Water Temperature - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Water Temperature (/showthread.php?tid=4263) |
Water Temperature - jwasnewski - 02-07-2007 18:11 I changed the subject because the speedo has been repaired. <> The override switch will have no effect if the chassis a/c is on because the fan is already in full force. Looking at the numbers, the chassis a/c was turned off while climbing the hills? Right? That would make sense, otherwise one would expect the temperature to climb to some fixed point without a cycle and the temperature would not recede until going down hill or running on flat land again. Leroy Eckert 1990 WB-40 "Smoke N Mirrors" Niceville, FL Water Temperature - Don Bradner - 02-08-2007 02:22 There is only one really significant long uphill from Quartzsite to Gila Bend, and that's at the beginning, about 5 miles in length, steady climb. Yes, the A/C was off, and that's also when I was most closely watching the cycle. On 2/8/2007 at 6:11 AM jwasnewski wrote: >I changed the subject because the speedo has been repaired. <> > >The override switch will have no effect if the chassis a/c is on >because the fan is already in full force. Looking at the numbers, the >chassis a/c was turned off while climbing the hills? Right? That would >make sense, otherwise one would expect the temperature to climb to some >fixed point without a cycle and the temperature would not recede until >going down hill or running on flat land again. > >Leroy Eckert >1990 WB-40 "Smoke N Mirrors" >Niceville, FL Don Bradner http://www.arcatapet.net Water Temperature - Ralph L. Fullenwider - 02-08-2007 02:41 Morning: If the fan over ride is not working, then the fan is running full time. I have seen the ground wire, on the valves behind the drivers side tag mud flap area, broken from road debris. If the ground is removed from the valves, which is what the fan over ride switch does, when you first start the Coach, open the engine hatch and check the fan, it should not be turning if all is ok. The sender for the fan to cycle is located to the left of center of the engine under some piping, those connections corrode as well. Safe travels, Ralph and Charolette Fullenwider 84FC35 Ralph's RV Solutions, Duncan, Oklahoma At 07:22 AM 2/8/2007 -0700, you wrote: >There is only one really significant long uphill from Quartzsite to Gila >Bend, and that's at the beginning, about 5 miles in length, steady climb. >Yes, the A/C was off, and that's also when I was most closely watching the >cycle. > >On 2/8/2007 at 6:11 AM jwasnewski wrote: > > >I changed the subject because the speedo has been repaired. <> > > > >The override switch will have no effect if the chassis a/c is on > >because the fan is already in full force. Looking at the numbers, the > >chassis a/c was turned off while climbing the hills? Right? That would > >make sense, otherwise one would expect the temperature to climb to some > >fixed point without a cycle and the temperature would not recede until > >going down hill or running on flat land again. > > > >Leroy Eckert > >1990 WB-40 "Smoke N Mirrors" > >Niceville, FL > >Don Bradner >http://www.arcatapet.net > > > Water Temperature - Leroy Eckert - 02-08-2007 04:59 Thank you sir for the info. Leroy Eckert 1990 WB-40 "Smoke N Mirrors" Niceville, FL ----- Original Message ----- From: Don Bradner To: WanderlodgeForum@yahoogroups.com Sent: Thursday, February 08, 2007 8:22 AM Subject: Re: [WanderlodgeForum] Water Temperature There is only one really significant long uphill from Quartzsite to Gila Bend, and that's at the beginning, about 5 miles in length, steady climb. Yes, the A/C was off, and that's also when I was most closely watching the cycle. On 2/8/2007 at 6:11 AM jwasnewski wrote: >I changed the subject because the speedo has been repaired. <> > >The override switch will have no effect if the chassis a/c is on >because the fan is already in full force. Looking at the numbers, the >chassis a/c was turned off while climbing the hills? Right? That would >make sense, otherwise one would expect the temperature to climb to some >fixed point without a cycle and the temperature would not recede until >going down hill or running on flat land again. > >Leroy Eckert >1990 WB-40 "Smoke N Mirrors" >Niceville, FL Don Bradner http://www.arcatapet.net [Non-text portions of this message have been removed] |
