Towing Question - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Towing Question (/showthread.php?tid=4487) |
Towing Question - jr_hampton - 03-13-2007 02:56 Hi All, I'm A class C owner and I'm getting close to a purchase on a beautiful 87 PT38. Just one quick question for the group, are there any GVWR/GCWR data on these coaches available? I'm sure they can pull a bunch with a 8V92TA but I'd like to know the numbers if possible. Thanks In Advance, Jeff Hampton Towing Question - Richard Hayden - 03-13-2007 05:12 Jeff, I pull a 20', 7000# car hauler with no trouble. Sure, I can tell the difference with and without the trailer but it pulls just fine. Good luck. Dick Hayden - '87 PT 38 - Lake Stevens, WA ----- Original Message ----- From: jr_hampton To: WanderlodgeForum@yahoogroups.com Sent: Tuesday, March 13, 2007 6:56 AM Subject: [WanderlodgeForum] Towing Question Hi All, I'm A class C owner and I'm getting close to a purchase on a beautiful 87 PT38. Just one quick question for the group, are there any GVWR/GCWR data on these coaches available? I'm sure they can pull a bunch with a 8V92TA but I'd like to know the numbers if possible. Thanks In Advance, Jeff Hampton [Non-text portions of this message have been removed] Towing Question - Leroy Eckert - 03-13-2007 09:53 There should be a tag on the coach you are looking at that gives you that info. My tag is under the overhead above the driver. You really have to crank the ole neck around to read it. I also pull a 7000# 20 ft trailer without any problems. Leroy Eckert 1990WB-40"Smoke N Mirrors" Niceville, FL 8v92 TAC 475hp DDEC II Allison HT-755 5 speed ----- Original Message ----- From: Richard Hayden To: WanderlodgeForum@yahoogroups.com Sent: Tuesday, March 13, 2007 11:12 AM Subject: Re: [WanderlodgeForum] Towing Question Jeff, I pull a 20', 7000# car hauler with no trouble. Sure, I can tell the difference with and without the trailer but it pulls just fine. Good luck. Dick Hayden - '87 PT 38 - Lake Stevens, WA ----- Original Message ----- From: jr_hampton To: WanderlodgeForum@yahoogroups.com Sent: Tuesday, March 13, 2007 6:56 AM Subject: [WanderlodgeForum] Towing Question Hi All, I'm A class C owner and I'm getting close to a purchase on a beautiful 87 PT38. Just one quick question for the group, are there any GVWR/GCWR data on these coaches available? I'm sure they can pull a bunch with a 8V92TA but I'd like to know the numbers if possible. Thanks In Advance, Jeff Hampton [Non-text portions of this message have been removed] [Non-text portions of this message have been removed] Towing Question - Richard Hayden - 03-13-2007 20:11 My neck won't turn in that fashion so I just take a picture of those plates and add them to the Blue Box. Dick Hayden - '87 PT 38 - Lake Stevens, WA ----- Original Message ----- From: Leroy Eckert To: WanderlodgeForum@yahoogroups.com Sent: Tuesday, March 13, 2007 1:53 PM Subject: Re: [WanderlodgeForum] Towing Question There should be a tag on the coach you are looking at that gives you that info. My tag is under the overhead above the driver. You really have to crank the ole neck around to read it. I also pull a 7000# 20 ft trailer without any problems. Leroy Eckert 1990WB-40"Smoke N Mirrors" Niceville, FL 8v92 TAC 475hp DDEC II Allison HT-755 5 speed ----- Original Message ----- From: Richard Hayden To: WanderlodgeForum@yahoogroups.com Sent: Tuesday, March 13, 2007 11:12 AM Subject: Re: [WanderlodgeForum] Towing Question Jeff, I pull a 20', 7000# car hauler with no trouble. Sure, I can tell the difference with and without the trailer but it pulls just fine. Good luck. Dick Hayden - '87 PT 38 - Lake Stevens, WA ----- Original Message ----- From: jr_hampton To: WanderlodgeForum@yahoogroups.com Sent: Tuesday, March 13, 2007 6:56 AM Subject: [WanderlodgeForum] Towing Question Hi All, I'm A class C owner and I'm getting close to a purchase on a beautiful 87 PT38. Just one quick question for the group, are there any GVWR/GCWR data on these coaches available? I'm sure they can pull a bunch with a 8V92TA but I'd like to know the numbers if possible. Thanks In Advance, Jeff Hampton [Non-text portions of this message have been removed] [Non-text portions of this message have been removed] [Non-text portions of this message have been removed] |
