Spot Lights 89SP 36' - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Spot Lights 89SP 36' (/showthread.php?tid=464) |
Spot Lights 89SP 36' - Don Spithaler - 05-01-2005 13:50 Hi All I'm getting the small things fix right now & my spot lights don't work & I found out it was in the relay that is sending the signal to the left or right light. Does anyone have a source for them? I am also looking for the mecury switch's that are in the outside compartment doors that turn the lights on when you lift up the doors. I found my musical horns had bad speakers. Got them Radio Shack for $39.00 a piece. Sounds as good as new. My air horns had a broken wire in the steering wheel. Thats fixed. Thanks for the advice on what to look for in those two problems. Thanks Don 89 SP 36' Butler, PA Spot Lights 89SP 36' - g_man1146 - 05-01-2005 14:11 Hi Don, When the relay for the spotlights on my '90 went bad, I purchased a slightly heavier duty one at Radio Shack wired and mounted it next to the original board. (Another of those little parasitic draws on your batteries, as one position left or right, keeps the coil energized.) Also replaced the positioning relays as the contacts on the originals were fried. Got those at Radio Shack too. Rich D. '99LXi43' CT --- In WanderlodgeForum@yahoogroups.com, "Don Spithaler" > Hi All > I'm getting the small things fix right now & my spot lights don't > work & I found out it was in the relay that is sending the signal to > the left or right light. Does anyone have a source for them? I am > also > looking for the mecury switch's that are in the outside compartment > doors that > turn the lights on when you lift up the doors. I found my musical > horns had bad speakers. Got them Radio Shack for $39.00 a piece. > Sounds as good as new. My air horns had a broken wire in the steering > wheel. Thats fixed. Thanks for the advice on what to look for in those > two problems. > Thanks Don > 89 SP 36' > Butler, PA Spot Lights 89SP 36' - Don Spithaler - 05-01-2005 16:09 Thanks Rich I though there must be a better way to wire the two spot lights. I guess I'll make another trip to Radio Shack. Don 89SP 36' Butler, PA > Hi Don, > When the relay for the spotlights on my '90 went bad, I purchased a > slightly heavier duty one at Radio Shack wired and mounted it next to > the original board. (Another of those little parasitic draws on your > batteries, as one position left or right, keeps the coil energized.) > Also replaced the positioning relays as the contacts on the originals > were fried. Got those at Radio Shack too. > > Rich D. '99LXi43' CT > > --- In WanderlodgeForum@yahoogroups.com, "Don Spithaler" > > > Hi All > > I'm getting the small things fix right now & my spot lights > don't > > work & I found out it was in the relay that is sending the signal > to > > the left or right light. Does anyone have a source for them? I am > > also > > looking for the mecury switch's that are in the outside compartment > > doors that > > turn the lights on when you lift up the doors. I found my musical > > horns had bad speakers. Got them Radio Shack for $39.00 a piece. > > Sounds as good as new. My air horns had a broken wire in the > steering > > wheel. Thats fixed. Thanks for the advice on what to look for in > those > > two problems. > > Thanks Don > > 89 SP 36' > > Butler, PA |
