1987 PT40 Grease and Zerk Fittings - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: 1987 PT40 Grease and Zerk Fittings (/showthread.php?tid=4952) |
1987 PT40 Grease and Zerk Fittings - worktohobby - 05-21-2007 07:32 Hi all, Do I need to use a special lube for my brake Zerk fittings? I could not locate the "Stopmaster" NLG1 grade #1 type. These are self adjusting type brakes. Also, what is the recommended lube for the other bus Zerk fitting? Or does it matter so long as it is grade NLG1 grade #2? Nappa has like ten types of this stuff and they recommended simply using the plane lithium type. Thanks for the help, Don Duncan 1987 PT40 Beaverton, Oregon 1987 PT40 Grease and Zerk Fittings - Stephen Birtles - 05-21-2007 09:42 just use the same good grease You use on the rest of the coach Stephen 77fc35 --- In WanderlodgeForum@yahoogroups.com, "worktohobby" > > Hi all, > > Do I need to use a special lube for my brake Zerk fittings? I could not > locate the "Stopmaster" NLG1 grade #1 type. These are self adjusting > type brakes. > > Also, what is the recommended lube for the other bus Zerk fitting? Or > does it matter so long as it is grade NLG1 grade #2? Nappa has like ten > types of this stuff and they recommended simply using the plane lithium > type. > > Thanks for the help, > > Don Duncan > 1987 PT40 > Beaverton, Oregon > |
