Cooland Hose Question & Answer - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Cooland Hose Question & Answer (/showthread.php?tid=4449) |
Cooland Hose Question & Answer - Curt Sprenger - 03-03-2007 15:45 I'm responding on the forums so others get the information...I received several emails asking about the condition of the hose from the engine to air compressor. I've only disconnected the air compressor end of that coolant hose. That was a PITA, until I made up my own tooling. That is why I buy China Palace tools, cheap, and to cut them up to make up tools. In the next couple days I'll remove the starter, and in turn disconnect the other end of that hose. Once that is done I can tell you what condition the hose is in. I'll post what I find. The coolant hose Bluebird installed from the engine to the air compressor is the same type hose installed from the coolant expansion tank to the top of the radiator. I have that hose removed and have examined it, and others; hose is very brittle/stiff, internal separation below or inside of the SS braiding, and a black/rust appearance inside. I'm not sure what this is telling me at this point, but my thinking is it is time the hoses are replaced. To remove the hoses from the fittings, they are extremely difficult to remove, I use a die grinder with a cutting wheel, cutting in parallel with the hose, cut through the outer covering and the SS braiding (sparks here), being careful not to cut into the fittings. After I'm through the SS, I use a screw driver to push the hose off (around) the fitting. I'll post more as progress is made. Curt Sprenger 1987 PT38 8V92 "MacAttack Racing" Anaheim Hills, Calif. |
