Speedometer - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Speedometer (/showthread.php?tid=4334) |
Speedometer - Dale Cooper - 06-17-2007 12:57 Speedometer reads very high, then very low and sometimes seems accurate, I am thinking about replacing the Speedo gage in the dash, any suggestions. Dale Cooper 1984 35 Ft. FC, SB Speedometer - Gardner Yeaw - 06-17-2007 13:39 Dale, On my '78FC my speedometer has similar problems. I am planning to send it to a shop in Lncaster PA. to see if they can fix it. I will update the forum when I get it back with the cost and results. I want to maintain the same guages for appearence. Gardner 78FC33 --- In WanderlodgeForum@yahoogroups.com, "Dale Cooper" wrote: > > Speedometer reads very high, then very low and sometimes seems > accurate, I am thinking about replacing the Speedo gage in the dash, > any suggestions. > > Dale Cooper > 1984 35 Ft. FC, SB > Speedometer - webdarn - 06-18-2007 04:41 I had a similar problem on my 82FC and it was a very dirty sensor on the rear axle. One of my brake drums has notches cut in the edge and a sensor reads the speed of the notches and signals to the speedo. My sensor was covered in mud and dirt. After a good cleaning, everything has worked fine. Hope this helps, a lot easier than pulling a speedo. Andy Clayton '82 35FC --- In WanderlodgeForum@yahoogroups.com, "Gardner Yeaw" wrote: > > Dale, > On my '78FC my speedometer has similar problems. I am planning to > send it to a shop in Lncaster PA. to see if they can fix it. I will > update the forum when I get it back with the cost and results. I want > to maintain the same guages for appearence. > > Gardner > 78FC33 > > > --- In WanderlodgeForum@yahoogroups.com, "Dale Cooper" > wrote: > > > > Speedometer reads very high, then very low and sometimes seems > > accurate, I am thinking about replacing the Speedo gage in the dash, > > any suggestions. > > > > Dale Cooper > > 1984 35 Ft. FC, SB > > > Speedometer - Gardner Yeaw - 06-18-2007 13:42 Dale, My '78 has a mechanical spedometer. I got an estimate of $150 to $200 to fix it. Gardner 78FC33 --- In WanderlodgeForum@yahoogroups.com, "Dale Cooper" wrote: > > Speedometer reads very high, then very low and sometimes seems > accurate, I am thinking about replacing the Speedo gage in the dash, > any suggestions. > > Dale Cooper > 1984 35 Ft. FC, SB > Speedometer - Jeff Miller - 06-19-2007 14:12 On the '84, there is a speed sensor on the rear of the brake drum, curb side. They go bad, and are only around $35. On some '84s there is another one on the left brake drum, the cruise-control was separated for interference reasons. The speed sensor if original is likly to break when you attempt to free it from its rusty lock-nut. I had to replace the sensor on two of my FCs On the '78 mechanical one: I replaced the speedo on my '77, used a new electronic speedometer. You can buy the new Teleflex one if you want (matches), or go with a new VDO programmable, about $100 I believe. For a speed sensor I used a driveshaft pickup, four magnets on the front of the driveshaft and a pickup coil (easily) mounted above it. On another arrangement I used the '77 speedometer cable to drive a cruise-control AC signal generator, also easy to find at your local NAPA et al. If you go VDO, you can buy the matching programmable tachometer, forget about the problematic tach drive on the FC, and drive the tachometer from the alternator, a fairly simple modification. buy the tachometer with the hourmeter in it, memory tells me that the '78 didn't have an engine hourmeter. A Teleflex industrial/international tach with hourmeter used to be available to match also (as in the later FCs and PTs), not sure they're still available but it's what I used in my '77. - Jeff Miller --- In WanderlodgeForum@yahoogroups.com, "Gardner Yeaw" wrote: > > Dale, > My '78 has a mechanical spedometer. I got an estimate of $150 to > $200 to fix it. > > Gardner > 78FC33 > > --- In WanderlodgeForum@yahoogroups.com, "Dale Cooper" > wrote: > > > > Speedometer reads very high, then very low and sometimes seems > > accurate, I am thinking about replacing the Speedo gage in the dash, > > any suggestions. > > > > Dale Cooper > > 1984 35 Ft. FC, SB > > > |
