Added external propane quick connector - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Added external propane quick connector (/showthread.php?tid=5124) Pages: 1 2 |
Added external propane quick connector - erniecarpet@... - 06-10-2007 08:11 What about a catalytic heater? Are those safe, as an alternative in our coach? I'm sure that anything that has combustion emits CO2. Ernie Ekberg 83PT40 Livingston, Mt -with one heater turned off cause the fumes are bad ************************************** See what's free at http://www.aol.com. [Non-text portions of this message have been removed] Added external propane quick connector - davidkerryedwards - 06-10-2007 11:10 Added a quick connect fitting to the propane tank today so I can hook up outside campstove. Took the elbow going into the regulator and replaced it with a T, put a second regulator above the existing one with a quick connect hose fitting. Took about an hour and about $20 in parts. I can also plug in a small propane heater, running the hose in thru a window so when dry camping I can get propane heat without the need for electricity if necessary. Kerry 82 Fc 35 Denver Added external propane quick connector - bloomas - 06-10-2007 11:26 ----- Original Message ----- From: davidkerryedwards To: WanderlodgeForum@yahoogroups.com Sent: Sunday, June 10, 2007 6:10 PM Subject: [WanderlodgeForum] Added external propane quick connector Yes and you can also kill you and your family from carbodioxide if the bird is not properly ventilated.It is your bird do with it you want. Bob Loomas 1985 PT 36 Added a quick connect fitting to the propane tank today so I can hook up outside campstove. Took the elbow going into the regulator and replaced it with a T, put a second regulator above the existing one with a quick connect hose fitting. Took about an hour and about $20 in parts. I can also plug in a small propane heater, running the hose in thru a window so when dry camping I can get propane heat without the need for electricity if necessary. Kerry 82 Fc 35 Denver [Non-text portions of this message have been removed] Added external propane quick connector - Scott Forman - 06-10-2007 11:45 Kerry, A "small propane heater" inside your coach is a good way to make sure you and your family never wake up from a winter's nap. Might want to reconsider that idea.... Scott Forman 86 PT38 --- In WanderlodgeForum@yahoogroups.com, "davidkerryedwards" > > Added a quick connect fitting to the propane tank today so I can hook up outside campstove. > Took the elbow going into the regulator and replaced it with a T, put a second regulator > above the existing one with a quick connect hose fitting. Took about an hour and about $20 > in parts. I can also plug in a small propane heater, running the hose in thru a window so > when dry camping I can get propane heat without the need for electricity if necessary. > > Kerry > 82 Fc 35 > Denver > Added external propane quick connector - Curt Sprenger - 06-10-2007 12:18 Catalytic heater works. Leave a window cracked. We've used them for years. 1987 PT38 8V92 "MacAttack Racing" Anaheim Hills, Calif. erniecarpet@... wrote: > What about a catalytic heater? Are those safe, as an alternative in our > coach? I'm sure that anything that has combustion emits CO2. > > Ernie Ekberg > 83PT40 > Livingston, Mt > -with one heater turned off cause the fumes are bad > > ************************************** See what's free at > http://www.aol.com. <http://www.aol.com.> > > [Non-text portions of this message have been removed] > > Added external propane quick connector - davidkerryedwards - 06-10-2007 12:30 Aware of those issues. I have owned a motorhome with a non-forced air propane heater in the past and have been quite happy with it. The heater I have has an oxygen depletion sensor that automatically shuts it off if the oxygen level drops below a certain point. Kerry 82 FC 35 Denver --- In WanderlodgeForum@yahoogroups.com, "Scott Forman" <sforman@...> wrote: > > Kerry, > > A "small propane heater" inside your coach is a good way to make sure > you and your family never wake up from a winter's nap. Might want to > reconsider that idea.... > > Scott Forman > 86 PT38 > > --- In WanderlodgeForum@yahoogroups.com, "davidkerryedwards" > > > > > Added a quick connect fitting to the propane tank today so I can > hook up outside campstove. > > Took the elbow going into the regulator and replaced it with a T, > put a second regulator > > above the existing one with a quick connect hose fitting. Took > about an hour and about $20 > > in parts. I can also plug in a small propane heater, running the > hose in thru a window so > > when dry camping I can get propane heat without the need for > electricity if necessary. > > > > Kerry > > 82 Fc 35 > > Denver > > > Added external propane quick connector - davidkerryedwards - 06-10-2007 12:31 Will do. Kerry 82 FC 35 Denver > your bird do with it you want. > Bob Loomas 1985 PT 36 Added external propane quick connector - bubblerboy64 - 06-10-2007 12:52 Kerry, I am not familiar with what type of heater you are talking about. Is there an external exhaust? What happens if the oxygen level sensor would fail? Please expand. I have used propane camp style heaters in garage or tent type situations. I don't think I would take a chance in a BB. I am also extremely sensitve to any fumes at all. The only heater I use in my trailers and RV have been the small electric heaters. Even these I would not leave unattended do to potential fire risks. JEH > > Aware of those issues. I have owned a motorhome with a non-forced air propane heater > in the past and have been quite happy with it. The heater I have has an oxygen depletion > sensor that automatically shuts it off if the oxygen level drops below a certain point. > > Kerry > 82 FC 35 > Denver > > --- In WanderlodgeForum@yahoogroups.com, "Scott Forman" <sforman@> wrote: > > > > Kerry, > > > > A "small propane heater" inside your coach is a good way to make sure > > you and your family never wake up from a winter's nap. Might want to > > reconsider that idea.... > > > > Scott Forman > > 86 PT38 > > > > --- In WanderlodgeForum@yahoogroups.com, "davidkerryedwards" > > > > > > > > Added a quick connect fitting to the propane tank today so I can > > hook up outside campstove. > > > Took the elbow going into the regulator and replaced it with a T, > > put a second regulator > > > above the existing one with a quick connect hose fitting. Took > > about an hour and about $20 > > > in parts. I can also plug in a small propane heater, running the > > hose in thru a window so > > > when dry camping I can get propane heat without the need for > > electricity if necessary. > > > > > > Kerry > > > 82 Fc 35 > > > Denver > > > > > > Added external propane quick connector - bluebird3208 - 06-10-2007 14:08 --- In WanderlodgeForum@yahoogroups.com, "bloomas" wrote:That would be Carbon monoxide. Jim > > > ----- Original Message ----- > From: davidkerryedwards > To: WanderlodgeForum@yahoogroups.com > Sent: Sunday, June 10, 2007 6:10 PM > Subject: [WanderlodgeForum] Added external propane quick connector > Yes and you can also kill you and your family from carbodioxide if the bird is not properly ventilated.It is > your bird do with it you want. > Bob Loomas 1985 PT 36 > > > Added a quick connect fitting to the propane tank today so I can hook up outside campstove. > Took the elbow going into the regulator and replaced it with a T, put a second regulator > above the existing one with a quick connect hose fitting. Took about an hour and about $20 > in parts. I can also plug in a small propane heater, running the hose in thru a window so > when dry camping I can get propane heat without the need for electricity if necessary. > > Kerry > 82 Fc 35 > Denver > > > > > > [Non-text portions of this message have been removed] > Added external propane quick connector - davidkerryedwards - 06-10-2007 15:08 It was in a motorhome I owned in Europe. Never seen one in the US. No external exhaust that I was aware of. Can't remember the brand name. I keep a carbon monoxide detector in the motorhome so if the oxygen depletion sensor fails, the carbon monoxide detector would go off. I also open a window. There is less combustion taking place in the propane heater than there is with the stove top burners or the oven. Kerry 82 FC 35 Denver --- In WanderlodgeForum@yahoogroups.com, "bubblerboy64" > > Kerry, I am not familiar with what type of heater you are talking > about. Is there an external exhaust? What happens if the oxygen > level sensor would fail? Please expand. I have used propane camp > style heaters in garage or tent type situations. I don't think I > would take a chance in a BB. I am also extremely sensitve to any > fumes at all. The only heater I use in my trailers and RV have been > the small electric heaters. Even these I would not leave unattended > do to potential fire risks. JEH |
