Air tank water - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Air tank water (/showthread.php?tid=4654) |
Air tank water - williamcharrison - 04-11-2007 02:02 Is it necessary to drain water from the air tank(s) manually on a 90 SP36, and where are the valves if any? Also, my pressure relief valve doesn't "spit" until almost 150lb pressure, is this normal? Chuck Harrison Akron, Ohio 90 WLSP36 Air tank water - Ralph L. Fullenwider - 04-11-2007 02:13 No that is not the norm. Adjust the air governor or replace it. Safe travels, Ralph and Charolette Fullenwider 84FC35 Ralph's RV Solutions, Duncan, Oklahoma At 02:02 PM 4/11/2007 +0000, you wrote: > Is it necessary to drain water from the air tank(s) manually on >a 90 SP36, and where are the valves if any? Also, my pressure relief >valve doesn't "spit" until almost 150lb pressure, is this normal? >Chuck Harrison >Akron, Ohio >90 WLSP36 > > Air tank water - williamcharrison - 04-11-2007 02:45 -Thanks for the reply Ralph. I still don't know if there are manually operated drain valves on the air tanks though. Also, where do I get the air governor and how do I replace it? -- In WanderlodgeForum@yahoogroups.com, "Ralph L. Fullenwider" > > No that is not the norm. Adjust the air governor or replace it. > > Safe travels, > > Ralph and Charolette Fullenwider > 84FC35 > Ralph's RV Solutions, Duncan, Oklahoma > > At 02:02 PM 4/11/2007 +0000, you wrote: > > Is it necessary to drain water from the air tank(s) manually on > >a 90 SP36, and where are the valves if any? Also, my pressure relief > >valve doesn't "spit" until almost 150lb pressure, is this normal? > >Chuck Harrison > >Akron, Ohio > >90 WLSP36 > > > > > Air tank water - Ralph L. Fullenwider - 04-11-2007 03:03 Chuck: You should have a manual valve on the bottom of each of the air tanks, there are automatic valves that will drain the thank at a certain point(I don't trust those) and there are valves that are manual but have a lanyard that you route to the edge of the coach for draining (recommended) The air governor should be attached to the air compressor on the engine usually head in place by 2 small bolts with a gasket and 2 or 3 air lines attached to the header on the compressor. Generally you will have to adjust the air pressure on the new or existing governor and the adjustment is located under the black rubber cover on one end, The paper work with the new one will tell you how to adjust it. They can be found at any truck store as can the lanyard air tank valves. Stores like truck pro and so forth. Safe travels, Ralph and Charolette Fullenwider 84FC35 Ralph's RV Solutions, Duncan, Oklahoma At 02:45 PM 4/11/2007 +0000, you wrote: >-Thanks for the reply Ralph. I still don't know if there are manually >operated drain valves on the air tanks though. Also, where do I get >the air governor and how do I replace it? > >-- In WanderlodgeForum@yahoogroups.com, "Ralph L. Fullenwider" > > > > > No that is not the norm. Adjust the air governor or replace it. > > > > Safe travels, > > > > Ralph and Charolette Fullenwider > > 84FC35 > > Ralph's RV Solutions, Duncan, Oklahoma > > > > At 02:02 PM 4/11/2007 +0000, you wrote: > > > Is it necessary to drain water from the air tank(s) manually on > > >a 90 SP36, and where are the valves if any? Also, my pressure >relief > > >valve doesn't "spit" until almost 150lb pressure, is this normal? > > >Chuck Harrison > > >Akron, Ohio > > >90 WLSP36 > > > > > > > > > Air tank water - Pete Masterson - 04-11-2007 14:42 Air tank should be governed to about 120 lbs. Air tanks with automatic water release have been in use for some time (probably since the early 80s) so there may not be a manual valve for that purpose. (Check the history at Vintage Birds -- I recall reading about it there...) Pete Masterson '95 Blue Bird Wanderlodge WBDA 42 El Sobrante CA aeonix1@... On Apr 11, 2007, at 7:45 AM, williamcharrison wrote: > -Thanks for the reply Ralph. I still don't know if there are manually > operated drain valves on the air tanks though. Also, where do I get > the air governor and how do I replace it? > > -- In WanderlodgeForum@yahoogroups.com, "Ralph L. Fullenwider" > >> >> No that is not the norm. Adjust the air governor or replace it. >> >> Safe travels, >> >> Ralph and Charolette Fullenwider >> 84FC35 >> Ralph's RV Solutions, Duncan, Oklahoma >> >> At 02:02 PM 4/11/2007 +0000, you wrote: >>> Is it necessary to drain water from the air tank(s) manually on >>> a 90 SP36, and where are the valves if any? Also, my pressure > relief >>> valve doesn't "spit" until almost 150lb pressure, is this normal? >>> Chuck Harrison >>> Akron, Ohio >>> 90 WLSP36 >>> >>> >> > > > > > > Yahoo! Groups Links > > > Air tank water - crissrace - 04-13-2007 04:29 --- In WanderlodgeForum@yahoogroups.com, "williamcharrison" > > Is it necessary to drain water from the air tank(s) manually on > a 90 SP36, and where are the valves if any? Also, my pressure relief > valve doesn't "spit" until almost 150lb pressure, is this normal? > Chuck Harrison > Akron, Ohio > 90 WLSP36 > No that is not normal. You need to service the dryer by rebuilding or replacing it with a rebuilt unit. (D-4 on my coach) Also time for a new governor. You might also check the "Expello" valves on your air tanks that are under the kitchen floor. Very difficult to get to. |
