How do I remove a furnace - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: How do I remove a furnace (/showthread.php?tid=4839) |
How do I remove a furnace - olson_phil - 05-05-2007 07:50 I have a hot water pipe that is leaking behind the rear furnace in my 83FC35SB. I need to remove the furnace that is under the bed to get to the leaking pipe. Any ideas on how to remove this furnace? I can only find a couple of screws on the hot air side that connect to ducts and a vent under the bed. After removing those it still does not budge. There must be something else I am missing. Any suggestions? Thanks. Phil Olson Appleton, Wi 83FC35SB How do I remove a furnace - Eric Johnson - 05-05-2007 08:29 Hello Phil, Assuming your coach is configured like mine, with two separate bunks, the water tank, water heater and furnace all under the driver side bunk, I can offer the following suggestions on furnace removal. First shut off LPG supply valves at the LPG tank and at the access door on the outside of the coach behind the Dometic refrigerator. Then shut off AC power to the coach. 1. Remove 4 screws on the chrome vent plate on the outside and extract the inlet and exhaust vent pipes. 2. Remove the 2 screws holding the register plaate to the side of the bunk and remove the register. 3. Remove the small screws that fasten the hot air duct to the furnace outlet. This is a tight fit on mine and it takes a little persuasion to get the air duct off the furnace outlet. 4. Remove the furnace outlet from the furnace box by flipping the two latches to the open position. 5. Remove the screw that is located at the bottom of the furnace box that secures the box to the plywood floor below. 6. Disconnect the LPG line and electrical wires. 7. Remove the furnace. Hope you find this helpful. It's as close as I can come from memory. Good luck with your leak. My leak turned out to be the water heater when I finally got to it. Eric in San Antonio 84FC35SBWL2 --- In WanderlodgeForum@yahoogroups.com, "olson_phil" > > I have a hot water pipe that is leaking behind the rear furnace in my > 83FC35SB. I need to remove the furnace that is under the bed to get > to the leaking pipe. Any ideas on how to remove this furnace? I can > only find a couple of screws on the hot air side that connect to ducts > and a vent under the bed. After removing those it still does not > budge. There must be something else I am missing. Any suggestions? > > Thanks. > > Phil Olson > Appleton, Wi > 83FC35SB > How do I remove a furnace - olson_phil - 05-05-2007 12:57 Thanks for your help, I was able to get it out. What a PITA. Now lets see if I can get it all put back together again. Phil Olson Appleton, WI 83FC35SB --- In WanderlodgeForum@yahoogroups.com, "Eric Johnson" wrote: > > Hello Phil, > Assuming your coach is configured like mine, with two separate bunks, the water tank, > water heater and furnace all under the driver side bunk, I can offer the following > suggestions on furnace removal. > > First shut off LPG supply valves at the LPG tank and at the access door on the outside of > the coach behind the Dometic refrigerator. Then shut off AC power to the coach. > > 1. Remove 4 screws on the chrome vent plate on the outside and extract the inlet and > exhaust vent pipes. > > 2. Remove the 2 screws holding the register plaate to the side of the bunk and remove > the register. > > 3. Remove the small screws that fasten the hot air duct to the furnace outlet. This is a > tight fit on mine and it takes a little persuasion to get the air duct off the furnace outlet. > > 4. Remove the furnace outlet from the furnace box by flipping the two latches to the open > position. > > 5. Remove the screw that is located at the bottom of the furnace box that secures the box > to the plywood floor below. > > 6. Disconnect the LPG line and electrical wires. > > 7. Remove the furnace. > > Hope you find this helpful. It's as close as I can come from memory. Good luck with your > leak. My leak turned out to be the water heater when I finally got to it. > > Eric in San Antonio > 84FC35SBWL2 > > > --- In WanderlodgeForum@yahoogroups.com, "olson_phil" > > > > I have a hot water pipe that is leaking behind the rear furnace in my > > 83FC35SB. I need to remove the furnace that is under the bed to get > > to the leaking pipe. Any ideas on how to remove this furnace? I can > > only find a couple of screws on the hot air side that connect to ducts > > and a vent under the bed. After removing those it still does not > > budge. There must be something else I am missing. Any suggestions? > > > > Thanks. > > > > Phil Olson > > Appleton, Wi > > 83FC35SB > > > |
