Lubricating/softening rubber? - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Lubricating/softening rubber? (/showthread.php?tid=4444) |
Lubricating/softening rubber? - Scott Forman - 03-03-2007 05:37 In this month's FMCA magazine, a guy wrote in and said he was able to make his Thetford toilet hold water again by applying a rubber conditioner of some kind to the gasket, which had become hard. I am having the same problem, and want to try his idea. Can anyone recommend a good rubber conditioner? Thanks Scott Forman 82 FC35RB Memphis Lubricating/softening rubber? - Robert Britton - 03-03-2007 14:06 You might want to try silicone plumbers grease, I found some at Ace Hardware. I use this on my waste valves for a good seal and also used it on an old O ring that wouldn't seal (couldn't find a proper replacement). Put some silicone grease on it and have not had a proplem sense --- In WanderlodgeForum@yahoogroups.com, "Scott Forman" <sforman@...> wrote: > > In this month's FMCA magazine, a guy wrote in and said he was able to > make his Thetford toilet hold water again by applying a rubber > conditioner of some kind to the gasket, which had become hard. I am > having the same problem, and want to try his idea. Can anyone > recommend a good rubber conditioner? > > Thanks > Scott Forman > 82 FC35RB > Memphis > Lubricating/softening rubber? - Fred Hulse - 03-03-2007 14:26 Scott The product he used was 303 Protectant which is used to protect rubber, vinyl, etc. Fred & Jeanne Hulse Morristown Arizona 1997 Wanderlodge WLWB41 [Non-text portions of this message have been removed] |
