Brake Adjusters - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Brake Adjusters (/showthread.php?tid=5110) |
Brake Adjusters - mbrund - 06-08-2007 14:18 Well I went a little to far with one of my brake tension adjusters on my coach and have not been able to determine how to get it to back off. When I try to turn the wrench the other way, it will not budge. How do you get the adjuster to back off? Michael Brundridge 1992 WB40 Georgetown, TX Brake Adjusters - Wilhelmus Schreurs - 06-09-2007 02:32 Michael: If I can remember correctly, push the wrench hard on the bolt, there is a locking spring there, it should allow you to turn it. Bill 84 FC 35 SB "$quanderlodge" Terrace, B.C. Canada ----- Original Message ---- From: mbrund <mbrund@...> To: WanderlodgeForum@yahoogroups.com Sent: Friday, June 8, 2007 7:18:37 PM Subject: [WanderlodgeForum] Brake Adjusters Well I went a little to far with one of my brake tension adjusters on my coach and have not been able to determine how to get it to back off. When I try to turn the wrench the other way, it will not budge. How do you get the adjuster to back off? Michael Brundridge 1992 WB40 Georgetown, TX __________________________________________________ Do You Yahoo!? Tired of spam? Yahoo! Mail has the best spam protection around http://mail.yahoo.com [Non-text portions of this message have been removed] Brake Adjusters - bloomas - 06-09-2007 02:48 ----- Original Message ----- From: mbrund To: WanderlodgeForum@yahoogroups.com Sent: Friday, June 08, 2007 9:18 PM Subject: [WanderlodgeForum] Brake Adjusters Michael Your coach is not equip with self slack adjusters? Bob Loomas 1985 PT 36 Well I went a little to far with one of my brake tension adjusters on my coach and have not been able to determine how to get it to back off. When I try to turn the wrench the other way, it will not budge. How do you get the adjuster to back off? Michael Brundridge 1992 WB40 Georgetown, TX [Non-text portions of this message have been removed] Brake Adjusters - mbrund - 06-09-2007 08:33 Since it was built after 1990 it has Auto-Slack adjusters. Since I had the wheels off I went ahead and adjusted them as if I had just done a brake job. Tighten them down till they contact the drum and then back them off 1/3 turn. They where adjusted fairly close, but figured I would do it anyway. Finially found the release pin, it was hidden on the back side where I could not see it. Once I reached around back I found the release pin and pulled it and was able to back it off 1/3 turn. Michael Brundridge 1992 WB40 Georgetown, TX --- In WanderlodgeForum@yahoogroups.com, "bloomas" wrote: > > > ----- Original Message ----- > From: mbrund > To: WanderlodgeForum@yahoogroups.com > Sent: Friday, June 08, 2007 9:18 PM > Subject: [WanderlodgeForum] Brake Adjusters > Michael Your coach is not equip with self slack adjusters? > Bob Loomas 1985 PT 36 > > > Well I went a little to far with one of my brake tension adjusters on > my coach and have not been able to determine how to get it to back > off. When I try to turn the wrench the other way, it will not > budge. > > How do you get the adjuster to back off? > > Michael Brundridge > 1992 WB40 > Georgetown, TX > > > > > > [Non-text portions of this message have been removed] > |
