Tachometer, AC outlets - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Tachometer, AC outlets (/showthread.php?tid=4718) |
Tachometer, AC outlets - amweath - 04-22-2007 04:58 My tach moves all over the scale when running at highway speeds. What drives the tach on a 6V92. Another problem was most of my AC outlets went dead while using my drill motor I had the generator running. I have to assume the gen. was putting out because the AC recepticle where the microwave is plugged in was still hot. I checked breakers in the AC box that is located in one of the wardrobe closets In all the manuals I got, there is no diagram of the AC circuitry - several diagrams of the DC. Concerning my fresh water tank - on futher investigation I have no leak. Water must have been spilled when filling at the vent. Art Weatherly Riverside Ca. '85 PT 36 Tachometer, AC outlets - erniecarpet@... - 04-22-2007 05:51 The built in vacs, I believe, were an option. Ernie Ekberg 83PT40 Livingston, Mt --central vac in mine ************************************** See what's free at http://www.aol.com. [Non-text portions of this message have been removed] Tachometer, AC outlets - Leroy Eckert - 04-22-2007 06:40 When your generator is running and working properly you should have 120v on leg one and leg two gauges as you would if plugged into shore power. The associated amp gauges tell you the usage on each leg. Is that the case? There also are breakers on the box behind the gen set, at least there are on mine. Spend some time understanding what all the gauges in the coach tell you. When you get that down it makes it easier to know where to start looking<<<<.>>>> Leroy Eckert 1990 WB-40"Smoke N Mirrors" Niceville, FL ----- Original Message ----- From: amweath To: WanderlodgeForum@yahoogroups.com Sent: Sunday, April 22, 2007 11:58 AM Subject: [WanderlodgeForum] Tachometer, AC outlets My tach moves all over the scale when running at highway speeds. What drives the tach on a 6V92. Another problem was most of my AC outlets went dead while using my drill motor I had the generator running. I have to assume the gen. was putting out because the AC recepticle where the microwave is plugged in was still hot. I checked breakers in the AC box that is located in one of the wardrobe closets In all the manuals I got, there is no diagram of the AC circuitry - several diagrams of the DC. Concerning my fresh water tank - on futher investigation I have no leak. Water must have been spilled when filling at the vent. Art Weatherly Riverside Ca. '85 PT 36 [Non-text portions of this message have been removed] Tachometer, AC outlets - Leroy Eckert - 04-22-2007 06:56 One other thing I failed to mention. See if you have a GFI in the coach. Reset it and see what happens. On my coach the bay outlets work on the gen set and shore power, not the inverter. Sounds like you were using interior outlets? Leroy Eckert 1990 WB-40"Smoke N Mirrors" Niceville, FL Are there any orange groves left in Riverside? I spent 25 years of my life there. ----- Original Message ----- From: amweath To: WanderlodgeForum@yahoogroups.com Sent: Sunday, April 22, 2007 11:58 AM Subject: [WanderlodgeForum] Tachometer, AC outlets My tach moves all over the scale when running at highway speeds. What drives the tach on a 6V92. Another problem was most of my AC outlets went dead while using my drill motor I had the generator running. I have to assume the gen. was putting out because the AC recepticle where the microwave is plugged in was still hot. I checked breakers in the AC box that is located in one of the wardrobe closets In all the manuals I got, there is no diagram of the AC circuitry - several diagrams of the DC. Concerning my fresh water tank - on futher investigation I have no leak. Water must have been spilled when filling at the vent. Art Weatherly Riverside Ca. '85 PT 36 [Non-text portions of this message have been removed] Tachometer, AC outlets - Art Weatherly - 04-22-2007 08:59 Reset both main breakers and that fixed it. They didn't look tripped. Now if I could figure out where the built-in vacume cleaner is. Art Weatherly Riverside Ca. '85 PT 36 Very few orange groves left in the inland area. There are now miles of groves east of Bakersfield along HYW 46 ----- Original Message ----- From: Leroy Eckert To: WanderlodgeForum@yahoogroups.com Sent: Sunday, April 22, 2007 11:56 AM Subject: [SPAM] Re: [WanderlodgeForum] Tachometer, AC outlets One other thing I failed to mention. See if you have a GFI in the coach. Reset it and see what happens. On my coach the bay outlets work on the gen set and shore power, not the inverter. Sounds like you were using interior outlets? Leroy Eckert 1990 WB-40"Smoke N Mirrors" Niceville, FL Are there any orange groves left in Riverside? I spent 25 years of my life there. ----- Original Message ----- From: amweath To: WanderlodgeForum@yahoogroups.com Sent: Sunday, April 22, 2007 11:58 AM Subject: [WanderlodgeForum] Tachometer, AC outlets My tach moves all over the scale when running at highway speeds. What drives the tach on a 6V92. Another problem was most of my AC outlets went dead while using my drill motor I had the generator running. I have to assume the gen. was putting out because the AC recepticle where the microwave is plugged in was still hot. I checked breakers in the AC box that is located in one of the wardrobe closets In all the manuals I got, there is no diagram of the AC circuitry - several diagrams of the DC. Concerning my fresh water tank - on futher investigation I have no leak. Water must have been spilled when filling at the vent. Art Weatherly Riverside Ca. '85 PT 36 [Non-text portions of this message have been removed] [Non-text portions of this message have been removed] Tachometer, AC outlets - bloomas - 04-22-2007 09:12 ----- Original Message ----- From: Art Weatherly To: WanderlodgeForum@yahoogroups.com Sent: Sunday, April 22, 2007 3:59 PM Subject: Re: [SPAM] Re: [WanderlodgeForum] Tachometer, AC outlets If yours is like mine it did not have one. Bob Loomas 1985 PT 36 Reset both main breakers and that fixed it. They didn't look tripped. Now if I could figure out where the built-in vacume cleaner is. Art Weatherly Riverside Ca. '85 PT 36 Very few orange groves left in the inland area. There are now miles of groves east of Bakersfield along HYW 46 ----- Original Message ----- From: Leroy Eckert To: WanderlodgeForum@yahoogroups.com Sent: Sunday, April 22, 2007 11:56 AM Subject: [SPAM] Re: [WanderlodgeForum] Tachometer, AC outlets One other thing I failed to mention. See if you have a GFI in the coach. Reset it and see what happens. On my coach the bay outlets work on the gen set and shore power, not the inverter. Sounds like you were using interior outlets? Leroy Eckert 1990 WB-40"Smoke N Mirrors" Niceville, FL Are there any orange groves left in Riverside? I spent 25 years of my life there. ----- Original Message ----- From: amweath To: WanderlodgeForum@yahoogroups.com Sent: Sunday, April 22, 2007 11:58 AM Subject: [WanderlodgeForum] Tachometer, AC outlets My tach moves all over the scale when running at highway speeds. What drives the tach on a 6V92. Another problem was most of my AC outlets went dead while using my drill motor I had the generator running. I have to assume the gen. was putting out because the AC recepticle where the microwave is plugged in was still hot. I checked breakers in the AC box that is located in one of the wardrobe closets In all the manuals I got, there is no diagram of the AC circuitry - several diagrams of the DC. Concerning my fresh water tank - on futher investigation I have no leak. Water must have been spilled when filling at the vent. Art Weatherly Riverside Ca. '85 PT 36 [Non-text portions of this message have been removed] [Non-text portions of this message have been removed] [Non-text portions of this message have been removed] Tachometer, AC outlets - Gregory OConnor - 04-22-2007 09:12 Wonder why it tripped with a drillmotor? Tripped circuits like blown fuses are usualy a result and not a cause. If you rewire anything remember the ground is not bonded to the common like is done at a household panel GregoryO'Connor 94ptRomolandCa --- In WanderlodgeForum@yahoogroups.com, "Art Weatherly" > > Reset both main breakers and that fixed it. They didn't look tripped. > > Now if I could figure out where the built-in vacume cleaner is. > > Art Weatherly > Riverside Ca. > '85 PT 36 > > Very few orange groves left in the inland area. There are now miles of groves east of Bakersfield along HYW 46 > ----- Original Message ----- > From: Leroy Eckert > To: WanderlodgeForum@yahoogroups.com > Sent: Sunday, April 22, 2007 11:56 AM > Subject: [SPAM] Re: [WanderlodgeForum] Tachometer, AC outlets > > > One other thing I failed to mention. See if you have a GFI in the coach. Reset it and see what happens. On my coach the bay outlets work on the gen set and shore power, not the inverter. Sounds like you were using interior outlets? > > Leroy Eckert > 1990 WB-40"Smoke N Mirrors" > Niceville, FL > Are there any orange groves left in Riverside? I spent 25 years of my life there. > > ----- Original Message ----- > From: amweath > To: WanderlodgeForum@yahoogroups.com > Sent: Sunday, April 22, 2007 11:58 AM > Subject: [WanderlodgeForum] Tachometer, AC outlets > > My tach moves all over the scale when running at highway speeds. > What drives the tach on a 6V92. > > Another problem was most of my AC outlets went dead while using my > drill motor I had the generator running. I have to assume the gen. was > putting out because the AC recepticle where the microwave is plugged > in was still hot. I checked breakers in the AC box that is located in > one of the wardrobe closets > > In all the manuals I got, there is no diagram of the AC circuitry - > several diagrams of the DC. > > Concerning my fresh water tank - on futher investigation I have no > leak. Water must have been spilled when filling at the vent. > > Art Weatherly > Riverside Ca. > '85 PT 36 > > [Non-text portions of this message have been removed] > > > > > > [Non-text portions of this message have been removed] > |
