headlights too dim - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: headlights too dim (/showthread.php?tid=469) |
headlights too dim - Smind1@... - 05-01-2005 20:01 I have a 98 LXi, and my headlights are very dim, has anyone had this problem and changed out there lights? Would love to put xenon, not sure if you can?? Amanda, Massachusetts [Non-text portions of this message have been removed] headlights too dim - Gary Miller - 05-02-2005 01:14 Amanda, I'm not sure but I believe your headlights are the four smaller round sealed beam units found on many cars, behind a clear plastic. Many options exist for replacements from street legal to not. A search of some racing parts websites will likely lead you to some good brand names and information, or even ebay. For my two cents however, If they are drastically dim, you may have a wiring problem. Can you check voltage at the headlights? You will hopefully see around 13volts with the engine or chargers running. If not, there's something else going on and someone with a schematic may be able to help out. While you're in there, make sure the lights and inside of the plastic cover are clean, it should be sealed to prevent dirt buildup. Gary Miller 83 FC 33 Wauwatosa, WI --- In WanderlodgeForum@yahoogroups.com, Smind1@a... wrote: > I have a 98 LXi, and my headlights are very dim, has anyone had this problem > and changed out there lights? Would love to put xenon, not sure if you can?? > Amanda, Massachusetts > > > [Non-text portions of this message have been removed] headlights too dim - Tom Warner - 05-02-2005 01:17 Amanda I dont know what your skill level is but if you have and can use a multimeter then check to see what voltage you have at the headlights. I suspect that is your problem and not bad lights. I am not aware that the later birds have this headlight problem but the ones from the 80's sure do. tom 1982 FC35 Vernon Center,NY In the beautiful Mohawk Valley At 08:01 AM 5/2/2005 -0400, you wrote: >I have a 98 LXi, and my headlights are very dim, has anyone had this problem >and changed out there lights? Would love to put xenon, not sure if you can?? > Amanda, Massachusetts headlights too dim - Stephen Birtles - 05-02-2005 01:42 you can go with hid lights just measure inside the light to make sure you you have the clearance for the modules they are longer than a regular bulb and also make sure you have room for the ballasts something else to check make sure you disable day time running lights if you have them, It is a fair bit of work to install but it can be done on most vehicles DO NOT SCRIMP on the money you spend buy a kit that is produced by one company eg Bosch Hella or Osram never buy a kit that is put together from parts from different supppliers like you see on ebay. You will find that you only use them on low beam the time it takes to warm and fire for high beam you usually have to turn them off for oncoming traffic. You might want to look at Silverstar halogen bulbs from Sylvania much cheaper but a lot brighter than Standard Halogen Cape0001 77fc35 http://www.capeinnovation.com --- In WanderlodgeForum@yahoogroups.com, Smind1@a... wrote: > I have a 98 LXi, and my headlights are very dim, has anyone had this problem > and changed out there lights? Would love to put xenon, not sure if you can?? > Amanda, Massachusetts > > > [Non-text portions of this message have been removed] headlights too dim - Smind1@... - 05-02-2005 19:12 thanks so much for all your input, I will have my mechanic check the voltage, clean the plastic, (actually I think we did that) and then look into "high end" hid lights. thank you all for your help, I really appreciate it. Amanda, Massachusetts [Non-text portions of this message have been removed] |
