Tranny Cooler. - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Tranny Cooler. (/showthread.php?tid=4687) |
Tranny Cooler. - kingmtpg - 04-17-2007 04:03 I am a new guy to Blue Bird having just bought a 78 FC. It is a stock 3208 NA. In an earlier post I ask if anyone had a manual I could copy. I have since located the manuals for my coach in IL and they are being forwarded. Thanks for the help on that. I have another question. This coach appears to be completely stock and does not have a trans temp guage. Is it likely the 3208 NA will develope enough heat to require a secondary trans cooler located somewhere else? I have installed them on other trucks I have owned but don't want to waste the time and $ if it is not likely needed. Thanks in advance. Brad Bloxham Yuma, AZ. Tranny Cooler. - erniecarpet@... - 04-17-2007 04:37 Brad, my 83 PT40 has no such gauge. I just keep an eye on oil pressure and water temps. I have driven a lot down south , so you kinda get the feel of it. Ernie Ekberg 83PT40 Livingston, Mt ************************************** See what's free at http://www.aol.com. [Non-text portions of this message have been removed] Tranny Cooler. - erniecarpet@... - 04-17-2007 06:32 My 84 35 FC had a transmission cooler under the rediline compartment. Don't know if this was an add on or factory installed. Ernie Ekberg 83PT40 Livingston, Mt ************************************** See what's free at http://www.aol.com. [Non-text portions of this message have been removed] Tranny Cooler. - Peggy & Ed McStay - 04-17-2007 09:58 --- In WanderlodgeForum@yahoogroups.com, "kingmtpg" wrote: > > I am a new guy to Blue Bird having just bought a 78 FC. It is a > stock 3208 NA. > In an earlier post I ask if anyone had a manual I could copy. I > have since located the manuals for my coach in IL and they are being > forwarded. Thanks for the help on that. > I have another question. This coach appears to be completely stock > and does not have a trans temp guage. Is it likely the 3208 NA will > develope enough heat to require a secondary trans cooler located > somewhere else? I have installed them on other trucks I have owned but > don't want to waste the time and $ if it is not likely needed. Thanks > in advance. Brad Bloxham Yuma, AZ. > brad----- a trans temp gauge is cheap insurance. will cost you about 40 dollar or so and is a heck of a lot cheaper than a tranny overhaul. you want that tranny to run as cool as you can get it to. the more heat the less life you will have in it. get one, install it, and read it all the time. the proper place for the sending unit is in the pan.( i know this will cause a stir but lets see what others say. how about it, who wants to say otherwise,and tell us why. ed and peggy mcstay 1983 FC RB 35FT "lonesome dove" Tranny Cooler. - davidkerryedwards - 04-17-2007 10:00 If your 78 is like my 80, it has a locking convertor. When the convertor is locked, heat generation should not be a big issue. Once you start climbing a hill and the convertor unlocks, heat production increases quickly. On a steep hill, I think it is a major factor in having the engine fan clutch kick on. I don't have a transmission temperature gauge so this is an educated guess. Kerry 82 FC 35 Denver - -- In WanderlodgeForum@yahoogroups.com, "kingmtpg" > > I am a new guy to Blue Bird having just bought a 78 FC. It is a > stock 3208 NA. > In an earlier post I ask if anyone had a manual I could copy. I > have since located the manuals for my coach in IL and they are being > forwarded. Thanks for the help on that. > I have another question. This coach appears to be completely stock > and does not have a trans temp guage. Is it likely the 3208 NA will > develope enough heat to require a secondary trans cooler located > somewhere else? I have installed them on other trucks I have owned but > don't want to waste the time and $ if it is not likely needed. Thanks > in advance. Brad Bloxham Yuma, AZ. > |
