gauge readings 88 FC - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: gauge readings 88 FC (/showthread.php?tid=4174) |
gauge readings 88 FC - birdshill123 - 01-18-2007 12:33 The following are my readings at a constant 59 mph. flat country. Water temp. 170 oil press. 70 Rear axle temp 210 ZF temp 195 Pyro 600 to 650 RPM 2000 ambient temp was 55 to 60 At ambient temp of 75 the water temp climbed to just over 175 I do not trust any of the gauges. I used my infrared thermometer on the diff. and it was 160 to 165 depending on where you read. At the sensor it was 160. I know that my gennie oil prssure is off by 15 lbs. as I tested it with a non electric hydraulic gauge. I noticed that when I am in the hills and the turbo kicks in the pyro temps can climb to over 900. Boost is about 10 to 12. How does all of this look?? Bruce 1988 FC35 " LaReina Gitana" on the road in Mexico gauge readings 88 FC - Mike Hohnstein - 01-18-2007 14:19 It's all good. MH ----- Original Message ----- From: birdshill123 To: WanderlodgeForum@yahoogroups.com Sent: Thursday, January 18, 2007 6:33 PM Subject: [WanderlodgeForum] gauge readings 88 FC The following are my readings at a constant 59 mph. flat country. Water temp. 170 oil press. 70 Rear axle temp 210 ZF temp 195 Pyro 600 to 650 RPM 2000 ambient temp was 55 to 60 At ambient temp of 75 the water temp climbed to just over 175 I do not trust any of the gauges. I used my infrared thermometer on the diff. and it was 160 to 165 depending on where you read. At the sensor it was 160. I know that my gennie oil prssure is off by 15 lbs. as I tested it with a non electric hydraulic gauge. I noticed that when I am in the hills and the turbo kicks in the pyro temps can climb to over 900. Boost is about 10 to 12. How does all of this look?? Bruce 1988 FC35 " LaReina Gitana" on the road in Mexico [Non-text portions of this message have been removed] gauge readings 88 FC - Tom Warner - 01-18-2007 15:29 If the thermostats are working properly the water temp should be reading 190-195 tom warner vernon center,ny 1985 PT 40 At 09:19 PM 1/18/2007, you wrote: >It's all good. >MH > ----- Original Message ----- > From: birdshill123 > To: WanderlodgeForum@yahoogroups.com > Sent: Thursday, January 18, 2007 6:33 PM > Subject: [WanderlodgeForum] gauge readings 88 FC > > > The following are my readings at a constant 59 mph. flat country. > Water temp. 170 > oil press. 70 > Rear axle temp 210 > ZF temp 195 > Pyro 600 to 650 > RPM 2000 > ambient temp was 55 to 60 > At ambient temp of 75 the water temp climbed to just over 175 > I do not trust any of the gauges. I used my infrared thermometer on > the diff. and it was 160 to 165 depending on where you read. At the > sensor it was 160. I know that my gennie oil prssure is off by 15 lbs. > as I tested it with a non electric hydraulic gauge. I noticed that > when I am in the hills and the turbo kicks in the pyro temps can climb > to over 900. Boost is about 10 to 12. How does all of this look?? > > Bruce 1988 FC35 > " LaReina Gitana" > on the road in Mexico > > > > > >[Non-text portions of this message have been removed] > > > > >Yahoo! Groups Links > > > gauge readings 88 FC - one_dusty_hoot - 01-18-2007 16:43 Bruce, I think the ambient temperature is on the low side.LOL When I went to Perry in October the fan clutch did not come on till I almost got to Atlanta, 150 miles, Temp was about the same, those radiators do a great job. bob janes, 87fc35, greenville, sc --- In WanderlodgeForum@yahoogroups.com, "birdshill123" > > The following are my readings at a constant 59 mph. flat country. > Water temp. 170 > oil press. 70 > Rear axle temp 210 > ZF temp 195 > Pyro 600 to 650 > RPM 2000 > ambient temp was 55 to 60 > At ambient temp of 75 the water temp climbed to just over 175 > I do not trust any of the gauges. I used my infrared thermometer on > the diff. and it was 160 to 165 depending on where you read. At the > sensor it was 160. I know that my gennie oil prssure is off by 15 lbs. > as I tested it with a non electric hydraulic gauge. I noticed that > when I am in the hills and the turbo kicks in the pyro temps can climb > to over 900. Boost is about 10 to 12. How does all of this look?? > > Bruce 1988 FC35 > " LaReina Gitana" > on the road in Mexico > gauge readings 88 FC - pattypape - 01-19-2007 01:54 Bruce, The 3208 coolant temp. appears to be low, The coolant is really effected by the ambient temp, speed, and hill climbing. It also takes time to get up to a stable operating temp. The thermostat opens at about 185*, Fan kicks on at 195*. These events could be a more accurate indication of temp than the temp gage. So, I would suggest running the 3208 hotter and faster to try to determine if the thermostat is opening properly. oil press. 70 This is good...... Rear axle temp 210 probably not accurate... It could take a full hour of highway driving to reach a stable rear axle running temp. Our 88 rear axle reads about 170* also ambient temp effected ZF temp 195 This is good and rises quickly to the yellow during use. 240/250* Pyro 600 to 650 RPM 2000 (This is good) I have seen 1000* and 13/14 boost. You are correct the gages could be at least 10% off, if they are functioning correctly. My experience with our gages is as follows: The temp gages are really important, the old sensors are not accurate, and the sensors do not always match the gage, I changed both the 3208 oil temp & the rear axle temp gages and matching sensors to get more accurate readings. Sensors need to be matched and purchased thru a Teleflex or Stuart Warner gage distributor. BB is not much help with these old sensors, although BB has a reasonable price on the gages. Volt meters are more accurate, that is why volts are posted to the 10th of a volt, such as 12.7, 13.7 etc. Amp meter accuracy is not criticle, so reading like 25, 50,75 amps is normal. The Onan oil pressure sensor seems to be a higher failure part than the gage. I think this is because of lack of use of the internal diaphram. I replaced the sensor on the Onan to get a more correct reading, 30/60 psi. I have not replaced the Onan temp, gage or sensor, But I know the coolant reads about 20 degrees high. Hope this helps, Bill 88 FC --- In WanderlodgeForum@yahoogroups.com, "birdshill123" > > The following are my readings at a constant 59 mph. flat country. > Water temp. 170 > oil press. 70 > Rear axle temp 210 > ZF temp 195 > Pyro 600 to 650 > RPM 2000 > ambient temp was 55 to 60 > At ambient temp of 75 the water temp climbed to just over 175 > I do not trust any of the gauges. I used my infrared thermometer on > the diff. and it was 160 to 165 depending on where you read. At the > sensor it was 160. I know that my gennie oil prssure is off by 15 lbs. > as I tested it with a non electric hydraulic gauge. I noticed that > when I am in the hills and the turbo kicks in the pyro temps can climb > to over 900. Boost is about 10 to 12. How does all of this look?? > > Bruce 1988 FC35 > " LaReina Gitana" > on the road in Mexico > gauge readings 88 FC - birdshill123 - 01-19-2007 02:33 Thanks Bill: My guage expeience echoes your experience. When we return from our trip I will try and correct those problems (with your help of course). Thanks again: Bruce 1988 FC35 gauge readings 88 FC - Chuck Wheeler - 01-19-2007 05:28 A quick test is to start the cat cold. Feel the bypass hose and when it starts to feel warm feel the upper radiator hose. If it also feels warm you have a thermostat stuck partially open. The only real test is to remove the thermostats and visually check and test them. I had one stuck partially open and the second would not fully open. The symptoms were slow warming up, temperature that tended to vary with speed, and excessive fan operation. After replacement the engine would be up to temp by the time we get out of our subdivision, the engine temperature is very stable, and the only time the fan runs is creeping in traffic or the grade between El Centro and San Diego. By the time I went to the work to pull them our I would just replace them. Be sure and get net gaskets. About a three hour job if you have a swing radiator. - Chuck Wheeler - 82 FC 31 SB Fort Worth, TX _____ From: WanderlodgeForum@yahoogroups.com [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of pattypape Sent: Friday, January 19, 2007 7:55 AM To: WanderlodgeForum@yahoogroups.com Subject: [WanderlodgeForum] Re: gauge readings 88 FC Bruce, The 3208 coolant temp. appears to be low, The coolant is really effected by the ambient temp, speed, and hill climbing. It also takes time to get up to a stable operating temp. The thermostat opens at about 185*, Fan kicks on at 195*. These events could be a more accurate indication of temp than the temp gage. So, I would suggest running the 3208 hotter and faster to try to determine if the thermostat is opening properly. oil press. 70 This is good...... Rear axle temp 210 probably not accurate... It could take a full hour of highway driving to reach a stable rear axle running temp. Our 88 rear axle reads about 170* also ambient temp effected ZF temp 195 This is good and rises quickly to the yellow during use. 240/250* Pyro 600 to 650 RPM 2000 (This is good) I have seen 1000* and 13/14 boost. You are correct the gages could be at least 10% off, if they are functioning correctly. My experience with our gages is as follows: The temp gages are really important, the old sensors are not accurate, and the sensors do not always match the gage, I changed both the 3208 oil temp & the rear axle temp gages and matching sensors to get more accurate readings. Sensors need to be matched and purchased thru a Teleflex or Stuart Warner gage distributor. BB is not much help with these old sensors, although BB has a reasonable price on the gages. Volt meters are more accurate, that is why volts are posted to the 10th of a volt, such as 12.7, 13.7 etc. Amp meter accuracy is not criticle, so reading like 25, 50,75 amps is normal. The Onan oil pressure sensor seems to be a higher failure part than the gage. I think this is because of lack of use of the internal diaphram. I replaced the sensor on the Onan to get a more correct reading, 30/60 psi. I have not replaced the Onan temp, gage or sensor, But I know the coolant reads about 20 degrees high. Hope this helps, Bill 88 FC --- In WanderlodgeForum@ yahoogroups.com, "birdshill123" > > The following are my readings at a constant 59 mph. flat country. > Water temp. 170 > oil press. 70 > Rear axle temp 210 > ZF temp 195 > Pyro 600 to 650 > RPM 2000 > ambient temp was 55 to 60 > At ambient temp of 75 the water temp climbed to just over 175 > I do not trust any of the gauges. I used my infrared thermometer on > the diff. and it was 160 to 165 depending on where you read. At the > sensor it was 160. I know that my gennie oil prssure is off by 15 lbs. > as I tested it with a non electric hydraulic gauge. I noticed that > when I am in the hills and the turbo kicks in the pyro temps can climb > to over 900. Boost is about 10 to 12. How does all of this look?? > > Bruce 1988 FC35 > " LaReina Gitana" > on the road in Mexico > [Non-text portions of this message have been removed] |
