Canister with Coolant Lines - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Canister with Coolant Lines (/showthread.php?tid=4353) |
Canister with Coolant Lines - Curt Sprenger - 02-17-2007 09:51 There is a canister 7" dia. and 12" length. It's located under the radiator fan mount. Coolant lines go to/from it. What is this canister? Thanks. -- Curt Sprenger 1987 PT38 8V92 "MacAttack Racing" Anaheim Hills, Calif. Canister with Coolant Lines - Terry Neal - 02-17-2007 09:58 That's the filter canister for your engine coolant system. Uses a filter element to trap all those pieces of crud from your engine block & radiator. Terry Neal Bozeman, MT 82PT40 6V92TA 74FC34 6V53T Curt Sprenger wrote: > There is a canister 7" dia. and 12" length. It's located under the > radiator fan mount. Coolant lines go to/from it. What is this canister? > Thanks. > > -- > Curt Sprenger > 1987 PT38 8V92 "MacAttack Racing" > Anaheim Hills, Calif. > > [Non-text portions of this message have been removed] |
