Yanmar generator oil pressure - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Yanmar generator oil pressure (/showthread.php?tid=5061) |
Yanmar generator oil pressure - Scott Forman - 06-03-2007 03:02 I took a day-trip yesterday that had the generator running for about 16 hours straight. On my way home, the oil pressure gauge for the gen engine began reading very high, almost pegged to the right. While I know what low oil press can do to an engine, I have never really heard any talk of whether high oil pressure is a big problem. Is it? If it is a true problem and not an instrument issue, what is the likely cause? It may well be the gauge, when I turned the gen off, the press gauge only retreated about half way. I checked the oil before leaving yesterday and it was fine. Have not done any investigating yet this morning. The gen seemed to be running perfectly otherwise, the water temp was fine and there were no odd sounds, smells, etc. Ideas? Scott Forman 86 PT38 Yanmar generator oil pressure - bloomas - 06-03-2007 03:17 ----- Original Message ----- From: Scott Forman To: WanderlodgeForum@yahoogroups.com Sent: Sunday, June 03, 2007 10:02 AM Subject: [WanderlodgeForum] Yanmar generator oil pressure Scott I would replace the gage if it is not zeroing out while the engine is shut down I would have to take a hard look at the gage. Bob Loomas 1985 PT 36 I took a day-trip yesterday that had the generator running for about 16 hours straight. On my way home, the oil pressure gauge for the gen engine began reading very high, almost pegged to the right. While I know what low oil press can do to an engine, I have never really heard any talk of whether high oil pressure is a big problem. Is it? If it is a true problem and not an instrument issue, what is the likely cause? It may well be the gauge, when I turned the gen off, the press gauge only retreated about half way. I checked the oil before leaving yesterday and it was fine. Have not done any investigating yet this morning. The gen seemed to be running perfectly otherwise, the water temp was fine and there were no odd sounds, smells, etc. Ideas? Scott Forman 86 PT38 [Non-text portions of this message have been removed] Yanmar generator oil pressure - Rob Robinson - 06-03-2007 03:40 Might be preaching to the choir here but I would change out the complete system.....sending unit and guage. On 03/06/07, bloomas > > > ----- Original Message ----- > From: Scott Forman > To: WanderlodgeForum@yahoogroups.com > Sent: Sunday, June 03, 2007 10:02 AM > Subject: [WanderlodgeForum] Yanmar generator oil pressure > Scott I would replace the gage if it is not zeroing out > while the engine is shut down I would have to take a hard look at the > gage. > Bob Loomas 1985 PT 36 > > > I took a day-trip yesterday that had the generator running for about 16 > hours straight. On my way home, the oil pressure gauge for the gen > engine began reading very high, almost pegged to the right. While I > know what low oil press can do to an engine, I have never really heard > any talk of whether high oil pressure is a big problem. Is it? If it > is a true problem and not an instrument issue, what is the likely > cause? It may well be the gauge, when I turned the gen off, the press > gauge only retreated about half way. I checked the oil before leaving > yesterday and it was fine. Have not done any investigating yet this > morning. The gen seemed to be running perfectly otherwise, the water > temp was fine and there were no odd sounds, smells, etc. > > Ideas? > > Scott Forman > 86 PT38 > > [Non-text portions of this message have been removed] > > > -- Rob, Sue & Merlin Robinson 94 WLWB [Non-text portions of this message have been removed] Yanmar generator oil pressure - pattypape - 06-03-2007 03:55 Good advice, Sounds like the gage, then the sensor must match up, Test and replace both. A good gage test guide is on the Teleflex web site. http://www.teleflexmarine.com/cgi-bin/frameset2.cgi? site=gauges&type=us&link2=1047 Bill 88 FC Michigan --- In WanderlodgeForum@yahoogroups.com, "Rob Robinson" > > Might be preaching to the choir here but I would change out the complete > system.....sending unit and guage. > > On 03/06/07, bloomas > > > > > > ----- Original Message ----- > > From: Scott Forman > > To: WanderlodgeForum@yahoogroups.com > > Sent: Sunday, June 03, 2007 10:02 AM > > Subject: [WanderlodgeForum] Yanmar generator oil pressure > > Scott I would replace the gage if it is not zeroing out > > while the engine is shut down I would have to take a hard look at the > > gage. > > Bob Loomas 1985 PT 36 > > > > > > I took a day-trip yesterday that had the generator running for about 16 > > hours straight. On my way home, the oil pressure gauge for the gen > > engine began reading very high, almost pegged to the right. While I > > know what low oil press can do to an engine, I have never really heard > > any talk of whether high oil pressure is a big problem. Is it? If it > > is a true problem and not an instrument issue, what is the likely > > cause? It may well be the gauge, when I turned the gen off, the press > > gauge only retreated about half way. I checked the oil before leaving > > yesterday and it was fine. Have not done any investigating yet this > > morning. The gen seemed to be running perfectly otherwise, the water > > temp was fine and there were no odd sounds, smells, etc. > > > > Ideas? > > > > Scott Forman > > 86 PT38 > > > > [Non-text portions of this message have been removed] > > > > > > > > > > -- > Rob, Sue & Merlin Robinson > 94 WLWB > > > [Non-text portions of this message have been removed] > |
