8V92 alternator questions - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: 8V92 alternator questions (/showthread.php?tid=4313) Pages: 1 2 |
8V92 alternator questions - Don Bradner - 02-20-2007 11:57 I've got a few questions after I describe what I'm seeing on my dual-alternator 8V92: After starting, the voltage is somewhat below 13, and alt2 is running about 50 amps. Alt1 is essentially zero, although there is a slight upward blip when changing the display from alt2 to both. Voltage slowly rises, and after quite a distance (100 miles or more) the voltage is in the 13.5 range. At around that time, the Fault light comes on. Alt2 at this point is running around 25 amps, and there is no apparent increase in the both position. What do other 8V92 dual-alternator owners see for charge rates, 1, 2, and both? I'm presuming the zero/near zero is telling me I have a bad alternator, but is the 50 amps from Alt2 also low? If it is, what does that mean? Does anyone know, on theirs, which alternator is 1 and which is 2? Front top, or back by the bumper? Don Bradner 90 PT40 "Blue Thunder" 8V92 alternator questions - smquandt - 02-20-2007 13:01 Don Previous discussion on this or the other Wanderlodge forum was that there might be a bad ground to ALT #1. I have the same problem but my 93 PT is in Florida until Friday when I go to retrieve it. I'm going to pull the floor when I get home. I had the Alt. rebuilt last summer when it was pulled just as a preventive maintenance issue, still read no voltage when replaced but didn't have time last summer to tackle the problem. Steve Quandt Iron Mountain, MI 93 PT40 -----Original Message----- From: WanderlodgeForum@yahoogroups.com [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of Don Bradner Sent: Tuesday, February 20, 2007 5:58 PM To: wanderlodgeforum@yahoogroups.com Subject: [WanderlodgeForum] 8V92 alternator questions I've got a few questions after I describe what I'm seeing on my dual-alternator 8V92: After starting, the voltage is somewhat below 13, and alt2 is running about 50 amps. Alt1 is essentially zero, although there is a slight upward blip when changing the display from alt2 to both. Voltage slowly rises, and after quite a distance (100 miles or more) the voltage is in the 13.5 range. At around that time, the Fault light comes on. Alt2 at this point is running around 25 amps, and there is no apparent increase in the both position. What do other 8V92 dual-alternator owners see for charge rates, 1, 2, and both? I'm presuming the zero/near zero is telling me I have a bad alternator, but is the 50 amps from Alt2 also low? If it is, what does that mean? Does anyone know, on theirs, which alternator is 1 and which is 2? Front top, or back by the bumper? Don Bradner 90 PT40 "Blue Thunder" [Non-text portions of this message have been removed] 8V92 alternator questions - Bob & Carol Howald` - 02-20-2007 14:25 Don: I've had a few alternator problem's with my 93pt a few years ago. It was always the # 2 alternator, that's the one on the left side of the engine . After replacing the alternator 2 time's bluebird finally convinced me to just eliminate it and use the # 1 alternator only, it's the one on the right side next to the bumper. I've not had any problem's since going to the single alternator. I use it to charge 8--series 31 house batteries plus the 3 engine start. Never a problem since and we do some dry camping. I believe that the problem with the # 2 alternator is due to the fact that the grounding cable's are too small. I now carry that extra alternator in the part's box in case I need it. It's much easier to replace the # 1 alternator than # 2. Also..A common problem is that one fail's and you don't know it till the other one fail's and then you have nothing. The alternator check switch #1--#2 is generally not reliable I would not spend much time or much trust in the integrity of this switch. Work's for me;;;;;;;Bob 93pt-40 - In WanderlodgeForum@yahoogroups.com, "Don Bradner" > > I've got a few questions after I describe what I'm seeing on my dual-alternator 8V92: > > After starting, the voltage is somewhat below 13, and alt2 is running about 50 amps. Alt1 is essentially zero, although there is a slight upward blip when changing the display from alt2 to both. > > Voltage slowly rises, and after quite a distance (100 miles or more) the voltage is in the 13.5 range. At around that time, the Fault light comes on. Alt2 at this point is running around 25 amps, and there is no apparent increase in the both position. > > What do other 8V92 dual-alternator owners see for charge rates, 1, 2, and both? I'm presuming the zero/near zero is telling me I have a bad alternator, but is the 50 amps from Alt2 also low? If it is, what does that mean? > > Does anyone know, on theirs, which alternator is 1 and which is 2? Front top, or back by the bumper? > > Don Bradner > 90 PT40 "Blue Thunder" > 8V92 alternator questions - Leroy Eckert - 02-20-2007 14:46 Don: I probably will not be much help because I chased that switch ghost for a year. I finally gave up and unplugged the fault light. It doesn't concern me any more. My number 1 alternator is the one on top of the engine accessable under the bed. After I start typically my amp guage will be in the 150 range with the switch in dual. It progressively decreases while driving and the volt meter is around 13.5v. Once stable the amp reading is 50 amp at all times. I periodically check my alternators for output with a meter. If you find the ghost, please advise. Leroy Eckert 1990 WB-40"Smoke N Mirrors" Niceville, FL ----- Original Message ----- From: Don Bradner To: wanderlodgeforum@yahoogroups.com Sent: Tuesday, February 20, 2007 5:57 PM Subject: [WanderlodgeForum] 8V92 alternator questions I've got a few questions after I describe what I'm seeing on my dual-alternator 8V92: After starting, the voltage is somewhat below 13, and alt2 is running about 50 amps. Alt1 is essentially zero, although there is a slight upward blip when changing the display from alt2 to both. Voltage slowly rises, and after quite a distance (100 miles or more) the voltage is in the 13.5 range. At around that time, the Fault light comes on. Alt2 at this point is running around 25 amps, and there is no apparent increase in the both position. What do other 8V92 dual-alternator owners see for charge rates, 1, 2, and both? I'm presuming the zero/near zero is telling me I have a bad alternator, but is the 50 amps from Alt2 also low? If it is, what does that mean? Does anyone know, on theirs, which alternator is 1 and which is 2? Front top, or back by the bumper? Don Bradner 90 PT40 "Blue Thunder" [Non-text portions of this message have been removed] 8V92 alternator questions - Don Bradner - 02-20-2007 15:06 That's helpful. It actually hadn't occurred to me that I might be chasing a switch ghost - I figured the number 1 (which you say is the one under the bed, but for Bob it is the one by the bumper ???) was actually bad, but the fault didn't trip until the total amperage dropped low enough. With a charge rate of 150 amps I would expect your batteries to hit full charge fairly quickly? That mine takes hours and 100 miles or more is a good part of why I thought the 50 amp rate might be right. We are not talking about discharged batteries - these are one-month-old 6-volt AGM Lifelines that are full charged at the start, and only have to make up for the current used in starting the engine. I would expect 160-amp chargers, even if only one is working, to get it up in a matter of minutes with a high charge-rate that quickly falls off. I'm not seeing that. I know just enough about alternators to be dangerous. I understand exciter current and such. I don't understand how an alternator would be working, but working way less than full output. On 2/20/2007 at 8:46 PM Leroy Eckert wrote: >Don: >I probably will not be much help because I chased that switch ghost for a >year. I finally gave up and unplugged the fault light. It doesn't concern >me any more. My number 1 alternator is the one on top of the engine >accessable under the bed. > >After I start typically my amp guage will be in the 150 range with the >switch in dual. It progressively decreases while driving and the volt >meter is around 13.5v. Once stable the amp reading is 50 amp at all >times. > >I periodically check my alternators for output with a meter. > >If you find the ghost, please advise. > >Leroy Eckert >1990 WB-40"Smoke N Mirrors" >Niceville, FL > > > > > > > ----- Original Message ----- > From: Don Bradner > To: wanderlodgeforum@yahoogroups.com > Sent: Tuesday, February 20, 2007 5:57 PM > Subject: [WanderlodgeForum] 8V92 alternator questions > > > I've got a few questions after I describe what I'm seeing on my >dual-alternator 8V92: > > After starting, the voltage is somewhat below 13, and alt2 is running >about 50 amps. Alt1 is essentially zero, although there is a slight upward >blip when changing the display from alt2 to both. > > Voltage slowly rises, and after quite a distance (100 miles or more) the >voltage is in the 13.5 range. At around that time, the Fault light comes >on. Alt2 at this point is running around 25 amps, and there is no apparent >increase in the both position. > > What do other 8V92 dual-alternator owners see for charge rates, 1, 2, >and both? I'm presuming the zero/near zero is telling me I have a bad >alternator, but is the 50 amps from Alt2 also low? If it is, what does >that mean? > > Does anyone know, on theirs, which alternator is 1 and which is 2? Front >top, or back by the bumper? > > Don Bradner > 90 PT40 "Blue Thunder" > > > > > >[Non-text portions of this message have been removed] > > > > >Yahoo! Groups Links > > > Don Bradner http://www.arcatapet.net 8V92 alternator questions - g_man1146 - 02-20-2007 15:43 Hi Don, When I got Blue Thunder the alternator fault light would come on frequently. BB told me that the internal voltage regulators in the alternators were not closely matched and when one alternator cut out due to the voltage level being satisfied it triggered a fault. Turning on a load such as headlights triggered the alternator to start and the light went out. The fault light would cycle on and off. The "fix" was to install a time delay relay so a fault would have to be present for 15-30 minutes or so before the light would come on. Reasoning being that if the alternator really was bad, it would stay bad long enough to light the LED. I mention this because you may find the time delay relay inside the dash and wonder. There should be documentation of this modification in the blue box. If the relay circuit is still there, you may have a bad alternator. My recollection is that both alternators output similar amperage until one cut out. I didn't forget your pictures and found many. Unfortunately I have prints only, no negatives or digital files and am attempting to find a service that will scan them all so I can send you the files. If I don't find that, I can send them all to you and you can copy the ones you want and return the originals to me. Rich D. '99LXi43' CT --- In WanderlodgeForum@yahoogroups.com, "Don Bradner" wrote: > > I've got a few questions after I describe what I'm seeing on my dual-alternator 8V92: > > After starting, the voltage is somewhat below 13, and alt2 is running about 50 amps. Alt1 is essentially zero, although there is a slight upward blip when changing the display from alt2 to both. > > Voltage slowly rises, and after quite a distance (100 miles or more) the voltage is in the 13.5 range. At around that time, the Fault light comes on. Alt2 at this point is running around 25 amps, and there is no apparent increase in the both position. > > What do other 8V92 dual-alternator owners see for charge rates, 1, 2, and both? I'm presuming the zero/near zero is telling me I have a bad alternator, but is the 50 amps from Alt2 also low? If it is, what does that mean? > > Does anyone know, on theirs, which alternator is 1 and which is 2? Front top, or back by the bumper? > > Don Bradner > 90 PT40 "Blue Thunder" > 8V92 alternator questions - Leroy Eckert - 02-20-2007 15:45 I tend to agree with your concerns. My alternator behind the rear bumper failed and I was not aware of it. On the road my #1 alternator failed and left me with the generator. That really wasn't a problem.. The #1 alternator was a 160amp variety if I recall and when I pulled the #2 it was 135amp. I put a 160amp alternator back. All of this is from memory at the moment, I could look in my paper work and verify. It has been almost 3 years without problems. I even had Coachcraft by McDonald, Columbus GA a BB service center look at the switch for me when I retrofitted the Wabasto and they could not figure it out either. I changed all the wires, cleaned connections and nothing changed at the switch. Soooo, I unplugged the !@#$ light. A little bit of redneck engineering there. Kinda like if the rattle bothers you , turn up the radio. lol You have 6v batteries? Interesting mine are 12v, bank of 6. A lot of weird differences in these coaches, eh? Typically, in terms of time, depending if the a/c, lights, inverter output, etc. are utilized, it may take 30 minutes for the amp meter to settle at 50 amp in my coach. I'd suggest starting the coach and checking the output of both alternators, if they have output you may be ok. Also, check the rating, someone may have placed a lesser output value on the coach. 160's are not easy to find and are not cheap. Just a thought. Leroy Eckert 1990 WB-40"Smoke N Mirrors" Niceville, FL Leroy Eckert 1990 WB-40"Smoke N Mirrors" Niceville, FL ----- Original Message ----- From: Don Bradner To: WanderlodgeForum@yahoogroups.com Sent: Tuesday, February 20, 2007 9:06 PM Subject: Re: [WanderlodgeForum] 8V92 alternator questions That's helpful. It actually hadn't occurred to me that I might be chasing a switch ghost - I figured the number 1 (which you say is the one under the bed, but for Bob it is the one by the bumper ???) was actually bad, but the fault didn't trip until the total amperage dropped low enough. With a charge rate of 150 amps I would expect your batteries to hit full charge fairly quickly? That mine takes hours and 100 miles or more is a good part of why I thought the 50 amp rate might be right. We are not talking about discharged batteries - these are one-month-old 6-volt AGM Lifelines that are full charged at the start, and only have to make up for the current used in starting the engine. I would expect 160-amp chargers, even if only one is working, to get it up in a matter of minutes with a high charge-rate that quickly falls off. I'm not seeing that. I know just enough about alternators to be dangerous. I understand exciter current and such. I don't understand how an alternator would be working, but working way less than full output. On 2/20/2007 at 8:46 PM Leroy Eckert wrote: >Don: >I probably will not be much help because I chased that switch ghost for a >year. I finally gave up and unplugged the fault light. It doesn't concern >me any more. My number 1 alternator is the one on top of the engine >accessable under the bed. > >After I start typically my amp guage will be in the 150 range with the >switch in dual. It progressively decreases while driving and the volt >meter is around 13.5v. Once stable the amp reading is 50 amp at all >times. > >I periodically check my alternators for output with a meter. > >If you find the ghost, please advise. > >Leroy Eckert >1990 WB-40"Smoke N Mirrors" >Niceville, FL > > > > > > > ----- Original Message ----- > From: Don Bradner > To: wanderlodgeforum@yahoogroups.com > Sent: Tuesday, February 20, 2007 5:57 PM > Subject: [WanderlodgeForum] 8V92 alternator questions > > > I've got a few questions after I describe what I'm seeing on my >dual-alternator 8V92: > > After starting, the voltage is somewhat below 13, and alt2 is running >about 50 amps. Alt1 is essentially zero, although there is a slight upward >blip when changing the display from alt2 to both. > > Voltage slowly rises, and after quite a distance (100 miles or more) the >voltage is in the 13.5 range. At around that time, the Fault light comes >on. Alt2 at this point is running around 25 amps, and there is no apparent >increase in the both position. > > What do other 8V92 dual-alternator owners see for charge rates, 1, 2, >and both? I'm presuming the zero/near zero is telling me I have a bad >alternator, but is the 50 amps from Alt2 also low? If it is, what does >that mean? > > Does anyone know, on theirs, which alternator is 1 and which is 2? Front >top, or back by the bumper? > > Don Bradner > 90 PT40 "Blue Thunder" > > > > > >[Non-text portions of this message have been removed] > > > > >Yahoo! Groups Links > > > Don Bradner http://www.arcatapet.net [Non-text portions of this message have been removed] 8V92 alternator questions - Leroy Eckert - 02-20-2007 15:54 Interesting, there really is a ghost in there. Leroy Eckert 1990 WB-40"Smoke N Mirrors" Niceville, FL ----- Original Message ----- From: g_man1146 To: WanderlodgeForum@yahoogroups.com Sent: Tuesday, February 20, 2007 9:43 PM Subject: [WanderlodgeForum] Re: 8V92 alternator questions Hi Don, When I got Blue Thunder the alternator fault light would come on frequently. BB told me that the internal voltage regulators in the alternators were not closely matched and when one alternator cut out due to the voltage level being satisfied it triggered a fault. Turning on a load such as headlights triggered the alternator to start and the light went out. The fault light would cycle on and off. The "fix" was to install a time delay relay so a fault would have to be present for 15-30 minutes or so before the light would come on. Reasoning being that if the alternator really was bad, it would stay bad long enough to light the LED. I mention this because you may find the time delay relay inside the dash and wonder. There should be documentation of this modification in the blue box. If the relay circuit is still there, you may have a bad alternator. My recollection is that both alternators output similar amperage until one cut out. I didn't forget your pictures and found many. Unfortunately I have prints only, no negatives or digital files and am attempting to find a service that will scan them all so I can send you the files. If I don't find that, I can send them all to you and you can copy the ones you want and return the originals to me. Rich D. '99LXi43' CT --- In WanderlodgeForum@yahoogroups.com, "Don Bradner" wrote: > > I've got a few questions after I describe what I'm seeing on my dual-alternator 8V92: > > After starting, the voltage is somewhat below 13, and alt2 is running about 50 amps. Alt1 is essentially zero, although there is a slight upward blip when changing the display from alt2 to both. > > Voltage slowly rises, and after quite a distance (100 miles or more) the voltage is in the 13.5 range. At around that time, the Fault light comes on. Alt2 at this point is running around 25 amps, and there is no apparent increase in the both position. > > What do other 8V92 dual-alternator owners see for charge rates, 1, 2, and both? I'm presuming the zero/near zero is telling me I have a bad alternator, but is the 50 amps from Alt2 also low? If it is, what does that mean? > > Does anyone know, on theirs, which alternator is 1 and which is 2? Front top, or back by the bumper? > > Don Bradner > 90 PT40 "Blue Thunder" > [Non-text portions of this message have been removed] 8V92 alternator questions - Don Bradner - 02-20-2007 16:22 Thanks, Rich. I didn't get the blue box - sent you an e-mail a week or so ago asking if it passed on from you, sounds like it did. I'm going to resend that e-mail after this one, so let me know if you don't get it. I'll be home tomorrow; have been somewhat on the road (but sitting a lot in Arizona) since getting Blue Thunder. Should have a couple of months to go through everything as carefully as I can to see if I can figure out what's going on. In 1500 miles the only other thing that has come up was a transient "do not shift/check tranny" light that occurred towards the end of the long climb up I-17 near the 6000-foot level. I had left it in Cruise at 62, and it was doing a lot of up-down shifting. I just backed off and the warnings did not re-occur. Temps, including tranny temp, were the same as they are the rest of the time (except when using the retarder, when obviously the transmission temps climb a lot). On 2/21/2007 at 3:43 AM g_man1146 wrote: >Hi Don, > >When I got Blue Thunder the alternator fault light would come on >frequently. BB told me that the internal voltage regulators in the >alternators were not closely matched and when one alternator cut out >due to the voltage level being satisfied it triggered a fault. >Turning on a load such as headlights triggered the alternator to >start and the light went out. The fault light would cycle on and >off. The "fix" was to install a time delay relay so a fault would >have to be present for 15-30 minutes or so before the light would >come on. Reasoning being that if the alternator really was bad, it >would stay bad long enough to light the LED. I mention this because >you may find the time delay relay inside the dash and wonder. There >should be documentation of this modification in the blue box. If the >relay circuit is still there, you may have a bad alternator. My >recollection is that both alternators output similar amperage until >one cut out. > >I didn't forget your pictures and found many. Unfortunately I have >prints only, no negatives or digital files and am attempting to find >a service that will scan them all so I can send you the files. If I >don't find that, I can send them all to you and you can copy the >ones you want and return the originals to me. > >Rich D. '99LXi43' CT > > >--- In WanderlodgeForum@yahoogroups.com, "Don Bradner" >wrote: >> >> I've got a few questions after I describe what I'm seeing on my >dual-alternator 8V92: >> >> After starting, the voltage is somewhat below 13, and alt2 is >running about 50 amps. Alt1 is essentially zero, although there is a >slight upward blip when changing the display from alt2 to both. >> >> Voltage slowly rises, and after quite a distance (100 miles or >more) the voltage is in the 13.5 range. At around that time, the >Fault light comes on. Alt2 at this point is running around 25 amps, >and there is no apparent increase in the both position. >> >> What do other 8V92 dual-alternator owners see for charge rates, 1, >2, and both? I'm presuming the zero/near zero is telling me I have a >bad alternator, but is the 50 amps from Alt2 also low? If it is, >what does that mean? >> >> Does anyone know, on theirs, which alternator is 1 and which is 2? >Front top, or back by the bumper? >> >> Don Bradner >> 90 PT40 "Blue Thunder" >> > > > > > >Yahoo! Groups Links > > > Don Bradner http://www.arcatapet.net 8V92 alternator questions - Don Bradner - 02-21-2007 02:46 This one had 6 12v Group 24s until a bit over a month ago. Swapping out for 6-volt Golf Cart batteries is a common method of increasing capacity. They have nearly the same footprint as the Group 24, but are taller. 6 Group 24s is 450AH (6*75), while 6 Golf Carts in series-parallel is 660AH (3*220). Golf Cart batteries are also designed for sustained discharge at significant output. The one tradeoff is a loss in high-power output. The Group 24s are rated for 500 Cold-Cranking Amps, while the CCA of a GC battery is 800, so you get 3000 (6*500) vs 2400 (3*800). I worried a bit about that, but reading, and experience since, indicates that 2000 is plenty for starting an 8V92. On 2/20/2007 at 9:45 PM Leroy Eckert wrote: >You have 6v batteries? Interesting mine are 12v, bank of 6. >A lot of weird differences in these coaches, eh? Don Bradner http://www.arcatapet.net |
