Refrigerator quit - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Refrigerator quit (/showthread.php?tid=4844) |
Refrigerator quit - Stephen Quandt - 05-05-2007 23:24 My coach has a Dometic NDR-1292 refrigerator / freezer unit. It has been running perfectly since the end of Feb when I installed a new thermocouple in it until last Thursday when it abruptly quit. It cycles between gas and electric with no problem both produce heat. There are no signs of ammonia leak, no loud gurgles to indicate a blockage. All the fuses are good. The resistance on the temperature sensor tell me that it is closed calling for cooling. I am stumped! Steve Quandt 1993 PT-40 Iron Mountain, MI Refrigerator quit - bloomas - 05-06-2007 01:02 ----- Original Message ----- From: "Stephen Quanta" To: Sent: Sunday, May 06, 2007 6:24 AM Subject: [WanderlodgeForum] Refrigerator quit Hi Steve Are the coils getting hot to the touch? If Not you probably have a air lock. Bob Loomis > My coach has a Domestic NOR-1292 refrigerator / freezer unit. It has been > running perfectly since the end of Feb when I installed a new thermocouple > in it until last Thursday when it abruptly quit. > > It cycles between gas and electric with no problem both produce heat. > There are no signs of ammonia leak, no loud gurgles to indicate a > blockage. All the fuses are good. The resistance on the temperature > sensor tell me that it is closed calling for cooling. I am stumped! > > Steve Quanta > 1993 PT-40 > Iron Mountain, MI > > > > Yahoo! Groups Links > > > > Refrigerator quit - Stephen Quandt - 05-06-2007 04:44 Bob, The coils are cold. How does one fix an air lock? Thanks Steve Quandt 1993 PT-40 Iron Mountain, MI ----- Original Message ---- From: bloomas To: WanderlodgeForum@yahoogroups.com Sent: Sunday, May 6, 2007 8:02:29 AM Subject: Re: [WanderlodgeForum] Refrigerator quit ----- Original Message ----- From: "Stephen Quanta" To: Sent: Sunday, May 06, 2007 6:24 AM Subject: [WanderlodgeForum] Refrigerator quit Hi Steve Are the coils getting hot to the touch? If Not you probably have a air lock. Bob Loomis > My coach has a Domestic NDR-1292 refrigerator / freezer unit. It has been > running perfectly since the end of Feb when I installed a new thermocouple > in it until last Thursday when it abruptly quit. > > It cycles between gas and electric with no problem both produce heat. > There are no signs of ammonia leak, no loud gurgles to indicate a > blockage. All the fuses are good. The resistance on the temperature > sensor tell me that it is closed calling for cooling. I am stumped! > > Steve Quanta > 1993 PT-40 > Iron Mountain, MI > > > > Yahoo! Groups Links > > > > [Non-text portions of this message have been removed] Refrigerator quit - robertnloomas - 05-06-2007 07:06 --- In WanderlodgeForum@yahoogroups.com, Stephen Quandt < smquandt@...> wrote:Steve You will have to pull the refrigerator out where you can rotate it 360 deg. Do it slowlySometime that will do the trick.You can do it a few times going in the same direction eachTime you rotate it. By the way rotating the unit is end over end. Before reinstalling the unit plug it In and check to see if the unit is now working. Do not forget you will need 12 volt control powerIn order for the controls to work. Bob Loomas 1985 PT 36 > > Bob > > The coils are cold. How does one fix an air lock? > > Thanks > Steve Quandt > 1993 PT-40 > Iron Mountain, MI > > > ----- Original Message ---- > From: bloomas > To: WanderlodgeForum@yahoogroups.com > Sent: Sunday, May 6, 2007 8:02:29 AM > Subject: Re: [WanderlodgeForum] Refrigerator quit > > > ----- Original Message ----- > From: "Stephen Quanta" > To: > Sent: Sunday, May 06, 2007 6:24 AM > Subject: [WanderlodgeForum] Refrigerator quit > > Hi Steve Are the coils getting hot to the touch? > If Not you probably have a air lock. > Bob Loomis > > > My coach has a Domestic NDR-1292 refrigerator / freezer unit. It has been > > running perfectly since the end of Feb when I installed a new thermocouple > > in it until last Thursday when it abruptly quit. > > > > It cycles between gas and electric with no problem both produce heat. > > There are no signs of ammonia leak, no loud gurgles to indicate a > > blockage. All the fuses are good. The resistance on the temperature > > sensor tell me that it is closed calling for cooling. I am stumped! > > > > Steve Quanta > > 1993 PT-40 > > Iron Mountain, MI > > > > > > > > Yahoo! Groups Links > > > > > > > > > > > > > [Non-text portions of this message have been removed] > Refrigerator quit - Stephen Quandt - 05-07-2007 02:45 Bob, Thanks for the info. Sounds like I need to recruit my son and a few of his friends for this one!!! Steve Quandt 1993 PT-40 Iron Mountain, MI ----- Original Message ---- From: robertnloomas To: WanderlodgeForum@yahoogroups.com Sent: Sunday, May 6, 2007 2:06:48 PM Subject: [WanderlodgeForum] Re: Refrigerator quit --- In WanderlodgeForum@ yahoogroups. com, Stephen Quandt < smquandt@... > wrote:Steve You will have to pull the refrigerator out where you can rotate it 360 deg. Do it slowlySometime that will do the trick.You can do it a few times going in the same direction eachTime you rotate it. By the way rotating the unit is end over end. Before reinstalling the unit plug it In and check to see if the unit is now working. Do not forget you will need 12 volt control powerIn order for the controls to work. Bob Loomas 1985 PT 36 > > Bob > > The coils are cold. How does one fix an air lock? > > Thanks > Steve Quandt > 1993 PT-40 > Iron Mountain, MI > > > ----- Original Message ---- > From: bloomas > To: WanderlodgeForum@ yahoogroups. com > Sent: Sunday, May 6, 2007 8:02:29 AM > Subject: Re: [WanderlodgeForum] Refrigerator quit > > > ----- Original Message ----- > From: "Stephen Quanta" > To: > Sent: Sunday, May 06, 2007 6:24 AM > Subject: [WanderlodgeForum] Refrigerator quit > > Hi Steve Are the coils getting hot to the touch? > If Not you probably have a air lock. > Bob Loomis > > > My coach has a Domestic NDR-1292 refrigerator / freezer unit. It has been > > running perfectly since the end of Feb when I installed a new thermocouple > > in it until last Thursday when it abruptly quit. > > > > It cycles between gas and electric with no problem both produce heat. > > There are no signs of ammonia leak, no loud gurgles to indicate a > > blockage. All the fuses are good. The resistance on the temperature > > sensor tell me that it is closed calling for cooling. I am stumped! > > > > Steve Quanta > > 1993 PT-40 > > Iron Mountain, MI > > > > > > > > Yahoo! Groups Links > > > > > > > > > > > > > [Non-text portions of this message have been removed] > [Non-text portions of this message have been removed] |
