update: plumbing/pump change in '95 BB - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: update: plumbing/pump change in '95 BB (/showthread.php?tid=4232) |
update: plumbing/pump change in '95 BB - Pete Masterson - 02-02-2007 12:23 Just to update folks on my project to replace my water pumps with a Shurflo variable speed 'demand' pump. I found the "Flare-It" connectors at Pex Connection <http://www.pexconnection.com>. It seems that California is the one state where PEX isn't in the building code, so no local hardware stores normally carry it nor the Flare-It connectors. The original plumbing in a '95 is made from polybutylene ("PB") pipe that was discontinued 1998 after a series of class-action lawsuits. I successfully installed PB to Pex connectors, some Pex tubing and the variable speed pump. Started up the pump, and after clearing the air out of the lines, everything seemed pretty good ... except, the fresh water drain valve had some pre-existing cracks that 'let go' under the slightly higher pressure of the new pump. I had the foresight to order an extra PB to normal pipe thread connector, so I'm on my way to the hardware store to try to replace the leaky valve. Once that's fixed, I'm going to pressure up and look at _all_ the visible connectors under the sinks, etc. to check for leaks. The variable speed pump indicates that its operating pressure is 65 lbs. -- somewhat more than the 40 lbs. nominal pressure with the old pumps. I suggest that others that might be contemplating this upgrade take that into consideration. (I can add, that I'm not thrilled with the idea of replumbing the coach, if it comes to that!) Pete Masterson aeonix1@... '95 Blue Bird Wanderlodge WBDA 42' El Sobrante, CA [Non-text portions of this message have been removed] update: plumbing/pump change in '95 BB - Don Bradner - 02-02-2007 13:41 Google "California Plastic Plumbing" (on the news pages) and you will find that CPVC was approved a couple of days ago. Don't know if this will include Pex or not, but the state is finally joining the rest of the nation on plastic vs copper. On 2/2/2007 at 4:23 PM Pete Masterson wrote: >Just to update folks on my project to replace my water pumps with a >Shurflo variable speed 'demand' pump. I found the "Flare-It" >connectors at Pex Connection <http://www.pexconnection.com>. It seems >that California is the one state where PEX isn't in the building >code, so no local hardware stores normally carry it nor the Flare-It >connectors. The original plumbing in a '95 is made from polybutylene >("PB") pipe that was discontinued 1998 after a series of class-action >lawsuits. > >I successfully installed PB to Pex connectors, some Pex tubing and >the variable speed pump. Started up the pump, and after clearing the >air out of the lines, everything seemed pretty good ... except, the >fresh water drain valve had some pre-existing cracks that 'let go' >under the slightly higher pressure of the new pump. I had the >foresight to order an extra PB to normal pipe thread connector, so >I'm on my way to the hardware store to try to replace the leaky >valve. Once that's fixed, I'm going to pressure up and look at _all_ >the visible connectors under the sinks, etc. to check for leaks. The >variable speed pump indicates that its operating pressure is 65 lbs. >-- somewhat more than the 40 lbs. nominal pressure with the old >pumps. I suggest that others that might be contemplating this upgrade >take that into consideration. > >(I can add, that I'm not thrilled with the idea of replumbing the >coach, if it comes to that!) > >Pete Masterson >aeonix1@... >'95 Blue Bird Wanderlodge WBDA 42' >El Sobrante, CA > > > > > > >[Non-text portions of this message have been removed] > > > > >Yahoo! Groups Links > > > Don Bradner http://www.arcatapet.net update: plumbing/pump change in '95 BB - Pete Masterson - 02-02-2007 15:38 It's interesting that when I Googled the "california plastic plumbing" I got (part of) an article entitled "PEX [plastic plumbing pipe] makers sue California" It goes on to state that the California Plumbing Code left _out_ PEX when it approved an updated code ... (it breaks off there...) Another 'hit' brings up the Plastic Pipe CPVC approval (which I saw in a local paper). The hardware store had a few CPVC fittings on the shelf, but they're not (directly) compatible with the PEX. The article on the CPVC goes into some detail about how a combination of plumbers unions and environmental groups (including the Sierra Club) have joined to attack plastic pipe of various types based on "safety." The environmental groups claim there are health risks while the unions object to the "loss of work" that the more efficient to install plastic pipes represent. Actually, I did recall seeing a CPVC article in the paper a couple of days ago... but CPVC isn't PEX ... CPVC is chlorinated polyvinyl chloride while Pex is "cross linked polyethylene". Frankly, the CPVC is still more labor intensive than PEX as it requires glued fittings while the Pex can be bent around corners, eliminating all joints and fittings between the source and the destination of a run... The unions certainly will do all they can to keep it out of the state ... and there's always an environmental group or two that will complain about any technology lurking around this state... Pete Masterson aeonix1@... '95 Blue Bird Wanderlodge WBDA 42' El Sobrante, CA On Feb 2, 2007, at 5:41 PM, Don Bradner wrote: > Google "California Plastic Plumbing" (on the news pages) and you > will find that CPVC was approved a couple of days ago. Don't know > if this will include Pex or not, but the state is finally joining > the rest of the nation on plastic vs copper. > > On 2/2/2007 at 4:23 PM Pete Masterson wrote: [Non-text portions of this message have been removed] |
