Installed two new black and gray gate valves - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Installed two new black and gray gate valves (/showthread.php?tid=4861) |
Installed two new black and gray gate valves - Jon - 05-07-2007 14:18 Well today I finished oft my cross connection job and replaced both tank valves and added one for the main pipe. The old ones were really tough to opperate and that was part of the reason I installed two new ones. The cost was pretty cheap only around 25 dollars for one set up. So now I can either keep the cross connection pipe on or take it oft and should have no trouble with dry camping. Jon Installed two new black and gray gate valves - Ryan Wright - 05-07-2007 15:34 Oops, forgot my entire signature... drat. -Ryan '86 PT-40 8V92 Tri-Cities, WA On 5/7/07, Ryan Wright > Hey Jon, > > Did you replace the gate valves yourself? > > Mine are working "fairly" well, but at least one (and I think it's the > black - ugh) has a slow leak. When I removed the cap to dump the tanks > the other day, an awful lot of greenish nasty fluid came out - several > gallons worth - before I was able to get the drain hose on. Thankfully > I was wearing gloves, and yes, the gate valves were both closed > properly. Gunk just seems to be leaking past the valve into the drain > tube. > > So, I'm thinking I should just replace 'em, and wanted to install some > electric dump valves instead for ease of use. However: They don't look > easy to replace! How do you get them off and get new ones on? It looks > like they're all hooked together with pipe dope and one might have to > replace every bit of drain piping under there, because I don't see a > way to cut the old ones out and still have enough pipe left on each > end for new fittings. > > Any ideas? > > -Ryan > > On 5/7/07, Jon > > > > Well today I finished oft my cross connection job and replaced both > > tank valves and added one for the main pipe. > > > > The old ones were really tough to opperate and that was part of the > > reason I installed two new ones. The cost was pretty cheap only around > > 25 dollars for one set up. So now I can either keep the cross > > connection pipe on or take it oft and should have no trouble with dry > > camping. Jon > Installed two new black and gray gate valves - Ryan Wright - 05-07-2007 15:34 Hey Jon, Did you replace the gate valves yourself? Mine are working "fairly" well, but at least one (and I think it's the black - ugh) has a slow leak. When I removed the cap to dump the tanks the other day, an awful lot of greenish nasty fluid came out - several gallons worth - before I was able to get the drain hose on. Thankfully I was wearing gloves, and yes, the gate valves were both closed properly. Gunk just seems to be leaking past the valve into the drain tube. So, I'm thinking I should just replace 'em, and wanted to install some electric dump valves instead for ease of use. However: They don't look easy to replace! How do you get them off and get new ones on? It looks like they're all hooked together with pipe dope and one might have to replace every bit of drain piping under there, because I don't see a way to cut the old ones out and still have enough pipe left on each end for new fittings. Any ideas? -Ryan On 5/7/07, Jon > > Well today I finished oft my cross connection job and replaced both > tank valves and added one for the main pipe. > > The old ones were really tough to opperate and that was part of the > reason I installed two new ones. The cost was pretty cheap only around > 25 dollars for one set up. So now I can either keep the cross > connection pipe on or take it oft and should have no trouble with dry > camping. Jon Installed two new black and gray gate valves - mrkane1952 - 05-10-2007 12:53 Greetings All: I recently replaced the cores of both Dupree waste valves on my 85 PT. The gray valve was leaking when closed, and both had been extremely difficult to operate for the year I've owned the coach. Now either can be easily opened with just the finger tips. Examination of the old paddles showed the seals on both to be quite swollen, and the leak was the result of a chunk missing. Replacement with either air or electric valves was considered, but there was no space on my coach. The electric valve in particular required mounting the handle/coil on top, which was just not possible in this case. I chose to replace the valve cores as complete units (from Jeff Miller, ~$22 each plus shipping.) This should have been a 15 minute job of removing 4 screws; but, alas, this is a 21 year old Bird. The gray valve is on the curb side, oriented downward at a 45 degree angle with no obstructions. It was easy. The black valve is behind a locked cover on the driver's side, next to the storage tube for the hose. Only one screw was accessible through the opening, but at least the head was sufficiently intact to allow backing it out. The other required removing the access door and door frame, plus the hose storage tube. Then I discovered the screw head was so damaged, I could not unscrew it. Eventually, I sawed the corner off the old cap, and broke enough material away to vise-grip it out. Next I found the core could not clear the opening, unless I took the handle off. The new core had a screw retaining the handle to the shaft, but the old one was pinned. It was horizontal, so punching it out was impossible--back to the vise-grips. Reassembly was much quicker. (Next time I'll get new screws with the new cores.) The moral of the story is to go ahead and replace the manual valve cores, and plan to pull them to re-lubricate the seals from time-to-time. Dumping requires kneeling to connect the hose anyway, so I'm satisfied with the renewed manual valves. --M.R.Kane '85 PT40 currently Isle du Bois Unit, Lake Ray Roberts SP, Texas Installed two new black and gray gate valves - Jon - 05-11-2007 07:22 --- In WanderlodgeForum@yahoogroups.com, "Ryan Wright" > > Hey Jon, > > Did you replace the gate valves yourself? > > Mine are working "fairly" well, but at least one (and I think it's the > black - ugh) has a slow leak. When I removed the cap to dump the tanks > the other day, an awful lot of greenish nasty fluid came out - several > gallons worth - before I was able to get the drain hose on. Thankfully > I was wearing gloves, and yes, the gate valves were both closed > properly. Gunk just seems to be leaking past the valve into the drain > tube. > > So, I'm thinking I should just replace 'em, and wanted to install some > electric dump valves instead for ease of use. However: They don't look > easy to replace! How do you get them off and get new ones on? It looks > like they're all hooked together with pipe dope and one might have to > replace every bit of drain piping under there, because I don't see a > way to cut the old ones out and still have enough pipe left on each > end for new fittings. > > Any ideas? > > -Ryan > > On 5/7/07, Jon > > > > Well today I finished oft my cross connection job and replaced both > > tank valves and added one for the main pipe. > > > > The old ones were really tough to opperate and that was part of the > > reason I installed two new ones. The cost was pretty cheap only around > > 25 dollars for one set up. So now I can either keep the cross > > connection pipe on or take it oft and should have no trouble with dry > > camping. Jon If your old valves are like mine and you haft to twist the handle to get the valve to open than I just cut those valves out by cutting next to the valve itself and installing the new valve on the old drain pipe. Really very strait forward job but you will need to clean up old pipe so that your new pipe glue will addhess itself to the new valve. Jon (the new valves work great and nice and easy!) Installed two new black and gray gate valves - Jon - 05-11-2007 07:26 --- In WanderlodgeForum@yahoogroups.com, "Jon" > > Well today I finished oft my cross connection job and replaced both > tank valves and added one for the main pipe. > > The old ones were really tough to opperate and that was part of the > reason I installed two new ones. The cost was pretty cheap only around > 25 dollars for one set up. So now I can either keep the cross > connection pipe on or take it oft and should have no trouble with dry > camping. Jon On those pipes that might haft to be cut, you can get a few 3" PVC coupling and pretty much cut where you want. I had enough room underneath my coach to just cut oft next to curved pipe that leads to the tank and installed the new ones. Jon 78 Bremerton Washington > Installed two new black and gray gate valves - Jon - 05-11-2007 07:33 --- In WanderlodgeForum@yahoogroups.com, "Ryan Wright" > > Hey Jon, > > Did you replace the gate valves yourself? > > Mine are working "fairly" well, but at least one (and I think it's the > black - ugh) has a slow leak. When I removed the cap to dump the tanks > the other day, an awful lot of greenish nasty fluid came out - several > gallons worth - before I was able to get the drain hose on. Thankfully > I was wearing gloves, and yes, the gate valves were both closed > properly. Gunk just seems to be leaking past the valve into the drain > tube. > > So, I'm thinking I should just replace 'em, and wanted to install some > electric dump valves instead for ease of use. However: They don't look > easy to replace! How do you get them off and get new ones on? It looks > like they're all hooked together with pipe dope and one might have to > replace every bit of drain piping under there, because I don't see a > way to cut the old ones out and still have enough pipe left on each > end for new fittings. > > Any ideas? > > -Ryan > > On 5/7/07, Jon > > > > Well today I finished oft my cross connection job and replaced both > > tank valves and added one for the main pipe. > > > > The old ones were really tough to opperate and that was part of the > > reason I installed two new ones. The cost was pretty cheap only around > > 25 dollars for one set up. So now I can either keep the cross > > connection pipe on or take it oft and should have no trouble with dry > > camping. Jon RYAN! I was talking to a friend this morning about my installaion of my valves and he said you can rebuild those older vlvs. I would try to see who knows where to get those repair items on this site. I only replaced mine as the little tits that stick out of flange for connecting the saftey spill cap were broke oft. I did open up my old vlvs and it is a cake walk as to repairing these of valves. Jon Jon 1978 Wanderlodge Bremerton Washington Installed two new black and gray gate valves - ebirder2000@... - 05-11-2007 21:35 Ryen Wright. Before you go to the trouble of cutting the old valves out and trying to replace, which might end up being a plumbing nightmare, you should try replacing just the inerts of the valves. The original valves on your bird should be Dupree (brand name) valves. Internal replacement kits are available. If you do a Internet search for Dupree products you should find Jeff Millers website. Replacing the paddles and shafts makes all the difference. (There is also probably a link posted in the links section of this forum and on the homepage of Bird Connection dot com.) Steve Anderson 79 FC 35 Poulsbo, Wa. > Hey Jon, > > Did you replace the gate valves yourself? > > Mine are working "fairly" well, but at least one (and I think it's the > black - ugh) has a slow leak. When I removed the cap to dump the tanks > the other day, an awful lot of greenish nasty fluid came out - several > gallons worth - before I was able to get the drain hose on. Thankfully > I was wearing gloves, and yes, the gate valves were both closed > properly. Gunk just seems to be leaking past the valve into the drain > tube. > > So, I'm thinking I should just replace 'em, and wanted to install some > electric dump valves instead for ease of use. However: They don't look > easy to replace! How do you get them off and get new ones on? It looks > like they're all hooked together with pipe dope and one might have to > replace every bit of drain piping under there, because I don't see a > way to cut the old ones out and still have enough pipe left on each > end for new fittings. > > Any ideas? > > -Ryan ************************************** See what's free at http://www.aol.com. [Non-text portions of this message have been removed] Installed two new black and gray gate valves - Ryan Wright - 05-12-2007 10:36 Thanks for the info, Steve. I'll look into doing that. Certainly would be easier and cheaper... On the other hand I really want electric valves. I'll have to weigh the options and select one or the other. Appreciate it! -Ryan On 5/12/07, ebirder2000@... > > Ryen Wright. > > Before you go to the trouble of cutting the old valves out and trying to > replace, which might end up being a plumbing nightmare, you should try replacing > just the inerts of the valves. The original valves on your bird should be > Dupree (brand name) valves. Internal replacement kits are available. If you do a > Internet search for Dupree products you should find Jeff Millers website. > Replacing the paddles and shafts makes all the difference. (There is also > probably a link posted in the links section of this forum and on the homepage of > Bird Connection dot com.) > > Steve Anderson > 79 FC 35 > Poulsbo, Wa. > |
