How tall is my '86 PT-40 going to be? - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: How tall is my '86 PT-40 going to be? (/showthread.php?tid=4717) |
How tall is my '86 PT-40 going to be? - Ryan Wright - 04-21-2007 16:21 I'm thinking I am going to have to start paying attention to those "low clearance" signs they put on overpasses... ![]() -Ryan How tall is my '86 PT-40 going to be? - Gregory OConnor - 04-22-2007 04:49 Something you may not have noticed is a Truckroute posted sign which limits the path of travel for commercial vehicles. If you choose the T route and assume the height is 13 foot you are good to go. One mistake folks make is hitting turn outs on steep grades when people are behind them. The problem with the turnouts are most often reentering the roadway you are unable to regain the max speed you were at when you hit the turn out. New oncomming traffic now is in danger of hitting you. I ran the 74 grade from PalmSprings toward Hemet Ca lastweekend in 2nd gear and under 2000 rpm, passed maybe 8 turn outs and scored a 90 at the crest of the hill. The first 50 gave me the finger then the last 20 waved a thankyou. The pull over rule about allowing faster traffic pass is trumped by the hazzard you create when you re-enter. ( I turn off the hazzards after about 5 cars are trailing because I dont want to further piss off the first in line) When you enter or drive a 55 plus speed roadway, always show your hazzzard lights if your speed is >10mph under the posted speedlimit. Using hazzard lights to enter a freeway helps open traffic up better , a left turn signal often alerts traffic that a bus is trying to get infront of them. they seem to move over for a hazzard and you want to maintain acceleration upto speed and not have to hold off for a unkind driver that will not yield. Driving in fog is easy. Dont drive in fog use red tape to highlight 1-water temp gauge 2-rpm gauge 3- hazzard light button. (engine oil tem should not go over235 and water stay under 200) learn the fuction of the retarder and remember to shut it off( I will not post as your retarder is more horsepower than the 94 I have) I allow the fleetwoods to pass on a down hill and never let the rps go over 2000. The rule of the road is never decend faster than you can climb. I use the brakes to slow the engine to 1500rpm if needed and reduce the allison tranny to 4 ( if the tranny is in 5 selecting 4 will not cause a down shift it will only limit the up shift so you may have to attempt a downshift by accelerating) GregoryO'Connor 94ptRomolandCa --- In WanderlodgeForum@yahoogroups.com, "Ryan Wright" > > I'm thinking I am going to have to start paying attention to those > "low clearance" signs they put on overpasses... ![]() > > -Ryan > |
