How to remove upper dash? - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: How to remove upper dash? (/showthread.php?tid=5014) |
How to remove upper dash? - Ryan Wright - 05-29-2007 14:37 Hi folks, How do I remove my upper dash panel (the one with the speedometer in it)? I got the lower one out easily. On the upper, I found a screw going through from the right side and another holding the panel to a bracket in the center. The right side & center area is free but the left won't budge. I'm sure there is a screw there somewhere near the speedometer but I can't find it. I don't want to force anything and break it. Any advice? -Ryan '86 PT-40 8V92 Tri-Cities, WA How to remove upper dash? - Art Weatherly - 05-29-2007 17:09 Ryan I did mine a couple of weeks ago. There is a screw on the left side. It's about the same position as the one on the right side. But it comes out from the inside. I needed a very long phillips screwdriver and a flashlightto get it out.I acually used a 15" 1/4 drive extention with a phillips bit on one end and a handle on the other. It took several times to "spear" the center of the screw but it worked. I got the direction from Ralph Fullenwider. Art Weatherly Riveride Ca. '85 PT36 ----- Original Message ----- From: Ryan Wright To: WanderlodgeForum@yahoogroups.com ; wanderlodge@yahoogroups.com Sent: Tuesday, May 29, 2007 7:37 PM Subject: [SPAM] [WanderlodgeForum] How to remove upper dash? Hi folks, How do I remove my upper dash panel (the one with the speedometer in it)? I got the lower one out easily. On the upper, I found a screw going through from the right side and another holding the panel to a bracket in the center. The right side & center area is free but the left won't budge. I'm sure there is a screw there somewhere near the speedometer but I can't find it. I don't want to force anything and break it. Any advice? -Ryan '86 PT-40 8V92 Tri-Cities, WA [Non-text portions of this message have been removed] How to remove upper dash? - Chuck Wheeler - 05-29-2007 18:05 Behind the top left switch or filler plate is another screw. - Chuck Wheeler - 82 FC 31 SB Fort Worth, TX _____ From: WanderlodgeForum@yahoogroups.com [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of Ryan Wright Sent: Tuesday, May 29, 2007 7:37 PM To: WanderlodgeForum@yahoogroups.com; wanderlodge@yahoogroups.com Subject: [WanderlodgeForum] How to remove upper dash? Hi folks, How do I remove my upper dash panel (the one with the speedometer in it)? I got the lower one out easily. On the upper, I found a screw going through from the right side and another holding the panel to a bracket in the center. The right side & center area is free but the left won't budge. I'm sure there is a screw there somewhere near the speedometer but I can't find it. I don't want to force anything and break it. Any advice? -Ryan '86 PT-40 8V92 Tri-Cities, WA [Non-text portions of this message have been removed] How to remove upper dash? - Ryan Wright - 05-30-2007 04:03 Thank you for the responses! Should be easy to finish getting out now that I know where the screw is hiding. -Ryan '86 PT-40 8V92 Tri-Cities, WA How to remove upper dash? - jim matus - 05-30-2007 16:35 There is a phillips head screw just above and to the left of the speedo. Some people have posted that they got it out with a long phillips screw driver. You will have to do it without being able to see the screw head. On mine I removed the two nuts from the speedo mount pulled the speedo out and then could use a 1/4" rachet with a phillips bit. After I got it out I took my Dremmel Tool and used the flexable drive to drill the screw hole all the way thru the upper surround. I then put a slide on type speed clip for a sheet metal screw on the dash mount ear that has the screw hole in it. when I put the dash back in I put a longer screw in from the outside and screwed it into the speed clip. I used a Bluebird screw head cover like the ones used all around that area. It looks factory and I can pull the upper dash in a couple of minutes. Jim Matus 84FCSB35 Rescue CA --- In WanderlodgeForum@yahoogroups.com, "Ryan Wright" > > Hi folks, > > How do I remove my upper dash panel (the one with the speedometer in > it)? I got the lower one out easily. On the upper, I found a screw > going through from the right side and another holding the panel to a > bracket in the center. The right side & center area is free but the > left won't budge. I'm sure there is a screw there somewhere near the > speedometer but I can't find it. I don't want to force anything and > break it. > > Any advice? > > -Ryan > '86 PT-40 8V92 > Tri-Cities, WA > |
