Synthetic Engine Oil - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Synthetic Engine Oil (/showthread.php?tid=4186) |
Synthetic Engine Oil - Pete Masterson - 01-23-2007 09:33 I know this will probably generate a lot of passionate opinions ... but what synthetic engine oil brand is suggested as "best" for a DD Series 60 engine. (I don't know what brand was used by the prior owner.) I found a good buy on eBay for a 5 gallon "pail" of Royal Purple synthetic. The radiator shop I used sells Redline brand. Both seem to have the appropriate API certification. Comments please? Pete Masterson aeonix1@... '95 Blue Bird Wanderlodge WBDA 42' El Sobrante, CA [Non-text portions of this message have been removed] Synthetic Engine Oil - David Brady - 01-23-2007 13:19 Pete, I've been using Mobil 1 Delvac for the last 30K miles. Royal Purple and Mobil 1 are approved by DD for use in the S60. Whatever DD approves I wouldn't hesitate to use. David Brady '02 LXi, Smoke NC Pete Masterson wrote: > I know this will probably generate a lot of passionate opinions ... > but what synthetic engine oil brand is suggested as "best" for a DD > Series 60 engine. (I don't know what brand was used by the prior > owner.) I found a good buy on eBay for a 5 gallon "pail" of Royal > Purple synthetic. The radiator shop I used sells Redline brand. Both > seem to have the appropriate API certification. Comments please? > Pete Masterson > aeonix1@... > '95 Blue Bird Wanderlodge WBDA 42' > El Sobrante, CA > > > > > > > [Non-text portions of this message have been removed] > > > > > Yahoo! Groups Links > > > > > > Synthetic Engine Oil - Gregory OConnor - 01-23-2007 14:12 If you use the least expensive stuff the Mfg aprove, it is easier to replace it on the time interval. I dont use synthetic because I run the used oil in the fuel tank of my work trucks. GregoryO'Connor 94ptRomolandCa --- In WanderlodgeForum@yahoogroups.com, David Brady wrote: > > Pete, > > I've been using Mobil 1 Delvac for the last 30K miles. Royal Purple > and Mobil 1 are approved by DD for use in the S60. Whatever DD > approves I wouldn't hesitate to use. > > David Brady > '02 LXi, Smoke > NC > > Pete Masterson wrote: > > I know this will probably generate a lot of passionate opinions ... > > but what synthetic engine oil brand is suggested as "best" for a DD > > Series 60 engine. (I don't know what brand was used by the prior > > owner.) I found a good buy on eBay for a 5 gallon "pail" of Royal > > Purple synthetic. The radiator shop I used sells Redline brand. Both > > seem to have the appropriate API certification. Comments please? > > Pete Masterson > > aeonix1@... > > '95 Blue Bird Wanderlodge WBDA 42' > > El Sobrante, CA > > > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > > > > Yahoo! Groups Links > > > > > > > > > > > > > Synthetic Engine Oil - Tom Warner - 01-23-2007 16:07 I believe that Royal Purple is NOT recommended by Detroit Diesel as see in their publication Detroit Diesel Lubricating oil, fuel and filters http://tinyurl.com/32txa4 What is interesting is that both Mobil Delvac 1 and Mobil Super 1300 is also recommended. I have used Mobil Super 1300 for some time in my old Cat 3208, my diesel tractor, and all my vehicles. It is a very special oil and very heavily used by truckers as it can now be found in almost any truck stop I have been in while travelling and in Walmarts at less then $7/gallon and auto parts stores. In my opinion for the few miles that we travel in a year I think synthetic oils are a waste since the drain intervals are not increased with them. Average coach owner travels 5000 miles a year and then changes the oil. tom warner vernon center,ny 1985 PT 40 with 6V92 that cant use mobil super 1300 At 08:19 PM 1/23/2007, you wrote: >Pete, > >I've been using Mobil 1 Delvac for the last 30K miles. Royal Purple >and Mobil 1 are approved by DD for use in the S60. Whatever DD >approves I wouldn't hesitate to use. > >David Brady >'02 LXi, Smoke >NC > >Pete Masterson wrote: > > I know this will probably generate a lot of passionate opinions ... > > but what synthetic engine oil brand is suggested as "best" for a DD > > Series 60 engine. (I don't know what brand was used by the prior > > owner.) I found a good buy on eBay for a 5 gallon "pail" of Royal > > Purple synthetic. The radiator shop I used sells Redline brand. Both > > seem to have the appropriate API certification. Comments please? > > Pete Masterson > > aeonix1@... > > '95 Blue Bird Wanderlodge WBDA 42' > > El Sobrante, CA > > > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > > > > Yahoo! Groups Links > > > > > > > > > > > > > > > > >Yahoo! Groups Links > > > |
