Cat 3208TA (non ATAAC) ratings - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Cat 3208TA (non ATAAC) ratings (/showthread.php?tid=4148) |
Cat 3208TA (non ATAAC) ratings - Benjamin Edge - 01-12-2007 15:08 Hello, Does anyone know exactly the HP (@ RPM) and torque (lb-ft @ RPM) ratings for the 3208TA (non ATAAC) engines? There are versions rated 250 (don't confuse with the 3208T version) and 280 HP (presumably at 2600 RPM for both) and maybe even a 300 HP version (2800 RPM). Blue Bird used the 250 HP version in the 1985 and '86 model years of their Wanderlodge FC series motorhomes. ~Ben (bene71281) [Non-text portions of this message have been removed] Cat 3208TA (non ATAAC) ratings - birdshill123 - 01-13-2007 04:31 Ben: My Blue Box has the original Cat brochure on the ATAAC engine 300HP @2800, 743 lb. ft. of torque @ 1600, 1450 lbs. dry, approved for RV's up to 36,000 GVW. For all you owners of 250 HP 3208's there is one caveat: Brochure states: Not recommended for sustained, high mileage, on-highway use. Bruce 1988 FC35 "La Reina Gitana" Cat 3208TA (non ATAAC) ratings - Mike Hohnstein - 01-13-2007 04:47 That's why you keep an eye on the crank shaft bearings. MH ----- Original Message ----- From: birdshill123 To: WanderlodgeForum@yahoogroups.com Sent: Saturday, January 13, 2007 10:31 AM Subject: [WanderlodgeForum] Re: Cat 3208TA (non ATAAC) ratings Ben: My Blue Box has the original Cat brochure on the ATAAC engine 300HP @2800, 743 lb. ft. of torque @ 1600, 1450 lbs. dry, approved for RV's up to 36,000 GVW. For all you owners of 250 HP 3208's there is one caveat: Brochure states: Not recommended for sustained, high mileage, on-highway use. Bruce 1988 FC35 "La Reina Gitana" [Non-text portions of this message have been removed] Cat 3208TA (non ATAAC) ratings - dspithaler@... - 01-13-2007 12:39 Mike Will an oil analysis tell you the bearing condition or do you need to drop the pan? Don 89 SP 36' Butler, PA That's why you keep an eye on the crank shaft bearings. MH ----- Original Message ----- From: birdshill123 To: WanderlodgeForum@yahoogroups.com Sent: Saturday, January 13, 2007 10:31 AM Subject: [WanderlodgeForum] Re: Cat 3208TA (non ATAAC) ratings Ben: My Blue Box has the original Cat brochure on the ATAAC engine 300HP @2800, 743 lb. ft. of torque @ 1600, 1450 lbs. dry, approved for RV's up to 36,000 GVW. For all you owners of 250 HP 3208's there is one caveat: Brochure states: Not recommended for sustained, high mileage, on-highway use. Bruce 1988 FC35 "La Reina Gitana" [Non-text portions of this message have been removed] ________________________________________________________________________ Check out the new AOL. Most comprehensive set of free safety and security tools, free access to millions of high-quality videos from across the web, free AOL Mail and more. [Non-text portions of this message have been removed] Cat 3208TA (non ATAAC) ratings - Mike Hohnstein - 01-13-2007 12:49 Oil analysis is a good thing, keeps an eye on the head gaskets. I'm of the opinion that by the time analysis shows excess metal, it's too late. It's a better strategy to physically check the bearings at 100/125k miles. It's an easy job compared to dealing with a bearing failure. MH ----- Original Message ----- From: dspithaler@... To: WanderlodgeForum@yahoogroups.com Sent: Saturday, January 13, 2007 6:39 PM Subject: Re: [WanderlodgeForum] Re: Cat 3208TA (non ATAAC) ratings Mike Will an oil analysis tell you the bearing condition or do you need to drop the pan? Don 89 SP 36' Butler, PA That's why you keep an eye on the crank shaft bearings. MH ----- Original Message ----- From: birdshill123 To: WanderlodgeForum@yahoogroups.com Sent: Saturday, January 13, 2007 10:31 AM Subject: [WanderlodgeForum] Re: Cat 3208TA (non ATAAC) ratings Ben: My Blue Box has the original Cat brochure on the ATAAC engine 300HP @2800, 743 lb. ft. of torque @ 1600, 1450 lbs. dry, approved for RV's up to 36,000 GVW. For all you owners of 250 HP 3208's there is one caveat: Brochure states: Not recommended for sustained, high mileage, on-highway use. Bruce 1988 FC35 "La Reina Gitana" [Non-text portions of this message have been removed] __________________________________________________________ Check out the new AOL. Most comprehensive set of free safety and security tools, free access to millions of high-quality videos from across the web, free AOL Mail and more. [Non-text portions of this message have been removed] [Non-text portions of this message have been removed] Cat 3208TA (non ATAAC) ratings - dspithaler@... - 01-14-2007 14:33 Thanks Mike I'll keep that in mind next time in the shop. I'm still under 100K. Don 89 SP 36' Butler, PA At the Birds Nest on my way to FL -----Original Message----- From: MHOHNSTEIN@... To: WanderlodgeForum@yahoogroups.com Sent: Sat, 13 Jan 2007 7:49 PM Subject: Re: [WanderlodgeForum] Re: Cat 3208TA (non ATAAC) ratings Oil analysis is a good thing, keeps an eye on the head gaskets. I'm of the opinion that by the time analysis shows excess metal, it's too late. It's a better strategy to physically check the bearings at 100/125k miles. It's an easy job compared to dealing with a bearing failure. MH ----- Original Message ----- From: dspithaler@... To: WanderlodgeForum@yahoogroups.com Sent: Saturday, January 13, 2007 6:39 PM Subject: Re: [WanderlodgeForum] Re: Cat 3208TA (non ATAAC) ratings Mike Will an oil analysis tell you the bearing condition or do you need to drop the pan? Don 89 SP 36' Butler, PA That's why you keep an eye on the crank shaft bearings. MH ----- Original Message ----- From: birdshill123 To: WanderlodgeForum@yahoogroups.com Sent: Saturday, January 13, 2007 10:31 AM Subject: [WanderlodgeForum] Re: Cat 3208TA (non ATAAC) ratings Ben: My Blue Box has the original Cat brochure on the ATAAC engine 300HP @2800, 743 lb. ft. of torque @ 1600, 1450 lbs. dry, approved for RV's up to 36,000 GVW. For all you owners of 250 HP 3208's there is one caveat: Brochure states: Not recommended for sustained, high mileage, on-highway use. Bruce 1988 FC35 "La Reina Gitana" [Non-text portions of this message have been removed] __________________________________________________________ Check out the new AOL. Most comprehensive set of free safety and security tools, free access to millions of high-quality videos from across the web, free AOL Mail and more. [Non-text portions of this message have been removed] [Non-text portions of this message have been removed] ________________________________________________________________________ Check out the new AOL. Most comprehensive set of free safety and security tools, free access to millions of high-quality videos from across the web, free AOL Mail and more. [Non-text portions of this message have been removed] Cat 3208TA (non ATAAC) ratings - gnburke@...> - 01-14-2007 17:39 Helloo Mike, A mutual friend mentioned that you may have owned a 1977 FC31, with a 534 C.I. gas engine. If you did, would you drop me a line @ gnburke@... .... I have a couple questions concerning the 100 gal. tank, and the engine. TIA, George Burke, 1977 FC31SB In now warm sunny N.C., at least until Tues. ----- Original Message ----- From: Mike Hohnstein To: WanderlodgeForum@yahoogroups.com Sent: Saturday, January 13, 2007 7:49 PM Subject: Re: [WanderlodgeForum] Re: Cat 3208TA (non ATAAC) ratings Oil analysis is a good thing, keeps an eye on the head gaskets. I'm of the opinion that by the time analysis shows excess metal, it's too late. It's a better strategy to physically check the bearings at 100/125k miles. It's an easy job compared to dealing with a bearing failure. MH ----- Original Message ----- From: dspithaler@... To: WanderlodgeForum@yahoogroups.com Sent: Saturday, January 13, 2007 6:39 PM Subject: Re: [WanderlodgeForum] Re: Cat 3208TA (non ATAAC) ratings Mike Will an oil analysis tell you the bearing condition or do you need to drop the pan? Don 89 SP 36' Butler, PA That's why you keep an eye on the crank shaft bearings. MH ----- Original Message ----- From: birdshill123 To: WanderlodgeForum@yahoogroups.com Sent: Saturday, January 13, 2007 10:31 AM Subject: [WanderlodgeForum] Re: Cat 3208TA (non ATAAC) ratings Ben: My Blue Box has the original Cat brochure on the ATAAC engine 300HP @2800, 743 lb. ft. of torque @ 1600, 1450 lbs. dry, approved for RV's up to 36,000 GVW. For all you owners of 250 HP 3208's there is one caveat: Brochure states: Not recommended for sustained, high mileage, on-highway use. Bruce 1988 FC35 "La Reina Gitana" [Non-text portions of this message have been removed] __________________________________________________________ Check out the new AOL. Most comprehensive set of free safety and security tools, free access to millions of high-quality videos from across the web, free AOL Mail and more. [Non-text portions of this message have been removed] [Non-text portions of this message have been removed] [Non-text portions of this message have been removed] |
