PowerTech generator problem - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: PowerTech generator problem (/showthread.php?tid=5136) |
PowerTech generator problem - rogerwwebb@... - 06-12-2007 22:40 A couple of suggestions: * verify the fuel solenoid is opening - when you preheat (or start) the engine the solenoid opens, and stays open for matter of seconds after you disengage the start or preheat button - you'll hear clicking - it then will return to the closed position - this solenoid is a booted device on the curb side front of the engine. * possible air in fuel line. have someone crank the engine while you open the T handle valve that is inline with the fuel lines (this is located above the solenoid mentioned in the first bullet. Opening this valve allows excess fuel to return to the pump, purging air that may be in the lines. Some people advise this valve should be left open a small amount. Generally, if it cranks and gets fuel, it should start. If it just cranks but won't start, and you're fairly sure your getting fuel, check for a bad electrical connection, a prime area is the gang plug with multiple wires on the curb side of the engine. Move/shake the plug to see if that helps. You can also feel (careful) the glow plugs to see if they are warm. Roger Webb 91WBWL Cedar Rapids, IA ************************************** See what's free at http://www.aol.com. [Non-text portions of this message have been removed] PowerTech generator problem - whynotam - 06-13-2007 02:17 Does anyone have a suggestion on where to start looking for the reason my 15KW PowerTech won't start? I used it last during a trip to Florida in January and it worked great. I tried to start it last week and it fired and ran for just a bit before dying, maybe ran for a few seconds. It turns over good but will not start. Thanks, Alvie Miller 1993 WLWB PowerTech generator problem - Thomas Rembert - 06-13-2007 03:58 --- In WanderlodgeForum@yahoogroups.com, "whynotam" wrote: > > Does anyone have a suggestion on where to start looking for the reason > my 15KW PowerTech won't start? I used it last during a trip to Florida > in January and it worked great. I tried to start it last week and it > fired and ran for just a bit before dying, maybe ran for a few seconds. > It turns over good but will not start. > > Thanks, > > Alvie Miller > 1993 WLWB > I just had to replace the electric fuel pump on mine. I came back to the motor home and found the gen-set off for the first time ever. no circuit breakers popped. started it up was rough running but then did OK. Ran all night but quit the next morning and would only try to start. Replaced the fuel pump and has been running good ever since. I had a spare pump from 2 motor-homes ago(15 years)and it worked fine. Bought a new spare from NAPA, they had it in stock. Good luck Thomas 93 wlwb PowerTech generator problem - whynotam - 06-13-2007 03:58 Roger, I will try your suggestions this evening after I get off work. Thanks for your speedy response. Alvie Miller Arthur IL 1993 WLWB --- In WanderlodgeForum@yahoogroups.com, rogerwwebb@... wrote: > > A couple of suggestions: > > * verify the fuel solenoid is opening - when you preheat (or start) the > engine the solenoid opens, and stays open for matter of seconds after you > disengage the start or preheat button - you'll hear clicking - it then will > return to the closed position - this solenoid is a booted device on the curb > side front of the engine. > * possible air in fuel line. have someone crank the engine while you > open the T handle valve that is inline with the fuel lines (this is located > above the solenoid mentioned in the first bullet. Opening this valve allows > excess fuel to return to the pump, purging air that may be in the lines. Some > people advise this valve should be left open a small amount. > Generally, if it cranks and gets fuel, it should start. If it just cranks > but won't start, and you're fairly sure your getting fuel, check for a bad > electrical connection, a prime area is the gang plug with multiple wires on the > curb side of the engine. Move/shake the plug to see if that helps. You can > also feel (careful) the glow plugs to see if they are warm. > > Roger Webb > 91WBWL > Cedar Rapids, IA > > > > > ************************************** See what's free at http://www.aol.com. > > > [Non-text portions of this message have been removed] > PowerTech generator problem - whynotam - 06-13-2007 04:37 Another good suggestion. I'll check it out also. Thanks, Alvie Miller Arthur IL 1993 WLWB --- In WanderlodgeForum@yahoogroups.com, "Thomas Rembert" > > --- In WanderlodgeForum@yahoogroups.com, "whynotam" > wrote: > > > > Does anyone have a suggestion on where to start looking for the > reason > > my 15KW PowerTech won't start? I used it last during a trip to > Florida > > in January and it worked great. I tried to start it last week and > it > > fired and ran for just a bit before dying, maybe ran for a few > seconds. > > It turns over good but will not start. > > > > Thanks, > > > > Alvie Miller > > 1993 WLWB > > > I just had to replace the electric fuel pump on mine. I came back to > the motor home and found the gen-set off for the first time ever. no > circuit breakers popped. started it up was rough running but then > did OK. Ran all night but quit the next morning and would only try > to start. Replaced the fuel pump and has been running good ever > since. I had a spare pump from 2 motor-homes ago(15 years)and it > worked fine. Bought a new spare from NAPA, they had it in stock. > > Good luck > Thomas > 93 wlwb > PowerTech generator problem - bloomas - 06-13-2007 07:15 ----- Original Message ----- From: whynotam To: WanderlodgeForum@yahoogroups.com Sent: Wednesday, June 13, 2007 11:37 AM Subject: [WanderlodgeForum] Re: PowerTech generator problem Check your air and fuel filters.I have had mine shut down because of air filter twice. Bob Loomas 1985 PT 36 in Grand Forks ND Another good suggestion. I'll check it out also. Thanks, Alvie Miller Arthur IL 1993 WLWB --- In WanderlodgeForum@yahoogroups.com, "Thomas Rembert" > > --- In WanderlodgeForum@yahoogroups.com, "whynotam" > wrote: > > > > Does anyone have a suggestion on where to start looking for the > reason > > my 15KW PowerTech won't start? I used it last during a trip to > Florida > > in January and it worked great. I tried to start it last week and > it > > fired and ran for just a bit before dying, maybe ran for a few > seconds. > > It turns over good but will not start. > > > > Thanks, > > > > Alvie Miller > > 1993 WLWB > > > I just had to replace the electric fuel pump on mine. I came back to > the motor home and found the gen-set off for the first time ever. no > circuit breakers popped. started it up was rough running but then > did OK. Ran all night but quit the next morning and would only try > to start. Replaced the fuel pump and has been running good ever > since. I had a spare pump from 2 motor-homes ago(15 years)and it > worked fine. Bought a new spare from NAPA, they had it in stock. > > Good luck > Thomas > 93 wlwb > [Non-text portions of this message have been removed] PowerTech generator problem - Leroy Eckert - 06-13-2007 11:20 There are several things that will cause the problem. Some have been suggested. Based on the year of the coach, the engine is probably a Kubota. This is how I would approach the problem. Check to see if the fuel solenoid is operating. It should click and the booted arm should move back and forth. If it will not start. Crack the pressure line on the fuel pump and see if fuel is being pumped to the injector pump. There should be a pretty good stream. If not, the fuel filter could be stopped up or the fuel pump is bad or there is no power to the pump. I had a bad fuel pump that caused very hard starting but would let it run. If all is well and it won't start their could be air in the system. Before you start bleeding lines: Disconnect the wire to the over temperature sensor and see if it starts. If it starts the sensor is bad or the wire to it is grounded somewhere. It probably has a low oil pressure switch. Disconnect that wire. If it starts the switch is bad or the oil pressure in the engine is low(unlikely). Check the oil. All from memory when I reworked my unit. The odds are slim. One of the start stop switches is in the stop position. Since they are spring loaded to run it's remote, but possible. Check the one in the genset bay, it is exposed to the elements. If it will not start I'll have to go get my book from the coach. Hope this helps Leroy Eckert 1990 WB-40"Smoke N Mirrors" Niceville, FL ----- Original Message ----- From: Thomas Rembert To: WanderlodgeForum@yahoogroups.com Sent: Wednesday, June 13, 2007 10:58 AM Subject: [WanderlodgeForum] Re: PowerTech generator problem --- In WanderlodgeForum@yahoogroups.com, "whynotam" wrote: > > Does anyone have a suggestion on where to start looking for the reason > my 15KW PowerTech won't start? I used it last during a trip to Florida > in January and it worked great. I tried to start it last week and it > fired and ran for just a bit before dying, maybe ran for a few seconds. > It turns over good but will not start. > > Thanks, > > Alvie Miller > 1993 WLWB > I just had to replace the electric fuel pump on mine. I came back to the motor home and found the gen-set off for the first time ever. no circuit breakers popped. started it up was rough running but then did OK. Ran all night but quit the next morning and would only try to start. Replaced the fuel pump and has been running good ever since. I had a spare pump from 2 motor-homes ago(15 years)and it worked fine. Bought a new spare from NAPA, they had it in stock. Good luck Thomas 93 wlwb [Non-text portions of this message have been removed] PowerTech generator problem - Ed Gardels - 06-13-2007 17:15 --- In WanderlodgeForum@yahoogroups.com, "whynotam" wrote: > Alvie... Ihad the same problem with my 89 kabota. Turned out to be a burnt pin in the cannon plug from the control box. The teck that fixed mine bypassed the plug with two wires, one of which supplied voltage to the glow plugs while cranking.I had prob for two years before I got it fixed. Stars right up now.While cranking check voltageon plugs.... hope this does it Ed Gardels 89sp > Roger, > > I will try your suggestions this evening after I get off work. Thanks > for your speedy response. > > Alvie Miller > Arthur IL > 1993 WLWB > > --- In WanderlodgeForum@yahoogroups.com, rogerwwebb@ wrote: > > > > A couple of suggestions: > > > > * verify the fuel solenoid is opening - when you preheat (or > start) the > > engine the solenoid opens, and stays open for matter of seconds > after you > > disengage the start or preheat button - you'll hear clicking - it > then will > > return to the closed position - this solenoid is a booted device > on the curb > > side front of the engine. > > * possible air in fuel line. have someone crank the engine > while you > > open the T handle valve that is inline with the fuel lines (this is > located > > above the solenoid mentioned in the first bullet. Opening this > valve allows > > excess fuel to return to the pump, purging air that may be in the > lines. Some > > people advise this valve should be left open a small amount. > > Generally, if it cranks and gets fuel, it should start. If it > just cranks > > but won't start, and you're fairly sure your getting fuel, check > for a bad > > electrical connection, a prime area is the gang plug with multiple > wires on the > > curb side of the engine. Move/shake the plug to see if that > helps. You can > > also feel (careful) the glow plugs to see if they are warm. > > > > Roger Webb > > 91WBWL > > Cedar Rapids, IA > > > > > > > > > > ************************************** See what's free at > http://www.aol.com. > > > > > > [Non-text portions of this message have been removed] > > > |
