Transfer Switch Wiring Diagrams and EMS location choice - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Transfer Switch Wiring Diagrams and EMS location choice (/showthread.php?tid=4566) |
Transfer Switch Wiring Diagrams and EMS location choice - ac7880 - 03-25-2007 14:32 Transfer Switch Wiring Diagrams and EMS location decision: Mine is wired like figure B. In this setup, the invertor feeds all circuit breakers. If yours only feeds select circuits, then you are likely wired like figure C. This may help in determing where to install your EMS. http://www.iotaengineering.com/pplib/50rman.pdf Dan 94 BB BMC 37' NM --- In WanderlodgeForum@yahoogroups.com, "Gregory OConnor" > > Rob , then there must be a transfer switch for the inverter after the > shore - genset transfer switch and closer to the Wanderlodge power > fuse pannel????? > > GregoryO'Connor > 94ptRomolandCa > > --- In WanderlodgeForum@yahoogroups.com, "Rob Robinson" > > > > > My mistype Dan. I installed mine after not before the transfer > switch. I > > guess my inverter does not go through the transfer switch. When on > inverter > > I do not get any reading on the EMS display. I do get readings > while the gen > > or shore power are selected. > > > > On 25/03/07, ac7880 > > > > > > Rob, > > > If you wire the EMS before the transfer switch, you have to choose > > > one input for the EMS (shore or generator or invertor). There are > > > multiple inputs into the transfer switch(es), but should only be > one > > > output to the circuit breaker panel > > > > > > So for instance if you choose to use the shore power input into > the > > > EMS, generator and invertor are still available, but the coach is > > > not surge protected from the gen or invertor output. > > > > > > If you install after the transfer switch, shore, gen, invertor > power > > > introduction into the coach are all checked. I installed on the > > > shore cable just prior to the transfer switch due to easier > install > > > location with my setup, and also to ensure the two transfer > switches > > > are also protected from a shore power surge. I distrust the shore > > > power the most. > > > > > > Dan > > > 94 BB BMC 37' NM > > > > > > --- In WanderlodgeForum@yahoogroups.com > > > "Rob Robinson" > > > > > > > > > > > Bill as I understand it, if you have the EMS wired before the > > > Transfer > > > > Switch and either the shore power or the generator malfunction > the > > > > functional one will still be available. In other words, if the > > > genny started > > > > putting out funky power this would only cause the genny to be > > > obstructed. > > > > Correct shore power would still get through. Is this correct??? > > > > > > > > On 25/03/07, Wilhelmus Schreurs > > > > > > > > > > Mike: > > > > > It also has a feature for frequency, so if the frequency or > > > voltage is out > > > > > of whack on the generator the contactor would not pull in. > > > > > Mike, everyone has there own reasons for doing things, and > IMHO, > > > I would > > > > > want the EMS to protect as much as it is capable of. Is this > EMS > > > the perfect > > > > > solution, no, but it is the best there is available that I > have > > > been able to > > > > > find. > > > > > > > > > > Bill 84 FC 35 SB "$quanderlodge" > > > > > Terrace, B.C. Canada > > > > > > > > > > ----- Original Message ---- > > > > > From: mbulriss <mbulriss@ <mbulriss%40yahoo.com>> > > > > > To: WanderlodgeForum@yahoogroups.com > > > > > Sent: Sunday, March 25, 2007 1:56:44 PM > > > > > Subject: [WanderlodgeForum] Re: EMS 50C > > > > > > > > > > Bill, > > > > > > > > > > That's why mine is being installed (when I get to it) only on > the > > > > > > > > > > shore power, so I can still have gen set power. > > > > > > > > > > Mike Bulriss > > > > > > > > > > 1991 WB40 "Texas Minivan" > > > > > > > > > > San Antonio, TX > > > > > > > > > > --- In WanderlodgeForum@ yahoogroups. com, Wilhelmus Schreurs > > > > > > > > > > > > > > > > > > > > > > > > > > > -- > > Rob, Sue & Merlin Robinson > > 94 WLWB > > > > > > [Non-text portions of this message have been removed] > > > Transfer Switch Wiring Diagrams and EMS location choice - Rob Robinson - 03-25-2007 15:03 Yes fig C would appear to be the case. My inverter only feeds certain circuit breakers. For example it does not feed power to engine preheat or the water heater On 25/03/07, ac7880 > > Transfer Switch Wiring Diagrams and EMS location decision: > > Mine is wired like figure B. > > In this setup, the invertor feeds all circuit breakers. If yours > only feeds select circuits, then you are likely wired like figure C. > > This may help in determing where to install your EMS. > > http://www.iotaengineering.com/pplib/50rman.pdf > > Dan 94 BB BMC 37' NM > > --- In WanderlodgeForum@yahoogroups.com > "Gregory OConnor" > > > > > Rob , then there must be a transfer switch for the inverter after > the > > shore - genset transfer switch and closer to the Wanderlodge power > > fuse pannel????? > > > > GregoryO'Connor > > 94ptRomolandCa > > > > --- In WanderlodgeForum@yahoogroups.com > "Rob Robinson" > > > > > > > > My mistype Dan. I installed mine after not before the transfer > > switch. I > > > guess my inverter does not go through the transfer switch. When > on > > inverter > > > I do not get any reading on the EMS display. I do get readings > > while the gen > > > or shore power are selected. > > > > > > On 25/03/07, ac7880 > > > > > > > > Rob, > > > > If you wire the EMS before the transfer switch, you have to > choose > > > > one input for the EMS (shore or generator or invertor). There > are > > > > multiple inputs into the transfer switch(es), but should only > be > > one > > > > output to the circuit breaker panel > > > > > > > > So for instance if you choose to use the shore power input into > > the > > > > EMS, generator and invertor are still available, but the coach > is > > > > not surge protected from the gen or invertor output. > > > > > > > > If you install after the transfer switch, shore, gen, invertor > > power > > > > introduction into the coach are all checked. I installed on the > > > > shore cable just prior to the transfer switch due to easier > > install > > > > location with my setup, and also to ensure the two transfer > > switches > > > > are also protected from a shore power surge. I distrust the > shore > > > > power the most. > > > > > > > > Dan > > > > 94 BB BMC 37' NM > > > > > > > > --- In WanderlodgeForum@yahoogroups.com > > > > > "Rob Robinson" > > > > > > > > > > > > > > Bill as I understand it, if you have the EMS wired before the > > > > Transfer > > > > > Switch and either the shore power or the generator > malfunction > > the > > > > > functional one will still be available. In other words, if the > > > > genny started > > > > > putting out funky power this would only cause the genny to be > > > > obstructed. > > > > > Correct shore power would still get through. Is this > correct??? > > > > > > > > > > On 25/03/07, Wilhelmus Schreurs > > > > > > > > > > > > Mike: > > > > > > It also has a feature for frequency, so if the frequency or > > > > voltage is out > > > > > > of whack on the generator the contactor would not pull in. > > > > > > Mike, everyone has there own reasons for doing things, and > > IMHO, > > > > I would > > > > > > want the EMS to protect as much as it is capable of. Is > this > > EMS > > > > the perfect > > > > > > solution, no, but it is the best there is available that I > > have > > > > been able to > > > > > > find. > > > > > > > > > > > > Bill 84 FC 35 SB "$quanderlodge" > > > > > > Terrace, B.C. Canada > > > > > > > > > > > > ----- Original Message ---- > > > > > > From: mbulriss <mbulriss@ <mbulriss%40yahoo.com>> > > > > > > To: WanderlodgeForum@yahoogroups.com > > > > > > > Sent: Sunday, March 25, 2007 1:56:44 PM > > > > > > Subject: [WanderlodgeForum] Re: EMS 50C > > > > > > > > > > > > Bill, > > > > > > > > > > > > That's why mine is being installed (when I get to it) only > on > > the > > > > > > > > > > > > shore power, so I can still have gen set power. > > > > > > > > > > > > Mike Bulriss > > > > > > > > > > > > 1991 WB40 "Texas Minivan" > > > > > > > > > > > > San Antonio, TX > > > > > > > > > > > > --- In WanderlodgeForum@ yahoogroups. com, Wilhelmus > Schreurs > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > -- > > > Rob, Sue & Merlin Robinson > > > 94 WLWB > > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > > -- Rob, Sue & Merlin Robinson 94 WLWB [Non-text portions of this message have been removed] |
