Tranny Heat Exchanger - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Tranny Heat Exchanger (/showthread.php?tid=4381) |
Tranny Heat Exchanger - Curt Sprenger - 02-21-2007 10:47 Tranny Heat Exchanger...I removed more tubes/hoses so visual inspection could be made of the tranny heat exchanger insides. The inside has many, many 1/8" tubes running through it, like a radiator core. I can see three tubes that have a little crud in the end. Other than that the inside looks fine. I would like to have seen the inside of the exchanger that caused the Montana tranny to be replaced. -- Curt Sprenger 1987 PT38 8V92 "MacAttack Racing" Anaheim Hills, Calif. Tranny Heat Exchanger - Troy Tikalsky - 02-21-2007 11:00 You may want to have this pressure tested. I had a heater core repaired at a radiator repair shop and they flushed and pressure tested several times. Troy Tikalsky 1986 Newell Waconia, MN ----- Original Message ----- From: Curt Sprenger To: WanderlodgeForum@yahoogroups.com ; wanderlodge@yahoogroups.com Sent: Wednesday, February 21, 2007 4:47 PM Subject: [WanderlodgeForum] Tranny Heat Exchanger Tranny Heat Exchanger...I removed more tubes/hoses so visual inspection could be made of the tranny heat exchanger insides. The inside has many, many 1/8" tubes running through it, like a radiator core. I can see three tubes that have a little crud in the end. Other than that the inside looks fine. I would like to have seen the inside of the exchanger that caused the Montana tranny to be replaced. -- Curt Sprenger 1987 PT38 8V92 "MacAttack Racing" Anaheim Hills, Calif. [Non-text portions of this message have been removed] Tranny Heat Exchanger - Leroy Eckert - 02-21-2007 12:12 I hope you are taking your clothes to the local Laundromat. lol Leroy Eckert 1990 WB-40"Smoke N Mirrors" Niceville, FL ----- Original Message ----- From: Curt Sprenger To: WanderlodgeForum@yahoogroups.com ; wanderlodge@yahoogroups.com Sent: Wednesday, February 21, 2007 4:47 PM Subject: [WanderlodgeForum] Tranny Heat Exchanger Tranny Heat Exchanger...I removed more tubes/hoses so visual inspection could be made of the tranny heat exchanger insides. The inside has many, many 1/8" tubes running through it, like a radiator core. I can see three tubes that have a little crud in the end. Other than that the inside looks fine. I would like to have seen the inside of the exchanger that caused the Montana tranny to be replaced. -- Curt Sprenger 1987 PT38 8V92 "MacAttack Racing" Anaheim Hills, Calif. [Non-text portions of this message have been removed] Tranny Heat Exchanger - Curt Sprenger - 02-21-2007 12:33 That's a good idea but I'd feel sorry for the next person using the washing machine. My wife said something like "throw them out, you are not washing those in my machine." So I just throw them in the trash bin. I save my old Levis and t-shirts for these jobs. Curt Sprenger 1987 PT38 8V92 "MacAttack Racing" Anaheim Hills, Calif. Leroy Eckert wrote: > I hope you are taking your clothes to the local Laundromat. lol > > Leroy Eckert > 1990 WB-40"Smoke N Mirrors" > Niceville, FL > > ----- Original Message ----- > From: Curt Sprenger > To: WanderlodgeForum@yahoogroups.com > > wanderlodge@yahoogroups.com > Sent: Wednesday, February 21, 2007 4:47 PM > Subject: [WanderlodgeForum] Tranny Heat Exchanger > > Tranny Heat Exchanger...I removed more tubes/hoses so visual inspection > could be made of the tranny heat exchanger insides. The inside has many, > many 1/8" tubes running through it, like a radiator core. I can see > three tubes that have a little crud in the end. Other than that the > inside looks fine. I would like to have seen the inside of the exchanger > that caused the Montana tranny to be replaced. > > -- > Curt Sprenger > 1987 PT38 8V92 "MacAttack Racing" > Anaheim Hills, Calif. > > [Non-text portions of this message have been removed] > > |
