ZF trans temperature sensor - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: ZF trans temperature sensor (/showthread.php?tid=442) |
ZF trans temperature sensor - williamcharrison - 04-29-2005 15:34 Hi all, Can anyone tell me how to locate the transmission temperature sensor on a 90 sp36? My manuals refer to the zf trans manual but it is not in the documentation. ZF trans temperature sensor - Gary Miller - 04-30-2005 01:19 The temperature sender should be located just behind the bell housing, on the upper portion, above the drain plug side of the transmission. Left side, top, forward as you look at the transmission from the driveshaft end. Gary Miller 83 FC 33 Wauwatosa, WI --- In WanderlodgeForum@yahoogroups.com, "williamcharrison" > Hi all, > Can anyone tell me how to locate the transmission temperature sensor > on a 90 sp36? My manuals refer to the zf trans manual but it is not > in the documentation. |
