Adding Cruise Control? - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Adding Cruise Control? (/showthread.php?tid=4173) |
Adding Cruise Control? - Scott Forman - 01-18-2007 11:24 Has anyone added cruise to an FC that didn't have it? Mine was removed long ago. A few questions: 1) Where can I find a good add-on unit? 2) How hard are these to install? 3) Do they hold speed worth a damn? My FC speed fluctuates so much due to hills and what-not, I have often wondered if cruise could even work. What is your experience? Thanks Scott Forman 82 FC35RB 225 turbo Memphis Adding Cruise Control? - Gardner Yeaw - 01-18-2007 12:11 Scott, Ihave an original unit on my 78FC. It is real nice to give my leg and foot a break between hills. You do still need to anticipate the hills. Here is an aftermarket unit that several people have mentioned on the forum. http://www.rostra.com/RSCostJustificationWorksheet.htm Gardner 78FC33 --- In WanderlodgeForum@yahoogroups.com, "Scott Forman" <sforman@...> wrote: > > Has anyone added cruise to an FC that didn't have it? Mine was removed > long ago. A few questions: > > 1) Where can I find a good add-on unit? > 2) How hard are these to install? > 3) Do they hold speed worth a damn? My FC speed fluctuates so much due > to hills and what-not, I have often wondered if cruise could even > work. What is your experience? > > Thanks > Scott Forman > 82 FC35RB 225 turbo > Memphis > Adding Cruise Control? - Chuck Wheeler - 01-18-2007 12:28 I replaced a defective Dana unit on our 82FC with a Rostra Global Cruise. Once I got it adjusted it works great! The best part was I could reuse the control on the turn signal and the speed pickup. I got my unit from Brandon Distributing Inc, 877-402-3944. When I told them what I had they knew just what to send me. I think it was about $150. It took the best part of a day to install but the time I tested the existing wiring and adapted to to the new unit. The Global Cruise is electric so there is no vacuum or air required. If you want we can talk and I will give you more details about my installation. - Chuck Wheeler - 82 FC 31 SB Fort Worth, TX _____ From: WanderlodgeForum@yahoogroups.com [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of Scott Forman Sent: Thursday, January 18, 2007 5:25 PM To: WanderlodgeForum@yahoogroups.com Subject: [WanderlodgeForum] Adding Cruise Control? Has anyone added cruise to an FC that didn't have it? Mine was removed long ago. A few questions: 1) Where can I find a good add-on unit? 2) How hard are these to install? 3) Do they hold speed worth a damn? My FC speed fluctuates so much due to hills and what-not, I have often wondered if cruise could even work. What is your experience? Thanks Scott Forman 82 FC35RB 225 turbo Memphis [Non-text portions of this message have been removed] Adding Cruise Control? - Mike Hohnstein - 01-18-2007 14:06 That's a lot cheaper than the King Cruise I got. Around 900 bucks, it's built for big trucks, might be overkill for a bird but it works OK. They give good support. MH 83FC35 ----- Original Message ----- From: Chuck Wheeler To: WanderlodgeForum@yahoogroups.com Sent: Thursday, January 18, 2007 6:28 PM Subject: RE: [WanderlodgeForum] Adding Cruise Control? I replaced a defective Dana unit on our 82FC with a Rostra Global Cruise. Once I got it adjusted it works great! The best part was I could reuse the control on the turn signal and the speed pickup. I got my unit from Brandon Distributing Inc, 877-402-3944. When I told them what I had they knew just what to send me. I think it was about $150. It took the best part of a day to install but the time I tested the existing wiring and adapted to to the new unit. The Global Cruise is electric so there is no vacuum or air required. If you want we can talk and I will give you more details about my installation. - Chuck Wheeler - 82 FC 31 SB Fort Worth, TX _____ From: WanderlodgeForum@yahoogroups.com [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of Scott Forman Sent: Thursday, January 18, 2007 5:25 PM To: WanderlodgeForum@yahoogroups.com Subject: [WanderlodgeForum] Adding Cruise Control? Has anyone added cruise to an FC that didn't have it? Mine was removed long ago. A few questions: 1) Where can I find a good add-on unit? 2) How hard are these to install? 3) Do they hold speed worth a damn? My FC speed fluctuates so much due to hills and what-not, I have often wondered if cruise could even work. What is your experience? Thanks Scott Forman 82 FC35RB 225 turbo Memphis [Non-text portions of this message have been removed] [Non-text portions of this message have been removed] Adding Cruise Control? - Chuck Wheeler - 01-18-2007 14:41 Mike, I also looked at the King Cruise but the price and the easy connection with the existing components made me decide to try the Rostra unit. I have helped friends install cruise on their pushers and the King Cruise is easier in that application. It also adjusts easier to the power/weight ratio on large equipment. We had to use relay repeaters to make the Rostra Cruise work reliably in a pusher application. It was an interesting coach. It had an older DD with a 9 speed Roadranger and a two speed rear end. It was so much fun to drive that I took it all the way to Mineral Wells for a "test drive"! I would love to have a BB with that setup. As a note, you all will have to put up with more of me now. I retired at the end of the year. - Chuck Wheeler - 82 FC 31 SB Fort Worth, TX _____ From: WanderlodgeForum@yahoogroups.com [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of Mike Hohnstein Sent: Thursday, January 18, 2007 8:06 PM To: WanderlodgeForum@yahoogroups.com Subject: Re: [WanderlodgeForum] Adding Cruise Control? That's a lot cheaper than the King Cruise I got. Around 900 bucks, it's built for big trucks, might be overkill for a bird but it works OK. They give good support. MH 83FC35 ----- Original Message ----- From: Chuck Wheeler To: WanderlodgeForum@ yahoogroups.com Sent: Thursday, January 18, 2007 6:28 PM Subject: RE: [WanderlodgeForum] Adding Cruise Control? I replaced a defective Dana unit on our 82FC with a Rostra Global Cruise. Once I got it adjusted it works great! The best part was I could reuse the control on the turn signal and the speed pickup. I got my unit from Brandon Distributing Inc, 877-402-3944. When I told them what I had they knew just what to send me. I think it was about $150. It took the best part of a day to install but the time I tested the existing wiring and adapted to to the new unit. The Global Cruise is electric so there is no vacuum or air required. If you want we can talk and I will give you more details about my installation. - Chuck Wheeler - 82 FC 31 SB Fort Worth, TX _____ From: WanderlodgeForum@ yahoogroups.com [mailto:WanderlodgeForum@ yahoogroups.com] On Behalf Of Scott Forman Sent: Thursday, January 18, 2007 5:25 PM To: WanderlodgeForum@ yahoogroups.com Subject: [WanderlodgeForum] Adding Cruise Control? Has anyone added cruise to an FC that didn't have it? Mine was removed long ago. A few questions: 1) Where can I find a good add-on unit? 2) How hard are these to install? 3) Do they hold speed worth a damn? My FC speed fluctuates so much due to hills and what-not, I have often wondered if cruise could even work. What is your experience? Thanks Scott Forman 82 FC35RB 225 turbo Memphis [Non-text portions of this message have been removed] [Non-text portions of this message have been removed] [Non-text portions of this message have been removed] Adding Cruise Control? - davidkerryedwards - 01-18-2007 16:17 I bought the Rostra to replace my original when the vacuum generator failed. I haven't installed it yet but I read of Chuck's satisfaction so will be installing mine when the weather warms up. My OE cruise was hard to get set at the speed I wanted and sometimes just disconnected on its own, but when engaged it held the speed well. Kerry 82 Fc 35 Denver --- In WanderlodgeForum@yahoogroups.com, "Scott Forman" <sforman@...> wrote: > > Has anyone added cruise to an FC that didn't have it? Mine was removed > long ago. A few questions: > > 1) Where can I find a good add-on unit? > 2) How hard are these to install? > 3) Do they hold speed worth a damn? My FC speed fluctuates so much due > to hills and what-not, I have often wondered if cruise could even > work. What is your experience? > > Thanks > Scott Forman > 82 FC35RB 225 turbo > Memphis > Adding Cruise Control? - Curt Sprenger - 01-18-2007 16:33 Chuck, Congrats on your retirement. Enjoy! Curt Sprenger 1987 PT38 8V92 "MacAttack Racing" Anaheim Hills, Calif. Chuck Wheeler wrote: > Mike, > I also looked at the King Cruise but the price and the easy connection > with > the existing components made me decide to try the Rostra unit. I have > helped friends install cruise on their pushers and the King Cruise is > easier > in that application. It also adjusts easier to the power/weight ratio on > large equipment. We had to use relay repeaters to make the Rostra Cruise > work reliably in a pusher application. It was an interesting coach. It had > an older DD with a 9 speed Roadranger and a two speed rear end. It was so > much fun to drive that I took it all the way to Mineral Wells for a "test > drive"! I would love to have a BB with that setup. > > As a note, you all will have to put up with more of me now. I retired at > the end of the year. > > - Chuck Wheeler - > 82 FC 31 SB > Fort Worth, TX > > > _____ > > From: WanderlodgeForum@yahoogroups.com > > [mailto:WanderlodgeForum@yahoogroups.com > > Sent: Thursday, January 18, 2007 8:06 PM > To: WanderlodgeForum@yahoogroups.com > > Subject: Re: [WanderlodgeForum] Adding Cruise Control? > > That's a lot cheaper than the King Cruise I got. Around 900 bucks, it's > built for big trucks, might be overkill for a bird but it works OK. They > give good support. > MH > 83FC35 > ----- Original Message ----- > From: Chuck Wheeler > To: WanderlodgeForum@ > yahoogroups.com > Sent: Thursday, January 18, 2007 6:28 PM > Subject: RE: [WanderlodgeForum] Adding Cruise Control? > > I replaced a defective Dana unit on our 82FC with a Rostra Global Cruise. > Once I got it adjusted it works great! The best part was I could reuse the > control on the turn signal and the speed pickup. I got my unit from > Brandon > Distributing Inc, 877-402-3944. When I told them what I had they knew just > what to send me. I think it was about $150. It took the best part of a day > to install but the time I tested the existing wiring and adapted to to the > new unit. The Global Cruise is electric so there is no vacuum or air > required. If you want we can talk and I will give you more details > about my > installation. > > - Chuck Wheeler - > 82 FC 31 SB > Fort Worth, TX > > _____ > > From: WanderlodgeForum@ > yahoogroups.com > [mailto:WanderlodgeForum@ > yahoogroups.com] On Behalf Of Scott Forman > Sent: Thursday, January 18, 2007 5:25 PM > To: WanderlodgeForum@ > yahoogroups.com > Subject: [WanderlodgeForum] Adding Cruise Control? > > Has anyone added cruise to an FC that didn't have it? Mine was removed > long ago. A few questions: > > 1) Where can I find a good add-on unit? > 2) How hard are these to install? > 3) Do they hold speed worth a damn? My FC speed fluctuates so much due > to hills and what-not, I have often wondered if cruise could even > work. What is your experience? > > Thanks > Scott Forman > 82 FC35RB 225 turbo > Memphis > > [Non-text portions of this message have been removed] > > [Non-text portions of this message have been removed] > > [Non-text portions of this message have been removed] > > Adding Cruise Control? - Eric Johnson - 01-20-2007 03:37 HI Scott, Lots of good answers to your questions. My adds would be: 1. I had a King Cruise unit installed by a Houston shop. 2. Took two men about 4 hours to do the install. They mounted the control box under our driver side sofa and ran the control cable under the carpet and through the side of the dog house. Problem with this was the box (designed for exterior mounting) tended to overheat and fry the electronics. Fix was a D.C. fan and removing one side of the metal box. King Cruise was very helpful in this process and replaced the electronics twice at no charge to me. 3. Cruise is most effective on flat to slightly hilly terrain. Really a help for the driver on long trips. I consider it money well spent. Regards, Eric in San Antonio 84FC35SBWL2 --- In WanderlodgeForum@yahoogroups.com, "Scott Forman" <sforman@...> wrote: > > Has anyone added cruise to an FC that didn't have it? Mine was removed > long ago. A few questions: > > 1) Where can I find a good add-on unit? > 2) How hard are these to install? > 3) Do they hold speed worth a damn? My FC speed fluctuates so much due > to hills and what-not, I have often wondered if cruise could even > work. What is your experience? > > Thanks > Scott Forman > 82 FC35RB 225 turbo > Memphis > Adding Cruise Control? - Todd Jones - 01-21-2007 11:10 Does any manufacturer make a RPM cruise control versus MPH ? Just curious, my boat's cruise control (PerfectPass) has both RPM & MPH. Todd Jones Lincoln, NE. 78FC33 . On 1/20/07, Eric Johnson > > HI Scott, > Lots of good answers to your questions. My adds would be: > 1. I had a King Cruise unit installed by a Houston shop. > 2. Took two men about 4 hours to do the install. They mounted the control > box under > our driver side sofa and ran the control cable under the carpet and > through the side of the > dog house. Problem with this was the box (designed for exterior mounting) > tended to > overheat and fry the electronics. Fix was a D.C. fan and removing one side > of the metal > box. King Cruise was very helpful in this process and replaced the > electronics twice at no > charge to me. > 3. Cruise is most effective on flat to slightly hilly terrain. Really a > help for the driver on > long trips. I consider it money well spent. > > Regards, Eric in San Antonio > 84FC35SBWL2 > > --- In WanderlodgeForum@yahoogroups.com > "Scott Forman" <sforman@...> wrote: > > > > Has anyone added cruise to an FC that didn't have it? Mine was removed > > long ago. A few questions: > > > > 1) Where can I find a good add-on unit? > > 2) How hard are these to install? > > 3) Do they hold speed worth a damn? My FC speed fluctuates so much due > > to hills and what-not, I have often wondered if cruise could even > > work. What is your experience? > > > > Thanks > > Scott Forman > > 82 FC35RB 225 turbo > > Memphis > > > > > [Non-text portions of this message have been removed] |
