PT cruise control - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: PT cruise control (/showthread.php?tid=4710) |
PT cruise control - Scott Forman - 04-20-2007 10:55 I have made a deal to purchase a PT38, so if everything goes well, I will have many questions as I move my learning curve from FC to PT. First question: seller says cruise control is not operational, he does not know why. Are there any common cruise problems that I should try to troubleshoot once I get the coach? Thanks Scott Forman 82 FC35RB-for sale Should have an 86 PT38 soon PT cruise control - Ralph L. Fullenwider - 04-20-2007 11:03 Check the Bosh relay that is located just under the Bendix control box. This is located behind the grill on the curb side. The connectors there will have a tendency to corrode and I have had that relay go bad in the past. Also check the related wiring in the same area. Safe travels, Ralph and Charolette Fullenwider 84FC35 Ralph's RV Solutions, Duncan, Oklahoma At 10:55 PM 4/20/2007 +0000, you wrote: >I have made a deal to purchase a PT38, so if everything goes well, I >will have many questions as I move my learning curve from FC to PT. > >First question: seller says cruise control is not operational, he does >not know why. Are there any common cruise problems that I should try >to troubleshoot once I get the coach? > >Thanks >Scott Forman >82 FC35RB-for sale >Should have an 86 PT38 soon > > PT cruise control - Scott Forman - 06-03-2007 14:07 Ralph..."behind the grill on the curb side"...do you mean behind the curb-side front exterior swing-out panel, the area in front of the co- pilot seat? If so, I looked in there, did not see anything electronic in there except the brain for The Horn. Help???? Scott --- In WanderlodgeForum@yahoogroups.com, "Ralph L. Fullenwider" > > Check the Bosh relay that is located just under the Bendix control box. > This is located behind the grill on the curb side. The connectors there > will have a tendency to corrode and I have had that relay go bad in the > past. Also check the related wiring in the same area. > > Safe travels, > > Ralph and Charolette Fullenwider > 84FC35 > Ralph's RV Solutions, Duncan, Oklahoma > > At 10:55 PM 4/20/2007 +0000, you wrote: > >I have made a deal to purchase a PT38, so if everything goes well, I > >will have many questions as I move my learning curve from FC to PT. > > > >First question: seller says cruise control is not operational, he does > >not know why. Are there any common cruise problems that I should try > >to troubleshoot once I get the coach? > > > >Thanks > >Scott Forman > >82 FC35RB-for sale > >Should have an 86 PT38 soon > > > > > PT cruise control - Ralph L. Fullenwider - 06-03-2007 15:17 Scott: We are talking about the PT right? Then on the curb side rear, there is a grill that lifts up for access to the side of the engine, batteries and so forth. Open that grill and on a plate above the batteries there will be the bendix control, a couple of valves, a cylinder with a cable housing. It also may be behind a steel cover toward the fire wall but in the same compartment. There should be a bosh relay in that same group of items. Safe travels, Ralph and Charolette Fullenwider 84FC35 Duncan, Oklahoma At 02:07 AM 6/4/2007 +0000, you wrote: >Ralph..."behind the grill on the curb side"...do you mean behind the >curb-side front exterior swing-out panel, the area in front of the co- >pilot seat? If so, I looked in there, did not see anything >electronic in there except the brain for The Horn. Help???? > >Scott > >--- In WanderlodgeForum@yahoogroups.com, "Ralph L. Fullenwider" > > > > > Check the Bosh relay that is located just under the Bendix control >box. > > This is located behind the grill on the curb side. The connectors >there > > will have a tendency to corrode and I have had that relay go bad in >the > > past. Also check the related wiring in the same area. > > > > Safe travels, > > > > Ralph and Charolette Fullenwider > > 84FC35 > > Ralph's RV Solutions, Duncan, Oklahoma > > > > At 10:55 PM 4/20/2007 +0000, you wrote: > > >I have made a deal to purchase a PT38, so if everything goes well, >I > > >will have many questions as I move my learning curve from FC to PT. > > > > > >First question: seller says cruise control is not operational, he >does > > >not know why. Are there any common cruise problems that I should >try > > >to troubleshoot once I get the coach? > > > > > >Thanks > > >Scott Forman > > >82 FC35RB-for sale > > >Should have an 86 PT38 soon > > > > PT cruise control - Scott Forman - 06-03-2007 23:57 Gotcha...you can see my front-engine mentality, someone says "grill" and I instinctively think of the front of the coach. Thanks for the help Scott --- In WanderlodgeForum@yahoogroups.com, "Ralph L. Fullenwider" > > Scott: > > We are talking about the PT right? Then on the curb side rear, there is a > grill that lifts up for access to the side of the engine, batteries and so > forth. Open that grill and on a plate above the batteries there will be the > bendix control, a couple of valves, a cylinder with a cable housing. > > It also may be behind a steel cover toward the fire wall but in the same > compartment. There should be a bosh relay in that same group of items. > > Safe travels, > > Ralph and Charolette Fullenwider > 84FC35 > Duncan, Oklahoma > > At 02:07 AM 6/4/2007 +0000, you wrote: > >Ralph..."behind the grill on the curb side"...do you mean behind the > >curb-side front exterior swing-out panel, the area in front of the co- > >pilot seat? If so, I looked in there, did not see anything > >electronic in there except the brain for The Horn. Help???? > > > >Scott > > > >--- In WanderlodgeForum@yahoogroups.com, "Ralph L. Fullenwider" > > > > > > > > Check the Bosh relay that is located just under the Bendix control > >box. > > > This is located behind the grill on the curb side. The connectors > >there > > > will have a tendency to corrode and I have had that relay go bad in > >the > > > past. Also check the related wiring in the same area. > > > > > > Safe travels, > > > > > > Ralph and Charolette Fullenwider > > > 84FC35 > > > Ralph's RV Solutions, Duncan, Oklahoma > > > > > > At 10:55 PM 4/20/2007 +0000, you wrote: > > > >I have made a deal to purchase a PT38, so if everything goes well, > >I > > > >will have many questions as I move my learning curve from FC to PT. > > > > > > > >First question: seller says cruise control is not operational, he > >does > > > >not know why. Are there any common cruise problems that I should > >try > > > >to troubleshoot once I get the coach? > > > > > > > >Thanks > > > >Scott Forman > > > >82 FC35RB-for sale > > > >Should have an 86 PT38 soon > > > > > > > PT cruise control - erniecarpet@... - 06-23-2007 11:10 Scott- in the rear of the coach by the racor, is where my cruise control is located. I had an air leak in one of the valves that was leaking. i took that apart and cleaned it. After 4 years, she works great. Ernie Ekberg 83PT40 Livingston, Mt ************************************** See what's free at http://www.aol.com. [Non-text portions of this message have been removed] PT cruise control - Scott Forman - 06-23-2007 13:51 OK...I replaces the relay and checked all the wiring, which all looks fine, and still no dice. Any other suggestions? Scott --- In WanderlodgeForum@yahoogroups.com, "Ralph L. Fullenwider" > > Check the Bosh relay that is located just under the Bendix control box. > This is located behind the grill on the curb side. The connectors there > will have a tendency to corrode and I have had that relay go bad in the > past. Also check the related wiring in the same area. > > Safe travels, > > Ralph and Charolette Fullenwider > 84FC35 > Ralph's RV Solutions, Duncan, Oklahoma > > At 10:55 PM 4/20/2007 +0000, you wrote: > >I have made a deal to purchase a PT38, so if everything goes well, I > >will have many questions as I move my learning curve from FC to PT. > > > >First question: seller says cruise control is not operational, he does > >not know why. Are there any common cruise problems that I should try > >to troubleshoot once I get the coach? > > > >Thanks > >Scott Forman > >82 FC35RB-for sale > >Should have an 86 PT38 soon > > > > > PT cruise control - putneyflash - 06-24-2007 12:34 --- In WanderlodgeForum@yahoogroups.com, "Scott Forman" <sforman@...> wrote: >Scott an air cylnder pulls the throttle. look at the fuel lever and you will find a cable connected to it , it could be the cylinder is froze or airis not geeting to the cylinder. This is how it is on my '84 pt 40 re K...I replaces the relay and checked all the wiring, which all looks > fine, and still no dice. Any other suggestions? > > Scott > > --- In WanderlodgeForum@yahoogroups.com, "Ralph L. Fullenwider" > > > > > Check the Bosh relay that is located just under the Bendix control > box. > > This is located behind the grill on the curb side. The connectors > there > > will have a tendency to corrode and I have had that relay go bad in > the > > past. Also check the related wiring in the same area. > > > > Safe travels, > > > > Ralph and Charolette Fullenwider > > 84FC35 > > Ralph's RV Solutions, Duncan, Oklahoma > > > > At 10:55 PM 4/20/2007 +0000, you wrote: > > >I have made a deal to purchase a PT38, so if everything goes well, > I > > >will have many questions as I move my learning curve from FC to PT. > > > > > >First question: seller says cruise control is not operational, he > does > > >not know why. Are there any common cruise problems that I should > try > > >to troubleshoot once I get the coach? > > > > > >Thanks > > >Scott Forman > > >82 FC35RB-for sale > > >Should have an 86 PT38 soon > > > > > > > > > |
