Problem with propane - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Problem with propane (/showthread.php?tid=4527) |
Problem with propane - curlesw - 03-19-2007 14:33 Hi Everyone, need a little help with my propane system. The last time we used the Bird, everything worked great (stove and heater). Now we are out on the road and no go (yes, lesson learned...check ALL systems before you leave...even the "simple ones"). I checked to make sure the tank is full. All valves are opened, nothing at the stove and heater fan will run, but does not get hot. Question: Is there anything electrical required to get the propane to work? I found a couple of blown fuses, not sure what they are for actually...any chance of them being related to this problem? I thought the propane system was all mechanical. Thanks for your help. v/r Wayne and Kimberlynn Curles 1984 PT-40 Problem with propane - Pete Masterson - 03-19-2007 15:14 Here's a non-intuitive suggestion -- for the heat, make sure that the AC master switches (by the driver) are turned ON. Also, check the LP gas leak detector. If it senses LP gas it will shut it off. Might also do that if it has no power or is defective. I believe it is electrical -- so a blown fuse might affect it. Pete Masterson aeonix1@... '95 Blue Bird Wanderlodge WBDA 42' El Sobrante, CA On Mar 19, 2007, at 6:33 PM, curlesw wrote: > Hi Everyone, need a little help with my propane system. The last time > we used the Bird, everything worked great (stove and heater). Now we > are out on the road and no go (yes, lesson learned...check ALL systems > before you leave...even the "simple ones"). I checked to make sure > the > tank is full. All valves are opened, nothing at the stove and heater > fan will run, but does not get hot. > > Question: Is there anything electrical required to get the propane to > work? I found a couple of blown fuses, not sure what they are for > actually...any chance of them being related to this problem? I > thought > the propane system was all mechanical. > > Thanks for your help. > > v/r > Wayne and Kimberlynn Curles > 1984 PT-40 [Non-text portions of this message have been removed] Problem with propane - Leroy Eckert - 03-19-2007 15:35 As well as the other suggestions, my electronic master switch shuts off, all the propane ops as well as certain other systems. Leroy Eckert 1990 WB-40"Smoke N Mirrors" Niceville, FL ----- Original Message ----- From: curlesw To: WanderlodgeForum@yahoogroups.com Sent: Monday, March 19, 2007 7:33 PM Subject: [WanderlodgeForum] Problem with propane Hi Everyone, need a little help with my propane system. The last time we used the Bird, everything worked great (stove and heater). Now we are out on the road and no go (yes, lesson learned...check ALL systems before you leave...even the "simple ones"). I checked to make sure the tank is full. All valves are opened, nothing at the stove and heater fan will run, but does not get hot. Question: Is there anything electrical required to get the propane to work? I found a couple of blown fuses, not sure what they are for actually...any chance of them being related to this problem? I thought the propane system was all mechanical. Thanks for your help. v/r Wayne and Kimberlynn Curles 1984 PT-40 [Non-text portions of this message have been removed] Problem with propane - Gregory OConnor - 03-19-2007 15:40 To add to Petes list, the 3 way refridg has an ignition key delay hooked up to keep the amonia system pilot from sparking when the bus is pitstopped for fuel. My 94pt has a 110 style light switch that control a inline valve called "lp master" located below the sink. this valve fails closed. GregoryO'Connor 94ptRomolandCa --- In WanderlodgeForum@yahoogroups.com, Pete Masterson wrote: > > Here's a non-intuitive suggestion -- for the heat, make sure that the > AC master switches (by the driver) are turned ON. > > Also, check the LP gas leak detector. If it senses LP gas it will > shut it off. Might also do that if it has no power or is defective. I > believe it is electrical -- so a blown fuse might affect it. > > Pete Masterson > aeonix1@... > '95 Blue Bird Wanderlodge WBDA 42' > El Sobrante, CA > > > > > On Mar 19, 2007, at 6:33 PM, curlesw wrote: > > > Hi Everyone, need a little help with my propane system. The last time > > we used the Bird, everything worked great (stove and heater). Now we > > are out on the road and no go (yes, lesson learned...check ALL systems > > before you leave...even the "simple ones"). I checked to make sure > > the > > tank is full. All valves are opened, nothing at the stove and heater > > fan will run, but does not get hot. > > > > Question: Is there anything electrical required to get the propane to > > work? I found a couple of blown fuses, not sure what they are for > > actually...any chance of them being related to this problem? I > > thought > > the propane system was all mechanical. > > > > Thanks for your help. > > > > v/r > > Wayne and Kimberlynn Curles > > 1984 PT-40 > > > > [Non-text portions of this message have been removed] > Problem with propane - curlesw - 03-19-2007 15:51 Thanks guys, got it. It was the LP detector...such a newbie mistake. At least I can have a warm dinner now. Thanks again. v/r Wayne C. --- In WanderlodgeForum@yahoogroups.com, "Gregory OConnor" > > To add to Petes list, the 3 way refridg has an ignition key delay > hooked up to keep the amonia system pilot from sparking when the bus > is pitstopped for fuel. My 94pt has a 110 style light switch that > control a inline valve called "lp master" located below the sink. > this valve fails closed. > > GregoryO'Connor > 94ptRomolandCa > > --- In WanderlodgeForum@yahoogroups.com, Pete Masterson > wrote: > > > > Here's a non-intuitive suggestion -- for the heat, make sure that > the > > AC master switches (by the driver) are turned ON. > > > > Also, check the LP gas leak detector. If it senses LP gas it will > > shut it off. Might also do that if it has no power or is defective. > I > > believe it is electrical -- so a blown fuse might affect it. > > > > Pete Masterson > > aeonix1@ > > '95 Blue Bird Wanderlodge WBDA 42' > > El Sobrante, CA > > > > > > > > > > On Mar 19, 2007, at 6:33 PM, curlesw wrote: > > > > > Hi Everyone, need a little help with my propane system. The last > time > > > we used the Bird, everything worked great (stove and heater). > Now we > > > are out on the road and no go (yes, lesson learned...check ALL > systems > > > before you leave...even the "simple ones"). I checked to make > sure > > > the > > > tank is full. All valves are opened, nothing at the stove and > heater > > > fan will run, but does not get hot. > > > > > > Question: Is there anything electrical required to get the > propane to > > > work? I found a couple of blown fuses, not sure what they are for > > > actually...any chance of them being related to this problem? I > > > thought > > > the propane system was all mechanical. > > > > > > Thanks for your help. > > > > > > v/r > > > Wayne and Kimberlynn Curles > > > 1984 PT-40 > > > > > > > > [Non-text portions of this message have been removed] > > > |
