0800, you wrote: >Ralph, > >Is the jack the same type as the front swing down jacks on our '87 PT38? >I've replaced the swing down Actuator on one. It's two o-rings, one top >and one bottom, press fit. > >Yup, last day of the year. > >Happy New Year to all. > >Curt Sprenger >1987 PT38 8V92 "MacAttack Racing" >Anaheim Hills, Calif. > > > >Ralph L. Fullenwider wrote: > > >Good morning everyone: > > > >The rebuild of the HWH control manifold went well, no more leaks there. We > >now have 3 out of 4 leveling jacks. I have a leak between the kick down > >cylinder and the jack cylinder on one. Have not had this off in the past, > >so am delving into something new. Looks like the leak is in the upper port > >where the small kick down cylinder joins the jack. Anyone been there? Does > >it screw in or is it a press fit with o'rings? > > > >Last day of this year, and Bird's from Coast to Coast are starting off 2007 > >with a bang!!! > > > >Safe travels, > > > >Ralph and Charolette Fullenwider > >84FC35 > >Ralph's RV Solutions, Duncan, Oklahoma > > > HWH Control manifold rebuild - Curt Sprenger - 12-31-2006 06:16 Ralph, Before removing the actuator, try tightening the top clamp or both clamps. That might be all that is needed. When I replaced the actuator it took a couple tries to align and tighten properly to stop the o-rings from leaking. Curt Sprenger 1987 PT38 8V92 "MacAttack Racing" Anaheim Hills, Calif. Ralph L. Fullenwider wrote: >Hi Curt: > >Thank you, yes the same swing down type. Will replace the o'rings and give >it a shot. > >Safe travels, > >Ralph and Charolette Fullenwider >84FC35 >Ralph's RV Solutions, Duncan, Oklahoma > >At 09:37 AM 12/31/2006 -0800, you wrote: > > >>Ralph, >> >>Is the jack the same type as the front swing down jacks on our '87 PT38? >>I've replaced the swing down Actuator on one. It's two o-rings, one top >>and one bottom, press fit. >> >>Yup, last day of the year. >> >>Happy New Year to all. >> >>Curt Sprenger >>1987 PT38 8V92 "MacAttack Racing" >>Anaheim Hills, Calif. >> >> >> >>Ralph L. Fullenwider wrote: >> >> >> >>>Good morning everyone: >>> >>>The rebuild of the HWH control manifold went well, no more leaks there. We >>>now have 3 out of 4 leveling jacks. I have a leak between the kick down >>>cylinder and the jack cylinder on one. Have not had this off in the past, >>>so am delving into something new. Looks like the leak is in the upper port >>>where the small kick down cylinder joins the jack. Anyone been there? Does >>>it screw in or is it a press fit with o'rings? >>> >>>Last day of this year, and Bird's from Coast to Coast are starting off 2007 >>>with a bang!!! >>> >>>Safe travels, >>> >>>Ralph and Charolette Fullenwider >>>84FC35 >>>Ralph's RV Solutions, Duncan, Oklahoma >>> >>> >>> > > > > >Yahoo! Groups Links > > > > > > HWH Control manifold rebuild - Ralph L. Fullenwider - 12-31-2006 09:14 Thanks Ernie: Sounds like the plan. I will replace the o rings and go with it. That o'ring kit I bought on o of our "tool" runs is paying for it's self. Too cold today to get under (no name yet) to work on the air valves. Safe travels, Ralph and Charolette Fullenwider 84FC35 Ralph's RV Solutions, Duncan, Oklahoma At 03:38 PM 12/31/2006 -0500, you wrote: >Ralph, I replaced the actuator on my forward jack. While getting the >actuator off is realtively easy. remounting is tough as the supplied >clamps are very >tight to get everything to work correctly. We used large worm drive clamps >to position it and then tightened it down with the factory clamps. Once we >figured out that procedure, it went as planned. > >Ernie Ekberg >83PT40 >Weatherford, tx > > HWH Control manifold rebuild - dandarst - 01-02-2007 02:20 Yes Curt, I had the same problem. Put hose clamps on that tighten in the opposite direction to get the actuator twisted on the o-rings just right. I used a feeler guage to measure the clearance between the shoulder of the actuator and the body of the main cylinder to determine that the connection was approximately square. So far the 0- rings are not leaking. About a year ago on a cold day, deployed the RR jack and the pressure broke one of the hose clamps seperating the actuator from the main cylinder, big mess. dandarst86fc35rbhuntleyil. -- In WanderlodgeForum@yahoogroups.com, Curt Sprenger > > Ralph, > > Before removing the actuator, try tightening the top clamp or both > clamps. That might be all that is needed. When I replaced the actuator > it took a couple tries to align and tighten properly to stop the o- rings > from leaking. > > Curt Sprenger > 1987 PT38 8V92 "MacAttack Racing" > Anaheim Hills, Calif. > > > > Ralph L. Fullenwider wrote: > > >Hi Curt: > > > >Thank you, yes the same swing down type. Will replace the o'rings and give > >it a shot. > > > >Safe travels, > > > >Ralph and Charolette Fullenwider > >84FC35 > >Ralph's RV Solutions, Duncan, Oklahoma > > > >At 09:37 AM 12/31/2006 -0800, you wrote: > > > > > >>Ralph, > >> > >>Is the jack the same type as the front swing down jacks on our '87 PT38? > >>I've replaced the swing down Actuator on one. It's two o-rings, one top > >>and one bottom, press fit. > >> > >>Yup, last day of the year. > >> > >>Happy New Year to all. > >> > >>Curt Sprenger > >>1987 PT38 8V92 "MacAttack Racing" > >>Anaheim Hills, Calif. > >> > >> > >> > >>Ralph L. Fullenwider wrote: > >> > >> > >> > >>>Good morning everyone: > >>> > >>>The rebuild of the HWH control manifold went well, no more leaks there. We > >>>now have 3 out of 4 leveling jacks. I have a leak between the kick down > >>>cylinder and the jack cylinder on one. Have not had this off in the past, > >>>so am delving into something new. Looks like the leak is in the upper port > >>>where the small kick down cylinder joins the jack. Anyone been there? Does > >>>it screw in or is it a press fit with o'rings? > >>> > >>>Last day of this year, and Bird's from Coast to Coast are starting off 2007 > >>>with a bang!!! > >>> > >>>Safe travels, > >>> > >>>Ralph and Charolette Fullenwider > >>>84FC35 > >>>Ralph's RV Solutions, Duncan, Oklahoma > >>> > >>> > >>> > > > > > > > > > >Yahoo! Groups Links > > > > > > > > > > > > > HWH Control manifold rebuild - dandarst - 01-02-2007 02:22 Yes Curt, I had the same problem. Put hose clamps on that tighten in the opposite direction to get the actuator twisted on the o-rings just right. I used a feeler guage to measure the clearance between the shoulder of the actuator and the body of the main cylinder to determine that the connection was approximately square. So far the 0- rings are not leaking. About a year ago on a cold day, deployed the RR jack and the pressure broke one of the hose clamps seperating the actuator from the main cylinder, big mess. dandarst86fc35rbhuntleyil. -- In WanderlodgeForum@yahoogroups.com, Curt Sprenger > > Ralph, > > Before removing the actuator, try tightening the top clamp or both > clamps. That might be all that is needed. When I replaced the actuator > it took a couple tries to align and tighten properly to stop the o- rings > from leaking. > > Curt Sprenger > 1987 PT38 8V92 "MacAttack Racing" > Anaheim Hills, Calif. > > > > Ralph L. Fullenwider wrote: > > >Hi Curt: > > > >Thank you, yes the same swing down type. Will replace the o'rings and give > >it a shot. > > > >Safe travels, > > > >Ralph and Charolette Fullenwider > >84FC35 > >Ralph's RV Solutions, Duncan, Oklahoma > > > >At 09:37 AM 12/31/2006 -0800, you wrote: > > > > > >>Ralph, > >> > >>Is the jack the same type as the front swing down jacks on our '87 PT38? > >>I've replaced the swing down Actuator on one. It's two o-rings, one top > >>and one bottom, press fit. > >> > >>Yup, last day of the year. > >> > >>Happy New Year to all. > >> > >>Curt Sprenger > >>1987 PT38 8V92 "MacAttack Racing" > >>Anaheim Hills, Calif. > >> > >> > >> > >>Ralph L. Fullenwider wrote: > >> > >> > >> > >>>Good morning everyone: > >>> > >>>The rebuild of the HWH control manifold went well, no more leaks there. We > >>>now have 3 out of 4 leveling jacks. I have a leak between the kick down > >>>cylinder and the jack cylinder on one. Have not had this off in the past, > >>>so am delving into something new. Looks like the leak is in the upper port > >>>where the small kick down cylinder joins the jack. Anyone been there? Does > >>>it screw in or is it a press fit with o'rings? > >>> > >>>Last day of this year, and Bird's from Coast to Coast are starting off 2007 > >>>with a bang!!! > >>> > >>>Safe travels, > >>> > >>>Ralph and Charolette Fullenwider > >>>84FC35 > >>>Ralph's RV Solutions, Duncan, Oklahoma > >>> > >>> > >>> > > > > > > > > > >Yahoo! Groups Links > > > > > > > > > > > > > |
