alternator problem - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: alternator problem (/showthread.php?tid=429) |
alternator problem - orpllew - 04-28-2005 23:41 hi everyone. we made our second run of the year (250 miles r.t.) this past weekend. before returning home i lifted the doghouse lid to check oil, belts, etc. i noticed the bottom bolt on the back of the alt loose and as i was tightening it i noticed that a condensor wire attached to the back of tha alt was burnt. i traced it to the indicator light post. it is a single wire that attaches to the post and runs to a condensor looking piece. the wire had detached from the condensor. i removed the wire and condensor. the coach ran fine coming home with no noticeable charging or noise problems. any advice??? orpllew 78fc cole camp missouri alternator problem - Gary Miller - 04-29-2005 01:25 This is a noise filter for the alternator. I removed mine from my '77 with no ill effects. - Jeff Miller http://www.wanderlodge.net http://www.millercoachworks.com --- In WanderlodgeForum@yahoogroups.com, "orpllew" wrote: > hi everyone. we made our second run of the year (250 miles r.t.) this > past weekend. before returning home i lifted the doghouse lid to check > oil, belts, etc. i noticed the bottom bolt on the back of the alt loose > and as i was tightening it i noticed that a condensor wire attached to > the back of tha alt was burnt. i traced it to the indicator light post. > it is a single wire that attaches to the post and runs to a condensor > looking piece. the wire had detached from the condensor. i removed the > wire and condensor. the coach ran fine coming home with no noticeable > charging or noise problems. any advice??? > > orpllew 78fc cole camp missouri alternator problem - John Suter - 04-29-2005 02:08 It sounds like the "condensor" device you describe is the radio/sound system "shunt" (1" diameter, by 2-3" long, tubular paper capacitor which shunts extraneous A.C. current to ground) which generally removes the "generator whine" from audio devices such as the sound system and radios, and possibly TV video interference, when the coach engine is operating and the engine alternator is providing current. If you discover irritating sounds/interference to electronic gadgets, you might consider replacing the device. Otherwise, in general, no harm, no foul. John Suter --- orpllew > i noticed that a > condensor wire attached to > the back of tha alt was burnt. i traced it to the > indicator light post. > it is a single wire that attaches to the post and > runs to a condensor > looking piece. the wire had detached from the > condensor. i removed the > wire and condensor. the coach ran fine coming home > with no noticeable > charging or noise problems. any advice??? > > orpllew 78fc cole camp missouri __________________________________________________ Do You Yahoo!? Tired of spam? Yahoo! Mail has the best spam protection around http://mail.yahoo.com |
