84FC35 ride height - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: 84FC35 ride height (/showthread.php?tid=4818) |
84FC35 ride height - Keith Strehle - 05-03-2007 03:52 How difficult is it to adjust the ride height on my 84FC? What is the proper ride height and where do I measure from? Should I have someone do this for me? Keith 84FC35 84FC35 ride height - Ralph L. Fullenwider - 05-03-2007 04:05 Keith: There should be a blue folder in your blue box for the ridewell air suspension system. It will direct you on how to set the ride height and you can do it yourself. It is time consuming though and best to make small adjustments, run the coach around the block then measure, then adjust and go around the block and so forth. The front will be aprox 1 inch lower in the front and that is normal. Safe travels, Ralph and Charolette Fullenwider 84FC35 Ralph's RV Solutions, Duncan, Oklahoma At 03:52 PM 5/3/2007 +0000, you wrote: >How difficult is it to adjust the ride height on my 84FC? What is the >proper ride height and where do I measure from? > >Should I have someone do this for me? > >Keith >84FC35 > > > 84FC35 ride height - Keith Strehle - 05-03-2007 05:49 Thanks Ralph, I'll check it out... Keith 84FC --- In WanderlodgeForum@yahoogroups.com, "Ralph L. Fullenwider" > > Keith: > > There should be a blue folder in your blue box for the ridewell air > suspension system. It will direct you on how to set the ride height and you > can do it yourself. It is time consuming though and best to make small > adjustments, run the coach around the block then measure, then adjust and > go around the block and so forth. The front will be aprox 1 inch lower in > the front and that is normal. > > Safe travels, > > Ralph and Charolette Fullenwider > 84FC35 > Ralph's RV Solutions, Duncan, Oklahoma > > At 03:52 PM 5/3/2007 +0000, you wrote: > >How difficult is it to adjust the ride height on my 84FC? What is the > >proper ride height and where do I measure from? > > > >Should I have someone do this for me? > > > >Keith > >84FC35 > > > > > > > |
