Temp Readings - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Temp Readings (/showthread.php?tid=512) |
Temp Readings - Mark Garber - 05-05-2005 15:41 I was exercising the bird and my water temp was running 190-200 which didn't concern me but the oil temp was running 290-300 and that concerns me. Altho I haven't checked or changed the oil sending unit yet and I know the guages aren't necessarily accurate as they haven't been calibrated to my knowledge. I had also stopped and cracked & opened the radatior cap without a problem while it was warm so I know the water was OK. I also plan on testing the antifreeze for cooling and ph properties. Any other thoughts b4 I start digging into things? Mark, 80FC35 in PA for awhile --------------------------------- Do you Yahoo!? Yahoo! Sports - Sign up for Fantasy Baseball. [Non-text portions of this message have been removed] Temp Readings - Jeff Miller - 05-06-2005 02:26 Seems to me I remember something about oil coolers going bad on 3208s, can't remember for sure though (long time ago). I suppose if you were to replace the hoses on the oil cooler anyway, you could check water flow through it. - Jeff Miller http://www.wanderlodge.net http://www.millercoachworks.com --- In WanderlodgeForum@yahoogroups.com, Mark Garber wrote: > I was exercising the bird and my water temp was running 190-200 which didn't concern me but the oil temp was running 290-300 and that concerns me. Altho I haven't checked or changed the oil sending unit yet and I know the guages aren't necessarily accurate as they haven't been calibrated to my knowledge. I had also stopped and cracked & opened the radatior cap without a problem while it was warm so I know the water was OK. I also plan on testing the antifreeze for cooling and ph properties. Any other thoughts b4 I start digging into things? > > Mark, 80FC35 in PA for awhile > > > > --------------------------------- > Do you Yahoo!? > Yahoo! Sports - Sign up for Fantasy Baseball. > > [Non-text portions of this message have been removed] Temp Readings - Mark Garber - 05-06-2005 04:08 Ty for your reply and your contributions to the continuing sucess of many peoples Bird ownership. Mark Jeff Miller Seems to me I remember something about oil coolers going bad on 3208s, can't remember for sure though (long time ago). I suppose if you were to replace the hoses on the oil cooler anyway, you could check water flow through it. - Jeff Miller http://www.wanderlodge.net http://www.millercoachworks.com --- In WanderlodgeForum@yahoogroups.com, Mark Garber wrote: > I was exercising the bird and my water temp was running 190-200 which didn't concern me but the oil temp was running 290-300 and that concerns me. Altho I haven't checked or changed the oil sending unit yet and I know the guages aren't necessarily accurate as they haven't been calibrated to my knowledge. I had also stopped and cracked & opened the radatior cap without a problem while it was warm so I know the water was OK. I also plan on testing the antifreeze for cooling and ph properties. Any other thoughts b4 I start digging into things? > > Mark, 80FC35 in PA for awhile --------------------------------- Yahoo! Mail Mobile Take Yahoo! Mail with you! Check email on your mobile phone. [Non-text portions of this message have been removed] |
