Ford 534 C.I. Gas Bird - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Ford 534 C.I. Gas Bird (/showthread.php?tid=4164) |
Ford 534 C.I. Gas Bird - George Burke - 01-17-2007 07:00 My new to me 1977 FC31 gas powered Bird needs a little help. Would love to hear from anyone who has ,or now owns a gas powered Bluebird that came with a Ford 534 C.I. engine. Issues are what did you do to improve mpg.Did you ever have the rear gear ratio changed? If you had a 100 gallon tank, did you run out of gas at 90 gal., (in other words, thats all it would take when we ran out!)Any help,i.e (if you do your own mechanic work, or where if you had work done by someone else), would be appreciated. George Burke 1977 FC31SB Charlotte Ford 534 C.I. Gas Bird - Curt Sprenger - 01-18-2007 04:00 George, Our previous 'Bird, '74 FC31, had the 534 gas engine. I did most of the maintenance, no gear changes. Gas mileage and performance improvements...upgraded the distributor to the Pertronix breakerless, new plugs/wires/coil, removed the factory installed governor & carburetor stuff and installed a 750 Holley carburetor. I never let the tank get below 1/3. Curt Sprenger 1987 PT38 8V92 "MacAttack Racing" Anaheim Hills, Calif. George Burke wrote: > My new to me 1977 FC31 gas powered Bird needs a little help. Would love > to hear from anyone who has ,or now owns a gas powered Bluebird that > came with a Ford 534 C.I. engine. Issues are what did you do to improve > mpg.Did you ever have the rear gear ratio changed? If you had a 100 > gallon tank, did you run out of gas at 90 gal., (in other words, thats > all it would take when we ran out!)Any help,i.e (if you do your own > mechanic work, or where if you had work done by someone else), would be > appreciated. George Burke 1977 FC31SB Charlotte > > Ford 534 C.I. Gas Bird - gnburke@...> - 01-18-2007 15:32 Hello Curt, Thanks for your reply. Do you remember what rear end ratio that your 74 FC31 had, and what was your ave.mpg. My first fillup was 6mpg, (2nd) 5 mpg, (3rd & 4th) averaged 4 mpg. All fillups were over 325 miles, and ran out at 387 miles, but was only able to get 90 gallons in. Need to replace the fuel gauge, but also want to find out why a 100 gal. tank will only take 90 gal. when empty. Have heard that the gen. will cut off when 25 gal. remains. At present, I can go 387 miles before I will have to push. But, if I run the gen, who knows. The original Holly/Motorcraft carb. is a model 4150. Do you remember the # of the 750 cfm that you used? Many thanks, George Burke 1977 FC31SB Charlotte ----- Original Message ----- From: Curt Sprenger To: WanderlodgeForum@yahoogroups.com Sent: Thursday, January 18, 2007 11:00 AM Subject: Re: [WanderlodgeForum] Ford 534 C.I. Gas Bird George, Our previous 'Bird, '74 FC31, had the 534 gas engine. I did most of the maintenance, no gear changes. Gas mileage and performance improvements...upgraded the distributor to the Pertronix breakerless, new plugs/wires/coil, removed the factory installed governor & carburetor stuff and installed a 750 Holley carburetor. I never let the tank get below 1/3. Curt Sprenger 1987 PT38 8V92 "MacAttack Racing" Anaheim Hills, Calif. George Burke wrote: > My new to me 1977 FC31 gas powered Bird needs a little help. Would love > to hear from anyone who has ,or now owns a gas powered Bluebird that > came with a Ford 534 C.I. engine. Issues are what did you do to improve > mpg.Did you ever have the rear gear ratio changed? If you had a 100 > gallon tank, did you run out of gas at 90 gal., (in other words, thats > all it would take when we ran out!)Any help,i.e (if you do your own > mechanic work, or where if you had work done by someone else), would be > appreciated. George Burke 1977 FC31SB Charlotte > > [Non-text portions of this message have been removed] Ford 534 C.I. Gas Bird - one_dusty_hoot - 01-18-2007 16:18 George, To my knowledge the Holley number is the cubic feet per minute. A 750 Holley is good for 750cfm. But, it has been a long time, 1968, that I bought one and I may be wrong. bob janes, greenville, sc --- In WanderlodgeForum@yahoogroups.com, > > Hello Curt, Thanks for your reply. Do you remember what rear end ratio that your 74 FC31 had, and what was your ave.mpg. My first fillup was 6mpg, (2nd) 5 mpg, (3rd & 4th) averaged 4 mpg. All fillups were over 325 miles, and ran out at 387 miles, but was only able to get 90 gallons in. Need to replace the fuel gauge, but also want to find out why a 100 gal. tank will only take 90 gal. when empty. Have heard that the gen. will cut off when 25 gal. remains. At present, I can go 387 miles before I will have to push. But, if I run the gen, who knows. The original Holly/Motorcraft carb. is a model 4150. Do you remember the # of the 750 cfm that you used? Many thanks, George Burke 1977 FC31SB Charlotte > ----- Original Message ----- > From: Curt Sprenger > To: WanderlodgeForum@yahoogroups.com > Sent: Thursday, January 18, 2007 11:00 AM > Subject: Re: [WanderlodgeForum] Ford 534 C.I. Gas Bird > > > George, > > Our previous 'Bird, '74 FC31, had the 534 gas engine. I did most of the > maintenance, no gear changes. > > Gas mileage and performance improvements...upgraded the distributor to > the Pertronix breakerless, new plugs/wires/coil, removed the factory > installed governor & carburetor stuff and installed a 750 Holley > carburetor. > > I never let the tank get below 1/3. > > Curt Sprenger > 1987 PT38 8V92 "MacAttack Racing" > Anaheim Hills, Calif. > > George Burke wrote: > > > My new to me 1977 FC31 gas powered Bird needs a little help. Would love > > to hear from anyone who has ,or now owns a gas powered Bluebird that > > came with a Ford 534 C.I. engine. Issues are what did you do to improve > > mpg.Did you ever have the rear gear ratio changed? If you had a 100 > > gallon tank, did you run out of gas at 90 gal., (in other words, thats > > all it would take when we ran out!)Any help,i.e (if you do your own > > mechanic work, or where if you had work done by someone else), would be > > appreciated. George Burke 1977 FC31SB Charlotte > > > > > > > > > > [Non-text portions of this message have been removed] > Ford 534 C.I. Gas Bird - Curt Sprenger - 01-18-2007 16:57 George, I don't remember the rear end ratio. Contact Jim Benson at Jim.Benson@... or thebenson79@... or jbenson71@... . He owns the coach. Maybe he can find it on one of the information plates or on a tag on the rear end housing. Ask him for pictures too. He had the 'Bird painted in Mexico. Looks great. If I recall correctly, fuel mileage was just over 5mpg, better after the upgrades, maybe 5.5mpg. I traveled down the highway at 62mph. I always towed at least 4,000 lbs. Ask Jim what the gas mileage is. Yes, gen. will not get any fuel at 1/4 tank. I believe there were two options and the 750 Holly had the electric choke vs. manual. I don't recall anything more about it. Curt Sprenger 1987 PT38 8V92 "MacAttack Racing" Anaheim Hills, Calif. gnburke@... wrote: > Hello Curt, Thanks for your reply. Do you remember what rear end ratio > that your 74 FC31 had, and what was your ave.mpg. My first fillup was > 6mpg, (2nd) 5 mpg, (3rd & 4th) averaged 4 mpg. All fillups were over > 325 miles, and ran out at 387 miles, but was only able to get 90 > gallons in. Need to replace the fuel gauge, but also want to find out > why a 100 gal. tank will only take 90 gal. when empty. Have heard that > the gen. will cut off when 25 gal. remains. At present, I can go 387 > miles before I will have to push. But, if I run the gen, who knows. > The original Holly/Motorcraft carb. is a model 4150. Do you remember > the # of the 750 cfm that you used? Many thanks, George Burke 1977 > FC31SB Charlotte > ----- Original Message ----- > From: Curt Sprenger > To: WanderlodgeForum@yahoogroups.com > > Sent: Thursday, January 18, 2007 11:00 AM > Subject: Re: [WanderlodgeForum] Ford 534 C.I. Gas Bird > > George, > > Our previous 'Bird, '74 FC31, had the 534 gas engine. I did most of the > maintenance, no gear changes. > > Gas mileage and performance improvements...upgraded the distributor to > the Pertronix breakerless, new plugs/wires/coil, removed the factory > installed governor & carburetor stuff and installed a 750 Holley > carburetor. > > I never let the tank get below 1/3. > > Curt Sprenger > 1987 PT38 8V92 "MacAttack Racing" > Anaheim Hills, Calif. > > George Burke wrote: > > > My new to me 1977 FC31 gas powered Bird needs a little help. Would love > > to hear from anyone who has ,or now owns a gas powered Bluebird that > > came with a Ford 534 C.I. engine. Issues are what did you do to improve > > mpg.Did you ever have the rear gear ratio changed? If you had a 100 > > gallon tank, did you run out of gas at 90 gal., (in other words, thats > > all it would take when we ran out!)Any help,i.e (if you do your own > > mechanic work, or where if you had work done by someone else), would be > > appreciated. George Burke 1977 FC31SB Charlotte > > > > > > [Non-text portions of this message have been removed] > > Ford 534 C.I. Gas Bird - Jim Benson - 01-20-2007 14:49 Hi guys, I had the bird down on Doheny beach today (as usual) and figured i would crawl under and take a look. 4.63 is the ratio. Best i can figure I'm getting around 5 to 5.5mpg @65MPH. I'm not towing anything. I'll be checking this out better next week on my way out to Quartzite. Just email if i can help with anthing else. Aloha--- Jim Benson Dana Point, CA 74-FC-31 --- Curt Sprenger > George, > > I don't remember the rear end ratio. Contact Jim > Benson at > Jim.Benson@... or thebenson79@... or > jbenson71@... > . He owns the coach. Maybe he can find it on one of > the information > plates or on a tag on the rear end housing. Ask him > for pictures too. He > had the 'Bird painted in Mexico. Looks great. > > If I recall correctly, fuel mileage was just over > 5mpg, better after the > upgrades, maybe 5.5mpg. I traveled down the highway > at 62mph. I always > towed at least 4,000 lbs. Ask Jim what the gas > mileage is. > > Yes, gen. will not get any fuel at 1/4 tank. > > I believe there were two options and the 750 Holly > had the electric > choke vs. manual. I don't recall anything more about > it. > > Curt Sprenger > 1987 PT38 8V92 "MacAttack Racing" > Anaheim Hills, Calif. > > > > gnburke@... wrote: > > > Hello Curt, Thanks for your reply. Do you remember > what rear end ratio > > that your 74 FC31 had, and what was your ave.mpg. > My first fillup was > > 6mpg, (2nd) 5 mpg, (3rd & 4th) averaged 4 mpg. All > fillups were over > > 325 miles, and ran out at 387 miles, but was only > able to get 90 > > gallons in. Need to replace the fuel gauge, but > also want to find out > > why a 100 gal. tank will only take 90 gal. when > empty. Have heard that > > the gen. will cut off when 25 gal. remains. At > present, I can go 387 > > miles before I will have to push. But, if I run > the gen, who knows. > > The original Holly/Motorcraft carb. is a model > 4150. Do you remember > > the # of the 750 cfm that you used? Many thanks, > George Burke 1977 > > FC31SB Charlotte > > ----- Original Message ----- > > From: Curt Sprenger > > To: WanderlodgeForum@yahoogroups.com > > > > Sent: Thursday, January 18, 2007 11:00 AM > > Subject: Re: [WanderlodgeForum] Ford 534 C.I. Gas > Bird > > > > George, > > > > Our previous 'Bird, '74 FC31, had the 534 gas > engine. I did most of the > > maintenance, no gear changes. > > > > Gas mileage and performance > improvements...upgraded the distributor to > > the Pertronix breakerless, new plugs/wires/coil, > removed the factory > > installed governor & carburetor stuff and > installed a 750 Holley > > carburetor. > > > > I never let the tank get below 1/3. > > > > Curt Sprenger > > 1987 PT38 8V92 "MacAttack Racing" > > Anaheim Hills, Calif. > > > > George Burke wrote: > > > > > My new to me 1977 FC31 gas powered Bird needs a > little help. Would love > > > to hear from anyone who has ,or now owns a gas > powered Bluebird that > > > came with a Ford 534 C.I. engine. Issues are > what did you do to improve > > > mpg.Did you ever have the rear gear ratio > changed? If you had a 100 > > > gallon tank, did you run out of gas at 90 gal., > (in other words, thats > > > all it would take when we ran out!)Any help,i.e > (if you do your own > > > mechanic work, or where if you had work done by > someone else), would be > > > appreciated. George Burke 1977 FC31SB Charlotte > > > > > > > > > > [Non-text portions of this message have been > removed] > > > > > > ________________________________________________________________________________\ ____ Want to start your own business? Learn how on Yahoo! Small Business. http://smallbusiness.yahoo.com/r-index |
