Suburban Heater - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Suburban Heater (/showthread.php?tid=4632) |
Suburban Heater - dspithaler@... - 04-07-2007 07:10 Guys My friends 79 FC 33' has only one of the propane heaters working. The other two will not come on when the thermostat calls for heat. They have power going to them but the fan will not come on. What is the best way to trouble shoot them? They ran this winter but when they were turned back on they wouldn't come on or even try to. Thanks Don 89 SP 36' Butler, PA ************************************** See what's free at http://www.aol.com. [Non-text portions of this message have been removed] Suburban Heater - Gardner Yeaw - 04-07-2007 12:44 Don, I have Dyna-Trail NT12DC heaters in my 78FC. The thermostat activates the fan relay directly. That in turn supplies power to the module board via a sail switch (sail switch detects the fan is running). You should hear the relay click when the thermostat closes. If the fan doesn't run then either the relay, thermostat, or fan has a problem. Try shorting the two blue wires at the connector, that will eliminate the thermostat. One of the blue wires is connected to +12 volts, the other to the fan relay. Check that one of the blue wires has +12 volts. If you hear the relay click when the thermostat is turned up or the wires are shorted, the problem is likley the motor or wiring from the relay to the motor. In my '78 FC I completely disassembled one of the heaters, several times, and finally got it working. In my case the fan would run. As long as the thermostat is closing the circuit, the fan should run. When I took the motor apart I found that the brushes were close to being worn out. I managed to salvage slightly better brushes from an old heater (One of mine is new). I have been unable to locate a source for brushes and from all I can find, the motors are no longer available. Another thing I found was that the slits in the burner were nearly rusted over so the output was minimal when did work. I pulled the burner out and used a hacksaw blade to clean out the rust and it made a world of difference. I didn't change the size of the slits, I just cleaned them out. --- In WanderlodgeForum@yahoogroups.com, dspithaler@... wrote: > > Guys My friends 79 FC 33' has only one of the propane heaters working. > The other two will not come on when the thermostat calls for heat. They have > power going to them but the fan will not come on. What is the best way to > trouble shoot them? They ran this winter but when they were turned back on they > wouldn't come on or even try to. Thanks > Don > 89 SP 36' > Butler, PA > > > > ************************************** See what's free at http://www.aol.com. > > > [Non-text portions of this message have been removed] > Suburban Heater - dspithaler@... - 04-07-2007 22:09 Thanks Gardner I'll have him check this out Don 89 SP 36' Butler, PA _gcyeaw@..._ (mailto:gcyeaw@...) writes: Don, I have Dyna-Trail NT12DC heaters in my 78FC. The thermostat activates the fan relay directly. That in turn supplies power to the module board via a sail switch (sail switch detects the fan is running). You should hear the relay click when the thermostat closes. If the fan doesn't run then either the relay, thermostat, or fan has a problem. Try shorting the two blue wires at the connector, that will eliminate the thermostat. One of the blue wires is connected to +12 volts, the other to the fan relay. Check that one of the blue wires has +12 volts. If you hear the relay click when the thermostat is turned up or the wires are shorted, the problem is likley the motor or wiring from the relay to the motor. In my '78 FC I completely disassembled one of the heaters, several times, and finally got it working. In my case the fan would run. As long as the thermostat is closing the circuit, the fan should run. When I took the motor apart I found that the brushes were close to being worn out. I managed to salvage slightly better brushes from an old heater (One of mine is new). I have been unable to locate a source for brushes and from all I can find, the motors are no longer available. Another thing I found was that the slits in the burner were nearly rusted over so the output was minimal when did work. I pulled the burner out and used a hacksaw blade to clean out the rust and it made a world of difference. I didn't change the size of the slits, I just cleaned them out..just > > ************************************** See what's free at http://www.aol.com. [Non-text portions of this message have been removed] |
