Radio Speakers not working - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Radio Speakers not working (/showthread.php?tid=4273) |
Radio Speakers not working - krminyl@... - 02-09-2007 01:08 I have a Privacy switch above my head, and to the left, where you switch on the A/C and Elect Heater units. That switch might have been bumped off accidentally. Also, it might sound elementary, but check your fader control on the radio...make sure your front speakers are "on". As for the weird dimming lights on the radio, sounds like a low voltage issue to the unit itself. Try turning off the electronic master switch (the toggle switch found in a cabinet...mine is in the overhead storage cabinet, street side, above the little glass front spice cabinet, then turning it back on. It might "re-boot" the radio....make sure that your master switch is on at the same time (the one under the dash). Also...did anyone have an Alpine radio in their BB (the one with a detachable head, cassette, with a remote CD changer) lying around....maybe someone who has upgraded the radio? I sent my unit back to Alpine to replace the illumination bulbs about a yr ago, and they have burnt out again...the display is dark, and unless you hold a light to the front of the display, you can't read the radio display. the unit works fine, except for not being able to see the display. Anyone??? Thanks.. Kevin McKeown Yorba Linda, CA 1986 38' PT [Non-text portions of this message have been removed] Radio Speakers not working - krminyl@... - 02-09-2007 05:01 Cool...glad it was something simple...it usually is!! (I did the same thing when my BB was "new") Kevin McKeown Yorba Linda, CA 1986 38' PT [Non-text portions of this message have been removed] Radio Speakers not working - amerson2 - 02-09-2007 05:24 I have a unusual problem. The front radio has no sound coming from the speakers. This has just happened a few weeks ago. I can see that the radio is getting a signal as the stereo light will flicker and the cd's will change songs. As I was waiting for tires to be installed today I turned the master switch under the dash off. After the master switch was turned off the radio would play for app. 2 seconds, off for a second then come on again for about 1 second very faintly. The light display on the radio would remain constant during this. I tried this several times with the same result. Any ideas? Pete Amerson 87 PT-40 Century FL Radio Speakers not working - bluebirdsp36 - 02-09-2007 08:17 Check your Speaker to headphones switch. Mine is on the left arm console and I keep hitting it with my elbow. Paul 90 SP-36 --- In WanderlodgeForum@yahoogroups.com, "amerson2" wrote: > > I have a unusual problem. The front radio has no sound coming from the > speakers. This has just happened a few weeks ago. Radio Speakers not working - amerson2 - 02-09-2007 09:09 --- In WanderlodgeForum@yahoogroups.com, krminyl@... wrote: >Thanks for your help. It was the switch that controls the headphones near the a/c-heater switches. Now I can listen to country music again......... Pete Amerson 87 PT-40 Century FL > I have a Privacy switch above my head, and to the left, where you switch on > the A/C and Elect Heater units. That switch might have been bumped off > accidentally. Also, it might sound elementary, but check your fader control on > the radio...make sure your front speakers are "on". As for the weird dimming > lights on the radio, sounds like a low voltage issue to the unit itself. Try > turning off the electronic master switch (the toggle switch found in a > cabinet...mine is in the overhead storage cabinet, street side, above the little > glass front spice cabinet, then turning it back on. It might "re- boot" the > radio....make sure that your master switch is on at the same time (the one under > the dash). > > Also...did anyone have an Alpine radio in their BB (the one with a > detachable head, cassette, with a remote CD changer) lying around....maybe someone who > has upgraded the radio? I sent my unit back to Alpine to replace the > illumination bulbs about a yr ago, and they have burnt out again...the display is > dark, and unless you hold a light to the front of the display, you can't read > the radio display. the unit works fine, except for not being able to see > the display. Anyone??? > > Thanks.. > > Kevin McKeown > Yorba Linda, CA > 1986 38' PT > > > [Non-text portions of this message have been removed] > Radio Speakers not working - Richard Hayden - 02-09-2007 18:24 I had a similar problem. It turned out to be that the equalizer was the problem, it had failed. I simply bypassed the equalizer and everything works fine. Dick Hayden - '87 PT 38 - Lake Stevens, WA ----- Original Message ----- From: amerson2 To: WanderlodgeForum@yahoogroups.com Sent: Friday, February 09, 2007 9:24 AM Subject: [WanderlodgeForum] Radio Speakers not working I have a unusual problem. The front radio has no sound coming from the speakers. This has just happened a few weeks ago. I can see that the radio is getting a signal as the stereo light will flicker and the cd's will change songs. As I was waiting for tires to be installed today I turned the master switch under the dash off. After the master switch was turned off the radio would play for app. 2 seconds, off for a second then come on again for about 1 second very faintly. The light display on the radio would remain constant during this. I tried this several times with the same result. Any ideas? Pete Amerson 87 PT-40 Century FL [Non-text portions of this message have been removed] |
