Solar Charger - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Solar Charger (/showthread.php?tid=4810) |
Solar Charger - kingmtpg - 05-02-2007 06:42 New Bird guy here again. I have had a 14x23" solar panel in my shop for a couple of years. It came off a 5th wheel I had bought, sold the 5th wheel and kept the solar panel. It was wired directly to the battery in the 5th wheel when I got it, no meter or anything. I am thinking of mounting it on my new to me (old) Bird. I am wondering if I can wire it into 1 set of 2 6 volt batteries (12 volts), and will that trickle charge all 4 batteries since they all share the same output/input lugs? Or maybe this whole idea is a bad one? Thanks in advance and for the other help also. Brad Bloxham 78FC, 3208, Yuma AZ. Solar Charger - worktohobby - 05-02-2007 07:10 Hello, Not a bad idea. Make sure that at the very least it has a blocking diode to insure that at night the batteries don't discharge into the solar cell. Your solar cell is small enough versus your battery bank that you really don't have to worrry about overcharging. You can get an inexpensive voltage regulator if one is not built into the unit. For best efficiancy, and high cost, look for one with maximum power point tracking (mppt). Regards, Don Duncan 1987 PT40 Beaverton, Oregon Solar Charger - Stephen Birtles - 05-02-2007 09:23 Brad please send me your address again thanks Stephen 77fc35 --- In WanderlodgeForum@yahoogroups.com, "kingmtpg" > > New Bird guy here again. I have had a 14x23" solar panel in my shop for > a couple of years. It came off a 5th wheel I had bought, sold the 5th > wheel and kept the solar panel. It was wired directly to the battery in > the 5th wheel when I got it, no meter or anything. I am thinking of > mounting it on my new to me (old) Bird. I am wondering if I can wire it > into 1 set of 2 6 volt batteries (12 volts), and will that trickle > charge all 4 batteries since they all share the same output/input lugs? > Or maybe this whole idea is a bad one? Thanks in advance and for the > other help also. Brad Bloxham 78FC, 3208, Yuma AZ. > Solar Charger - Mike Hohnstein - 05-02-2007 13:53 won't hurt a thing, however you may want to check the voltage output before you go to the trouble of installing. MH ----- Original Message ----- From: kingmtpg To: WanderlodgeForum@yahoogroups.com Sent: Wednesday, May 02, 2007 12:42 PM Subject: [WanderlodgeForum] Solar Charger New Bird guy here again. I have had a 14x23" solar panel in my shop for a couple of years. It came off a 5th wheel I had bought, sold the 5th wheel and kept the solar panel. It was wired directly to the battery in the 5th wheel when I got it, no meter or anything. I am thinking of mounting it on my new to me (old) Bird. I am wondering if I can wire it into 1 set of 2 6 volt batteries (12 volts), and will that trickle charge all 4 batteries since they all share the same output/input lugs? Or maybe this whole idea is a bad one? Thanks in advance and for the other help also. Brad Bloxham 78FC, 3208, Yuma AZ. [Non-text portions of this message have been removed] Solar Charger - Gregory OConnor - 05-02-2007 15:34 Brad, if the charger does not keep up with the rested drain of the bank, it wont maintain anything, will just extend time befor a marginal amp reading.. Maybe you can hook it up to a single isolated genset battery or set one up for that purpose. GregoryO'Connor 94ptRomolandCa --- In WanderlodgeForum@yahoogroups.com, "kingmtpg" wrote: > > New Bird guy here again. I have had a 14x23" solar panel in my shop for > a couple of years. It came off a 5th wheel I had bought, sold the 5th > wheel and kept the solar panel. It was wired directly to the battery in > the 5th wheel when I got it, no meter or anything. I am thinking of > mounting it on my new to me (old) Bird. I am wondering if I can wire it > into 1 set of 2 6 volt batteries (12 volts), and will that trickle > charge all 4 batteries since they all share the same output/input lugs? > Or maybe this whole idea is a bad one? Thanks in advance and for the > other help also. Brad Bloxham 78FC, 3208, Yuma AZ. > |
